03-12-2015, 03:29 PM
#31
Originally Posted by ajohnson
I also have the factory rear bumper and driver side plastic cover. The passenger side is damaged. I'll get you some pics when I get a chance.
Sweet that would help out a lot. I'm planning on some low profile tube bumpers eventually but itd be good to have something on there in the meantime. I'll PM you my email and phone number so you can send me pics/price.
On a negative note, my low idle problem is back. New plugs seem to have worsened it but I forgot dielectric grease. May put that on and see if it helps. Anyone have any other ideas?
Here's a couple more pics in the sunlight half way through my Hella H4 install.
03-13-2015, 11:11 AM
#32
Anyone have part numbers or a source for the rear seat center bracket? It's the one that goes into the four bolt holes in between the two seatbacks. I needto put these rear seats in!
Also my rear seat fabric is in ok shape but it is nasty velour with a bunch of stains that won't come out. Does anyone make some nice seat covers for those for a reasonable price?
My truck is missing the most annoying parts to replace! If you have a bunch of spare 1st gen parts or are parting out a truck, check out my wanted ad in the classifieds.
03-13-2015, 12:07 PM
#33
I know this is a lot of stuff but I did warn you in the title!
One more issue I'm going to have to address is the ride height in the rear. Tires fit ok now but once I add the rear bumper, spare tire, and some people and gear it might get pretty close to rubbing.
What are my options for getting the ride height up 1-2"? Want to avoid body lifts if possible. I like OME products and I have helped a buddy install a 2" kit on a wrangler but they are pricey and probably a bit overkill.
I guess I could go the other way and replace the tires with stock size but I like the 265/75/16's on it and BFG A/T's aren't cheap.
Ideas?
03-13-2015, 12:17 PM
#34
if you search for ZUK mod you'll see an in-expensive solution.
basically, install a coil spring between the frame rail and the existing leaf spring.
the other option is to replace the existing leaf springs with OME... i went with ironman.
unfortunately, the ironman was not exactly bolt-in and required a custom bolt thingy for the install.
i didn't do the install but was shown the problem with the bolt that shipped.
good luck!!!
joel
Ideas?
'88 Toyota 4Runner 22re manual
03-13-2015, 01:42 PM
#35
Hmmm ZUK mod is interesting. Seems simple enough but I'm not sure I like how the shock sits on the bump stop. Seems like it would need some kind of cup or puck type thing to sit on.
I didn't realize the stock tire size was so small for these things (225/75-16) and now I'm a little more worried about the 265/75-16's that came on it. Do I need to re-gear at this size? The tires are 3.3" bigger than stock. No telling if it's been re-geared or not. Feels a little sluggish in low gears but I don't have anything to compare it to. I'd say it's doubtful.
On the highway the speedo seems to run about 5mph slow, always have to remind myself to compensate.
03-13-2015, 02:56 PM
#36
My 4Runner came with the equivalent of 30" tires and it was good... looked a little small
When I replaced my wife's 265/70/16s for 265/75/16s I bought 16" steel wheels and put her old tires on...
I can feel the difference. But I just have to downshift a bit more going up hills.
I have a 5-speed 22re and Downey intake & headers and custom 2.5" exhaust with stock gearing.
Joel
03-13-2015, 04:28 PM
#37
About how much space is there supposed to be between there supposed to be between the A-Arm and the bump stops on the front? Mine looks awfully close.
03-13-2015, 06:15 PM
#38
For low idle possibly check your throttle sensor or throttle cable?
03-13-2015, 07:46 PM
#39
The idle issue is a bit complicated! After m first fill up after I bought it it developed a consistent rough/low idle. I put in new plugs, added seafoam, and ran a tank of premium gas through it. That improved it quite a bit but it would still give me a low/rough idle sometimes.
I picked up from paint earlier this week and it was still idling a bit rough, but not as bas as before. I put new NGK spark plug wires in and that seems to have made it worse.
Current situation is...
-Cold crank, idle surges to about 1500
-Quickly settles to 1100-1000 RPM
-Holds for a few seconds
-Drops down to around 400rpm
-Back up to 1000rpm
-Repeats this for about 30-40seconds then eventually conks out during a low idle.
Truck runs great on the move, problem only shows when it's sitting still.
