09-11-2014, 07:14 PM
#61
Location: DFW, TX. / Santa Rita, Copán Ruinas, Honduras, C.A.
Lol & Wow Ray! Great write up sir! I'll be stealing some ideas. ;)
-Daniel Kent
Adventure Copán, LLC.
www.AdventureCopan.com
Changing Lives Through Coffee!™
'87 4Runner "pepe" :steer:
09-12-2014, 10:45 AM
#62
I really like that console lock box. Which one did you get and did you buy one of their mounting kits?
09-14-2014, 06:21 PM
#63
It's a Series II without the radio. I only bought what it came with. I'm still working on actual mounting. Bought it from 4WD.com for $226.02 shipped.
-Daniel Kent
09-14-2014, 06:22 PM
#64
Our '87 4R SR5 Honduras Coffee/Missions Rig Build...
Anyone know the back spacing on these? Trying to avoid pulling it off to find out.
Thanks!
-Daniel Kent
EDIT: Was just told 4,3/8.
09-14-2014, 07:35 PM
#65
So here are the rims I'm going with.
Here's the best pic I can find of the color rims I want.
I like the tires on that 40 as well, but I'm leaning towards KM2's 31x10.5x15. Thoughts?
-Daniel Kent
09-14-2014, 09:25 PM
#66
Thanks!
-Daniel Kent
Should be 7" with +15mm backspacing. "15x7JJ-15"
I believe the trucks with the same looking rims had 8mm backspacing.
09-15-2014, 10:12 AM
#67
Thank you. I have a couple spare FJ rims with 33's so I'm going to test fit those to be super sure all fits good. Will post up after!
-Daniel Kent
09-15-2014, 07:05 PM
#68
Talked to a shop about rebuilding our 22RE. It was a lot higher than I was expecting, around $4,500. Looks like I'm buying a new one online for $1,800 shipped!
-Daniel Kent
09-16-2014, 12:21 PM
#69
To test out fit & finish I put on a 33x12.5x15 I had. It fit good, so I know a 31x10.5x15 will do great!
-Daniel Kent
09-16-2014, 03:47 PM
#70
Real Name: Caleb
Real Name: Caleb
That 33 fits great till you try and turn, then youll have some firewall stuffage. The 31s should do nice.
The KM2 is a great all around tire, great for street and off road. But if this runner is going to be spending more time off road than on, I would go with a swamper.
92 ExtraCab on 38s: built for go, not for show
88 4runner: Solid axle, doubler, fun stuff
IG: rattlewagon
Its all about the parts you break, and the friends you make.
09-16-2014, 04:32 PM
#71
Yeah I wanted a swamper since you can go more narrow. However for about the first year it's going to get a lot of street use and I'm afraid the swamper would wear out to fast.
-Daniel Kent
09-16-2014, 06:24 PM
#72
Dropped off my rims at the sand blaster to get stripped. I've decided to spray paint them. Going with the vintage grey.
-Daniel Kent
09-17-2014, 05:08 PM
#73
09-17-2014, 08:38 PM
#74
In the next few weeks looks like we are going with a rebuilt motor from http://www.22reperformance.com/22RE_...t_Engines.html Sadly it's a 20 week wait time!
-Daniel Kent
09-18-2014, 08:27 PM
#75
The Toyota MoreFunner is looking good!
...22reperformance...
...Sadly it's a 20 week wait time!
Good choice!
I also wanted to buy from 22RE performance (Stage 2), but the wait was a concern, and right before I placed an order, an officemate recommended a local shop whose owner used to race 22RE's in Baja California, so I went for them.
So far, happy with the rebuild.
Best wishes.
86 4Runner, 22R-Eliable, 5-Speed Manual, dlx. WHAT'S YOURS?
If you want us to help from afar please let us see, hear, feel what you're dealing with.
A picture paints a thousand words.
Toyota components are bullet-proof. Issues often arise from poor wiring, assembly and/or maintenance. Suspect those first.
Next only to our senses, the multi-meter is the most important electrical diagnostic tool. Spend $6 at Harbor Freight or $$$ blindly replacing parts.
