Old 03-31-2015, 01:10 PM #1
forerunner95 forerunner95 is offline
forerunner95 is on a distinguished road
95 3.0 Gas Leak Only When Engine is Running
This morning I have noticed that there is a gas leak when engine is running. It was literally dripping every couple seconds. The leak is coming from the front-passenger side, between the engine and shocks, around that area.
Any advice or input is greatly appreciated.
forerunner95 is offline   Reply With QuoteReply With Quote
Old 03-31-2015, 01:48 PM #2
colep123 colep123 is offline
colep123 is on a distinguished road
could it be coming from the top of the engine and just following a line down?
colep123 is offline   Reply With QuoteReply With Quote
Old 03-31-2015, 04:31 PM #3
dogojoe96's Avatar
dogojoe96 dogojoe96 is offline
Real Name: Joe
dogojoe96 is on a distinguished road
dogojoe96's Avatar
Real Name: Joe
Check the rubber lines that go to the pressure regulator I believe its called. The hoses can get brittle or clamps come off and cause it to leak. Looking up a diagram of the fuel system on your 4runner should help
1993 4Runner 3.0L, 5 speed swap, 3in lift pro-comp rear coils and front torsion bars cranked up/ ball joint spacers.
dogojoe96 is offline   Reply With QuoteReply With Quote
Old 03-31-2015, 05:08 PM #4
Hyde802's Avatar
Hyde802 Hyde802 is offline
Real Name: Caleb
Hyde802 has a spectacular aura about Hyde802 has a spectacular aura about
Hyde802's Avatar
Real Name: Caleb
Makes sense, thats where the gas lines are.
If you open the hood while its running, you should be able to see where its coming from. Did you check to see where it was coming from at all?
Always be careful with gas leaks. Dont go gettin blowed up.
92 ExtraCab on 38s: built for go, not for show
88 4runner: Solid axle, doubler, fun stuff
IG: rattlewagon
Its all about the parts you break, and the friends you make.
Hyde802 is offline   Reply With QuoteReply With Quote
Old 03-31-2015, 08:37 PM #5
I appreciate all the direction. My friend gave me a ride to work today. Came back in the evening and looked for any fresh leaks but there were none.
I started the engine, got under the car started waiting for a drip but again there were none.
I inspected as much as I can. Turned off, looked around, turned back on, revved up the engine, looked around engine running, revved up again and nothing. So weird. Puzzled.
However one thing comes to my mind that in the morning I experienced this after a cold night and in the evening it is after a warm day. I will check in the morning if no leak I will take it to work.
Also, I just got the head gasket replaced, this guy working at this shop took a long time, and extended three deadlines he himself gave me. Changed distributor since there was idling issues. I gave it a go and got it changed. Idling issues are still there.
Now I found there is a crack in the intake hose which wasn't there before and this guy tried to cover it with a silicon based compound. On the Air flow sensor the sensor section is ziptied to secure. Also the Mass Air Flow Sensor making a sound like somebody sucking an empty soda bottle with a straw.
The worst case scenario I will buy a new air flow sensor together with the hose.
But the main concern I have is the gas leak I saw this morning. I am still puzzled since I don't want to blow the whole truck up.
One last thing is there is lots of gunk since I had head gasket issues, had oil and power steering leaks. What is the best way to clean that. Best way to do it without effecting electrical system.
Sorry for the long post and again I appreciate all the response. Thanks!
Old 04-01-2015, 09:00 AM #6
This morning it leaked again and Hyde802 was right on spot, it is the gas line. It was a tiny stream as if you sticked a needle there. Is there specific name to that section to the fuel line, which seems to be a short piece with screw on both ends. Here is a picture of it:
Please help! Massive oil leak with engine running! DoddBoy1 3rd gen T4Rs 17 09-04-2018 05:17 PM
Gas leak under engine? mistersnowman97 Classic T4Rs 7 07-15-2014 09:30 AM
Engine,VSC,ABS and Brake lights on, no codes, engine running rough chd2001 4th Gen T4Rs 2 04-22-2014 12:14 PM
Possible engine oil leak? Auce 3rd gen T4Rs 5 04-09-2014 08:28 PM
engine starts.. then dies.. must keep gas applied to keep it running. vacuum leak? airbag 3rd gen T4Rs 16 03-22-2008 10:08 AM