03-15-2015, 12:16 PM
#40
One more issue I'm going to have to address is the ride height in the rear...
OME is the properly engineered solution. Ask Defrag (Home on the Highway) and Ruined Adventures who had put it through the paces in places and conditions that most of us owners could only dream of going.
Two-inch lift in back will require:
1)Cranking your torsion bar to level it up front,
2)OR upgrading to OME's torsion bars,
3) Or using BJ spacers - a debatable option in terms of reliability.
I do not have the budget for OME, either, so I ZUK'd mine ( write-up here). I'm very happy with it.
You can research used springs, or
OR save time, 14-inch, 100-lb/inch Black Magic (Ebay) springs would give you around 2-inch lift.
12-inch, 125 lb/inch BM springs would give you back stock height.
Getting bigger tires without fixing the suspension sag:
1) Will only mask the problem, and not improve your ride quality.
2) May cause another problem (rubbing).
86 4Runner, 22R-Eliable, 5-Speed Manual, dlx. WHAT'S YOURS?
If you want us to help from afar please let us see, hear, feel what you're dealing with.
A picture paints a thousand words.
Toyota components are bullet-proof. Issues often arise from poor wiring, assembly and/or maintenance. Suspect those first.
Next only to our senses, the multi-meter is the most important electrical diagnostic tool. Spend $6 at Harbor Freight or $$$ blindly replacing parts.
03-16-2015, 10:25 AM
#41
It came with bigger tires than stock, I was talking about reverting to stock tire size instead of lifting the suspension. It's a little further back on my list. I have to get everything working first, wipers, horn, etc.
03-16-2015, 12:05 PM
#42
If your rear leafs are blown then you will need to either replace them or do the cheaper ZUK mod.
The 12" black magic springs should help you return to stock height.
The 14" black magic springs will give you about 2" over stock height.
Both should be functional
Returning to stock size tires will help with your MPGs and your "get up and go" will be better because your rotation mass will be reduced.
And you will see a reduction in height... easier to get in and out of your rig.
BUT again, if your leafs are blown you should deal with that and one of the least expensive solutions is the ZUK mod... refer to Ray's build.
Keep up the great work!!!
Joel
03-16-2015, 01:37 PM
#43
Real Name: Mark
Real Name: Mark
-Back up to 1000rpm
Check all your vacuum lines, i just bought a 85 and it had a bad cold idle and it ended up being the rubber intake tube that attaches to the throttle body. I had taken it off several times and never bother to look at the bottom side and sure enough there was a huge crack.
This was after i had gone through just about everything, plugs and wires, IACV, cold start injector, cold start switch, removed and cleaned throttle bod and intake manifold. Anyways runs like a champ now.
2013 TE w/KDSS, Nav | Mods: OME 3'' w/OME shocks, 1.25'' wheel spacers, 285/70-17 Cooper ST Maxx, Baja Rack
1985 4runner Mods:Custom Alcan springs, Bilstiens, Downey Header & Cat, Cherry Bomb exhaust, ARB Bull bar w/warn winch, ARB rear air locker w/ARB compressor, 5.29 gears, Marlin Crawler single 4.7 case, KMC enduro wheels w/BFG muds, CanBack Soft top, 40'' LED light bar
03-16-2015, 01:48 PM
#44
This weekend I tried putting teflon tape on the idle adjustment screw. I set it to three turns from fully tight. The truck idled flawlessly at about 8-900 rpm for two days. Tried starting it up today and it did the old high idle/low idle, conk out. I'll try it again after work to see if it repeats the issue.
Next order of business is to get the horn and wipers working so I can pass safety inspection.
I am having some trouble removing the cowl, removed the three screws in the center but there are two brittle plastic rivets on the ends. I assume these are the only things preventing me from removing the cowl? Any thoughts on how to get them off without removing the hood? (I hope)
Wiper linkage underneath is either broken or disconnected.
In the meantime I ignored the important stuff and popped on some hella lights and sweet little dick cepek stone guards ($9 on ebay). I Like the look and I hope they'll protect the glass lenses a bit.
03-16-2015, 02:41 PM
#45
If you didn't know already, worn horn contacts inside the steering wheel is a common issue. I need to fix this on my '87.
2007 Tacoma with cool things and stuff
1987 4runner with cool things and stuff and such
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
