Runs OK cold-hesitates when it's warm
The hesitation is not much just a slight one and is not present when the engine is cold. I already replaced the oxygen sensor but this did not fix the issue. Let's say I am driving with 40 m/h on the highway and press the gas pedal to accelerate, the hesitation will occur somewhere in the 1/3 of the gas peddle range. If I release the gas and do it again it will do it in approximately the same spot and I can reproduce it. Fuel filter was replaced, plugs, wires, rotor, dist cap... If you have any advice it is very much appreciated. Thanks
85 4runner EFI
Everett, WA
