Real Name: Kevin
Real Name: Kevin
When you apply the parking brake how many clicks before it is engaged fully? Hopefully its about 5-8. If your able to jack up the truck and check that the wheels turn at least a full revolution just to make sure the brakes are not engaged. You can also check the parking brake cable is not tight when the brake is not applied.
Good luck hopefully its something easy...
1987 22R-E, SR5. 5 Speed, 31's BFG A/T, stock wheels. 4.56 Gears, Rear Detroit locker Front True Track. 1.5" BJ Spacers & Extended Shackles in the rear.
1992 3.0, SR5. 5 Speed. 31's BFG M/T, stock wheels. 4.30 Gears-NON ADD- manual hubs, Elocker, 1.5" BJ Spacers, Moog springs w/ spacers. Sold
