Old 03-17-2015, 09:50 AM #46
rusty904 rusty904 is offline
rusty904 is on a distinguished road
Managed to fix the wipers last night. Removed the cowl by tapping the heads of the brittle plastic rivets off with a mallet and a sharp flat head screwdriver. I found the wiper linkage disconnected and jammed up, which explains why the motor was getting really hot without moving anything. Re-connected the linkage and replaced the cowl and presto, working wipers!
The design seems pretty weak on those things. It's a little plastic ball and socket deal that just snaps into place. Guess it's designed to pop off before anything breaks?
Need to find the part number for those plastic rivets or better yet, figure out a way to replace them with screws.
rusty904 is offline   Reply With QuoteReply With Quote
Old 03-17-2015, 03:21 PM #47
This is low priority, but does anyone know where I could get some centercaps for my back wheels? Seems to be options on ebay but I don't know what would or wouldn't fit my steelies.
Suppose I could just plastidip the hub black.
Old 03-17-2015, 04:33 PM #48
javendan's Avatar
javendan javendan is offline
javendan is on a distinguished road
javendan's Avatar
I went with wheelers offroad...
http://wheelersoffroad.com/product-c...g-nuts-282843/
Scroll down.
Joel
'88 Toyota 4Runner 22re manual
javendan is offline   Reply With QuoteReply With Quote
Old 03-17-2015, 08:42 PM #49
onemanarmy onemanarmy is offline
onemanarmy is on a distinguished road
Nice Runner....I was eyeing that one as well.
For the rear suspension, I added two cut down leaves to the factory rear pack and a 2" longer shackle...tried to get the best of both worlds. Plenty of room for 31s, and didn't cost much at all and will be dependable.
For the most reliable front end lift, if you want to lift it, is the heavier duty torsion bars.
And I second the search for the vacuum leak first. Often times you hear that the cheapest/most obvious issues are the culprit.
wyndscreen.com
onemanarmy is offline   Reply With QuoteReply With Quote
Old 03-19-2015, 05:46 PM #50
Thanks for the link on the centercaps, may give those a try. I ordered a bunch of nuts and bolts plus a horn contact plate and an A/C faceplate off toyotapartsdeal.com. Great prices but they'll take forever to get here. Also still no sign of any center seat brackets for the rear!!!!! I want 4 seat capability so bad!
Still debating on the ZUK mod. There seems to be a lot of documentation for it but it just doesn't look right to me, spring on the bump stop with nothing really holding it in place except pressure looks like bad news to my untrained eye.
OME kit is super nice but just too much. Has anyone just put new leaf springs in? Skyjacker "soft ride" leafs are supposed to add about 2" of lift and are about $150ea. I haven't looked hard but there have to be some other brands out there too?
Anyone care to sell me on the ZUK mod or some other option? I'd say the rear end needs to go up about 2" or so for good clearance under moderate loads and the front should go up maybe 1" or so.
Old 03-21-2015, 12:59 AM #51
Nervo19's Avatar
Nervo19 Nervo19 is offline
Nervo19 is on a distinguished road
Nervo19's Avatar
The paint turned out great! Please get some sort of theft protection for it. I always liked the Club. It will not stop a pro west coast thief but it will stop the joy riders.
I don't understand why you are using Plasti Dip on body parts. It is designed to peel off. I used satin black Rustoleum on wiper arms etc. four years ago and it has held up.
1989 4Runner Build thread:http://www.yotatech.com/f199/nervo19.../#post52231244
2000 4Runner & 2000 Tacoma TRD Off Road
2008 4Runner & 2016 Tacoma 4x4 Dbl Cab TRD Sport
Nervo19 is offline   Reply With QuoteReply With Quote
Old 03-23-2015, 12:37 AM #52
Pretty much just because it's all I had handy in matte black. Also it's really easy to get a consistent finish and its proven quite durable in my experience.
Agree on the anti-theft. Need something to protect it. Add that to the list!
Old 03-23-2015, 03:02 AM #53
RAD4Runner's Avatar
RAD4Runner RAD4Runner is offline
RAD4Runner has a spectacular aura about RAD4Runner has a spectacular aura about
RAD4Runner's Avatar
Still debating on the ZUK mod. ... nothing really holding it in place except pressure...
Yes, something holds my springs
If I had the budget, I'd do the OME front and back, but for now Zuk makes sense for what I use the truck for...
