Old 09-22-2014, 04:52 PM #1
BigRyan1986's Avatar
BigRyan1986 BigRyan1986 is offline
Real Name: Ryan O'Dell
BigRyan1986 is an unknown quantity at this point
dual transfer cases
I have read that people have them so i wonder how do these work and how do you set them up and what would i use to do this
BigRyan1986 is offline   Reply With QuoteReply With Quote
Old 09-22-2014, 08:19 PM #2
4Running15 4Running15 is offline
4Running15 is on a distinguished road
I would do a LOT of reading on Pirate4x4. There is a TON of really helpful information there. But a quick overview of what you need would be:
2 top shift transfer cases (you can convert a forward shift to top shift but it will be easier to find another top shift case
Decide if you want to run stock gears (2.23) in both cases or if you want to put a reduction gear (4.7) in the back t-case (double low and stupid crawl ratio of 223:X or something like that)
Decide if you want to use a triple stick setup or a double stick setup. Triple sticks will allow you to keep MOST (not all) of your center console. Closest option to keep everything factory looking.
You will also need to resize both drive shafts as well a custom transmission/t-case mount to accommodate the extra t-case.
It is not a cheap investment at all. I've got most of the parts I need, but I don't have the coin to resize my driveshafts. I'm going to put a single 4.7 case in and use that setup for a while.
85 4Runner with some mods....
4Running15 is offline   Reply With QuoteReply With Quote
Old 09-22-2014, 09:11 PM #3
Hyde802's Avatar
Hyde802 Hyde802 is offline
Real Name: Caleb
Hyde802 has a spectacular aura about Hyde802 has a spectacular aura about
Hyde802's Avatar
Real Name: Caleb
Read this WHOLE thread. Big mike explains it all. Starts getting good around post#5.
V6 transmission and transfer case - YotaTech Forums
Doesn't matter that it says V6, its good relevant info.
92 ExtraCab on 38s: built for go, not for show
88 4runner: Solid axle, doubler, fun stuff
IG: rattlewagon
Its all about the parts you break, and the friends you make.
Hyde802 is offline   Reply With QuoteReply With Quote
Old 09-22-2014, 09:27 PM #4
Hyde, have you ever regeared a t-case? I'm thinking about trying it myself.
Old 09-23-2014, 12:23 AM #5
sam24th's Avatar
sam24th sam24th is offline
Real Name: Sam
sam24th is on a distinguished road
sam24th's Avatar
Real Name: Sam
I regeared my Tcase in the pickup truck. Went to 4.7 gears in the case. It was a lot easier than I had thought personally.
Need Custom Decals? PM me.
1984 Toyota Pickup SR5: 22r dual fuel propane/gas, 5-speed, 35s, RUF lift, TG high steer, Chevy 63 rear swapped, 5.29 gears, longs, chromo shafts, aisin hubs, 4.8 T-case, twin sticks, addicted offroad bumper, homemade sliders, arb front locker, aussie rear locker.
1989 Toyota 4runner SR5 Daily Driver: 3.0 5-Speed, 35s 4inches of lift (still chicken winged) sliders, arb front locker, 5.29 gears, chromo rear shafts
sam24th is offline   Reply With QuoteReply With Quote
Old 09-23-2014, 03:35 AM #6
KidVermicious's Avatar
KidVermicious KidVermicious is offline
Real Name: Kevin
KidVermicious has a spectacular aura about KidVermicious has a spectacular aura about
Real Name: Kevin
I'm running a single 4.7 case right now. It works and is awesome, but I miss having a normal low range and will upgrade to duals at some point, just to get it back.
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
The Grey Bastard, 1985 4Runner, driveway ornament.
Utah DesertRunners T4R, for all things wheeling and 4Runner in Utah.
KidVermicious is offline   Reply With QuoteReply With Quote
Old 09-23-2014, 06:47 AM #7
Hyde802's Avatar
Real Name: Caleb
Hyde802's Avatar
Real Name: Caleb
Ive lent a hand to other people setting up duals/ gears, but never on my own truck. My plan is to run a single 4.7 case behind my v6, hopefully in the next couple months here Ill be able get that done.
Its not that bad. Just take your time and read the manual. Its just bolts and some gaskets...
IG: rattlewagon
Old 09-23-2014, 11:42 AM #8
thanks for the info so in other words this is something that is probably easier to just buy rather than build myself and i only really need it if im going to be doing alot of rock crawling
Old 09-23-2014, 11:58 AM #9
nevada's Avatar
nevada nevada is offline
nevada has a spectacular aura about nevada has a spectacular aura about nevada has a spectacular aura about
nevada's Avatar
its not too bad to do yourself. you will pay a LOT more for a complete unit. even then, you will still have to install it.
having the option of the extra low gear is very nice. its not as important if you are geared correctly for your tire size, unless you are really serious into wheeling.
it seems that most people get dual cases do so because they need lower gearing to turn their larger tires. but they are still running stock differential gears. very silly. so they have 38's, dual cases and 4.10 axle gears. not smart..
also, its not just for rock crawling. I don't play in the rocks much, I prefer the snow. double low is almost a requirement at times, depending on the snow quality.
