Fish Hunter, you are the man. Let me fill you in on some of these details.
Originally Posted by FISH HUNTER
You might have more than one issue. Make sure the timing is right. Check you TDC too.
Timing is one way I am leaning as well. I just didn't think it would start this well if the timing were off. Even at cold temps without the block heater it always starts around the 3rd crank. I'm guessing by TDC you mean top dead center. I assume there are markings on the pulleys to do this right? Or is it important to check that the engine is actually at TDC when that bottom pulley is lined up with the markings?
For the compression, if its low, then pour some oil down the cylinder and take another reading. If the compression goes up, then your rings are bad, if the compression does not go up, then the valve (s) might be burnt.
I have heard this, just having trouble getting ahold of a compression gauge with my work schedule. Hoping to get some of this done this weekend!
Your exhaust is just sending sounds from our engine. So its probably not the exhaust.
The reason I'm wary of the exhaust is that it was changed by one of the two previous owners, so not sure if it was done to OEM standards.
Is your radiator fluid going down after a period of driving?
Can you smell any radiator fluid smell in your exhaust (don't breath your exhaust for a long time)?
I haven't experienced any of the tell-tale head gasket signs I've seen around, but I'm not completely counting it out. Underneath the oil cap is completely clean and bone dry. The coolant level is stable and a bright green. The exhaust smells odd but more like fuel than the sweetness of coolant, also the smoke goes down once it warms up to normal winter levels. The temperature gauge goes up to the middle after 5-10 minutes and doesn't budge after that.
Is your cat plugged up?
I need to look at the exhaust they put in there. I wouldn't be surprised if it doesn't even have a cat. Would the lack of back pressure from not having a cat affect fuel economy?
When you start your engine, do all the idiots light (the CEL) light come on for a short period of time? If not, you might have a CEL light but not know it.
Yeah all the lights come on, the Rear ABS light goes off after a moment or two.
On your idle, the idle screw is on the throttle body. There is a flat head screw facing the front of the engine. The more you turn the screw in, the lower our engine idle will go. Your idle should be around 600-750 RPM. Again, check your timing and also TDC
Is there a fast idle control on this vehicle? Is it never idling lower than 1000 potentially because it's below freezing out? It seems to start at around 1500 rpm and settle down to 1000 rpm once it has warmed up. But I've also read that people find their trucks idle at 1000 for the winter even after they've warmed up but go down to 750 or 800 once summer hits.
Appreciate all the help. Gonna get some wrenches turning soon so that I can start ruling things out.
Paul