86 4Runner, 22R-Eliable, 5-Speed Manual, dlx. WHAT'S YOURS?
If you want us to help from afar please let us see, hear, feel what you're dealing with.
A picture paints a thousand words.
Toyota components are bullet-proof. Issues often arise from poor wiring, assembly and/or maintenance. Suspect those first.
Next only to our senses, the multi-meter is the most important electrical diagnostic tool. Spend $6 at Harbor Freight or $$$ blindly replacing parts.
RAD4Runner is offline   Reply With QuoteReply With Quote
Old 03-24-2015, 11:18 AM #54
Picked up a stock rear bumper and skid last weekend (thanks ajohnson!) Was bolting it on yesterday with some slightly rusty hardware and one of the bolt heads sheared off with very minimal force. I cleaned the threads with a wire brush and was using a small 3/8's ratchet and it just broke off like it was made of cheese!
That'll teach me to buy new hardware.
There are no exposed threads, it's nearly flush with the hole. Anybody have a good bolt extraction technique to share? Preferably one that does not involve a welder.
88 4Runner Project! (Lots of Questions)-img_0570-jpg
Old 03-24-2015, 11:32 AM #55
javendan's Avatar
javendan's Avatar
quick google search and there are other videos obviously
https://www.youtube.com/watch?v=K34RS6M11uw
i imagine any auto store and sears has what you are looking for.
good luck... you should be okay!
joel
Old 03-24-2015, 11:34 AM #56
Thanks for the link, saw a few and heard of a few different techniques through searching and talking to people around here, just wanted to see if anyone had any ideas I hadn't heard of! I just haven't had a ton of luck with extractors in the past.
Old 03-24-2015, 08:43 PM #57
RAD4Runner's Avatar
RAD4Runner's Avatar
Originally Posted by gamefreakgc View Post
The headliner can be glued, but if it has shrunk due to age or moisture I'm not sure if you can ever get it back. You could try applying some heat and try and stretch it, but that might loosen the entire headliner and make things worse.
Forget fixing the headliner. If you don't mind non-OEM but utilitarian...
Diamond-plate pattern anti-fatigue/shop mat... approx $22 from Sears.
I removed old headliner, left foam in there because it is still in good shape, and used some headliner spray adhesive to stick mat on to old foam. Adhesive not even critical because the mat is pretty rigid. It does not sag.
Now I have extra acoustic insulation on the Fiberglas cap...
Old 03-25-2015, 11:18 AM #58
[QUOTE=RAD4Runner;1962504]Forget fixing the headliner. If you don't mind non-OEM but utilitarian...
Well done, very innovative. Totally forgot about the headliner honestly, sooo much to do!
Old 03-25-2015, 06:30 PM #59
RAD4Runner's Avatar
RAD4Runner's Avatar
[QUOTE=rusty904;1962981]
Thanks. Original idea by Chefyota4x4@Yotatech.
Old 04-03-2015, 10:13 AM #60
WOOHOOO SEAT BRACKETS!
Finally stumbled on a full set of rear seat brackets on ebay. So stoked to have 4 seat capability. I'm just going to have to figure out how to mount the (strikers?) on the DIY interior panel that came on the truck.
I'd also really like to find some headrests to fit my rear seats. Does anyone happen to know if other gen's headrests will fit or if there are universal headrests with 5.5" posts? Don't particularly care about matching things up.
Finally with regards to the rear seats, has anyone come up with a nice way to cover the rear seats up? The velour on mine is pretty gross even though the seats themselves (frames and cushions) seem to be in great shape. Even though it's probably the best solution, I'd rather not pay $300+ to get them re-upholstered.
Any decent quality seat covers out there?
1988 , dents , flooring , interior , project
New 05 4Runner Lots of Questions! sprtv8 4th Gen T4Rs 6 04-04-2014 10:31 PM
New 2000 4Runner owner with lots of questions! dbsoundman 3rd gen T4Rs 18 11-06-2012 07:34 PM
Lots of questions about 2nd generation 4runner Az Yota New Members 3 10-13-2011 08:32 PM
1992 4Runner SR5 4WD IMACULATE Lots of Extras, Lots of New Parts - $4395 St Louis,MO SupraRacer Classifieds - buy & sell (no commercial ads please) 8 01-21-2011 01:16 PM
first car 2006 4runner limited lots of questions zlasterhazzard New Members 3 12-27-2009 05:20 AM