1985 pickup: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited: stock. Build Thread YouTube Channel
nevada is offline   Reply With QuoteReply With Quote
Old 09-23-2014, 12:01 PM #10
ajohnson's Avatar
ajohnson ajohnson is offline
ajohnson will become famous soon enough
ajohnson's Avatar
All you need is the front half of one transfer case and an adapter to bolt to the front of another transfer case. The front crawl box bolts to the transmission like normal. New crossmember, modified driveshafts, speedo cable extender, cut a hole for the 2!nd shifter in the body, and you're good to go. It is not difficult.
2007 Tacoma with cool things and stuff
1987 4runner with cool things and stuff and such
ajohnson is offline   Reply With QuoteReply With Quote
Old 09-23-2014, 12:31 PM #11
Hyde802's Avatar
Real Name: Caleb
Hyde802's Avatar
Real Name: Caleb
Im gonna be that guy. No duals, just 4.7. The only bad thing about this is it puts a lot of stress on outputs and ring and pinons. My truck also will never see pavement. So I dont need to work about cruising at highways speeds.
But its more bang for your buck to upgrade the middle multiplication number (t case) than the end number (ring and pinion) and I can find replacement 4.10s all day long for $50, where if I had 5.29s Id be looking at new gear costs plus a bearings n such.
Lets say I can only upgrade one. Most stock trucks have a stock crawl ratio of 36ish (3.9 first gear, x 2.28 t case and 4.10 r&P). Adding ring and pinion alone will bring it down to 47. (3.9 first gear, x 2.28 t case and 5.29 r&P)
Just doing a doubler will bring you way down to 83. (3.9 x 2.28 x 2.28 x 4.10)
Bang for your buck, if you can fab a little all you would need to buy is the adapter and a second case vs 600+ for setup 3rds.
We dont have super sticky rocks up here, so having that much end reduction isnt the end of the world. Just like a lot of these types of debates, its all about your terrain and how you drive. '
T case gears are for wheeling, axle gears are for the street.
IG: rattlewagon
Old 09-23-2014, 12:42 PM #12
ok well this would be for my rig that will be mostly used for wheelin, but occasionally i want to beable to drive it to work and show it off. It does have 38's on it now and supposedly 4.29's the guy i got it from used to wheel it with the 38's but im thinking i want to go down to a 36" tire just for having more room the 38's rub on the back of my frame so do you think that have the dual setup would be good for my application or just an add on that i dont really need at the moment
Old 09-23-2014, 12:45 PM #13
nevada's Avatar
nevada's Avatar
replace those 4.10's with 5.29's and you get over 100: crawl ratio
of course there are exceptions.
dual cases are cheaper, but not by that much. not by the time you buy the adapter, 2nd case, mount, drivelines... it adds up.
if you are only ever offroad, and only ever in low range, a single case with LOW range, or duals in low all the time, with stock diff gears is fine.
most people drive their rigs on the street also, that's where having the proper differential gearing would be important.
Old 09-23-2014, 12:50 PM #14
nevada's Avatar
nevada's Avatar
that must have been a typo? you mean 5.29's?
that's a good ratio for 36-38's. whether you need dual cases or not is up to you. does it seem low enough when you're wheeling? if its not low enough, or you feel it struggles in certain areas, do the duals. you will love it.
what year is your rig? you mentioned the tires are rubbing the frame, that makes me think its an 85. swap in an 86+ rear axle, OR get some 1.5 wheel adapters, to push the tires out a bit, to keep them from rubbing.
Old 09-23-2014, 01:03 PM #15
Hyde802's Avatar
Real Name: Caleb
Hyde802's Avatar
Real Name: Caleb
I think were on the same page here. Thats the "if you can fab part" if you can make your own drivelines and crossmembers, its pretty cheap.
I think you need to find out whats really in the diff, then if it is 4.10s, I bet axle gears would be fine. If its 5.29s, try downsizing to a 36, your IFS will like you better anyway . . .
Make sure the engine is running well, all the gearing in the world wont make up for a dying engine. Didnt you make a post about needing an engine replacement (3.0)? And is this an auto or stick, because that matters.
IG: rattlewagon
Atlas or Dual Cases? 42s on u 3rd gen T4Rs 36 02-17-2014 02:48 PM
Dual Transfer Cases 304-Runner New Members 11 06-08-2013 03:09 AM
Dual Transfer Case(s) 304-Runner New Members 5 06-02-2013 04:04 AM
Dual toyota cases and rear axle RockCndy For Sale: T4R Items 2 05-25-2012 03:28 PM
Quick overview of 3rd gen transfer cases & associated driveline? fasterdammit 3rd gen T4Rs 7 07-13-2011 04:32 PM
