I understand the concept but don't know how to apply it. The wires are in a think harness that lead into connections. I gutted the entire door, and removed all the insides to try to further figure it out. This is basically the entire system as it applies to this problem:
Press button->signal goes through the circuit board all the driver's side buttons go through->into the thick wiring harness->a connector->other side of connection goes to window motor.
With only the window motor hooked up, it goes down in a fury. When I press for it to go up, however, nothing; not even a sound or click.
I went ahead and ordered a new window motor from autozone for 50 bucks. I'll plug it in and see if the situation goes away, if so, 50 bucks well spent. If it doesn't, I'll take it back and start pounding my head into the wall.
My problem is if the 'new' motor does the exact same thing, I don't know what to do or test.
