Old 08-13-2015, 11:30 PM #31
UnderFire's Avatar
UnderFire UnderFire is offline
UnderFire has a spectacular aura about UnderFire has a spectacular aura about UnderFire has a spectacular aura about
UnderFire's Avatar
Originally Posted by flyinhawaiian01 View Post
Good amount of money for a 1UZ, and it has to be a specific one (not the VVti engine), but you would probably be very happy with the power/torque output of one!
There's also a lot of wiring support for that engine in the supra world, and the trucks/4 runners are very similar to the MKII supra in terms of sensors and transmissions.
Price wise, it would be cheaper to go with an american engine (chevy/ford), there's several companies who do full kits for engine swaps like that, and you can find Vortecs all over the place for little money.
Personally, I would love to go with the 3RZ swap into my truck, the setup is pretty well-documented online, the parts are readily available, the engines are also easy to find, and best of all, its a TOYOTA!
Kevin, don't you have a 3RZ?
The cars that had the 1UZ from the factory are very cheap around here with interior, exterior or transmission problems, I've seen countless 90-94 LS400 and SC400's over the course of the last year around here for well under 1k, some were running and driving but wrecked.
There is also a lot of support growing for putting the 1UZ into Pickups and 4runners, 2 local companies have popped up within the last couple of months that are selling bellhousings for W and R series 4wd transmissions as well as prebuilt harnesses, which solves the 2 main hurdles with the swap, they aren't super cheap or simple like the small block Chevy, but should get much better milage, run smoother and fit better in the engine bay.
'97 3RZ 5 Speed "FrankenRunner" (Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - (Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
UnderFire is offline   Reply With QuoteReply With Quote
Old 08-13-2015, 11:52 PM #32
santanvalleydirt's Avatar
santanvalleydirt santanvalleydirt is offline
santanvalleydirt is on a distinguished road
Originally Posted by UnderFire View Post
Some people claim they're the best engine Toyota ever built, forged crank, 6 bolt main, all aluminum, etc., not a powerhouse in stock form, but you can't beat the ability to rev to 9k with a v8
Looking up specs for the 1UZ says that it gets 250 HP.... to me that's a power house compared to the 125 HP 3vze.
santanvalleydirt is offline   Reply With QuoteReply With Quote
Old 08-14-2015, 12:48 AM #33
UnderFire's Avatar
UnderFire's Avatar
From what I've seen, with light modifications like intake and exhaust, you'll get about 210-230WHP through a manual transmission, add in a good tune on an aftermarket standalone ECU and you're closer to the 250 mark.
Either way, yes it's a much more lively engine than the 3.slow, the power curve is way better too.
Old 08-14-2015, 02:27 AM #34
Now the real challenge: getting all of that for my 4Runner while spending hardly any money.
Old 08-14-2015, 05:46 AM #35
KidVermicious's Avatar
KidVermicious KidVermicious is offline
Real Name: Kevin
KidVermicious has a spectacular aura about KidVermicious has a spectacular aura about
Real Name: Kevin
I'm working on putting in a 3RZ, yeah. It'll be a huge improvement over the 22RE, but a 1UZ or LS would be even better.
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
The Grey Bastard, 1985 4Runner, driveway ornament.
Utah DesertRunners T4R, for all things wheeling and 4Runner in Utah.
KidVermicious is offline   Reply With QuoteReply With Quote
Old 08-14-2015, 05:50 AM #36
Real Name: Kevin
Real Name: Kevin
If you're thinking swap, hard to go wrong with a 3.4. It's "only" a V6, but it bolts up to your bell housing and motor mounts, and you can buy a conversion harness and still finish the swap under $1000 if you buy the right donor truck. That's 180 very cheap and easy horsepower. A 1UZ swap would be a lot more complicated.
Old 08-14-2015, 01:29 PM #37
flyinhawaiian01's Avatar
flyinhawaiian01 flyinhawaiian01 is offline
Real Name: Chris
flyinhawaiian01 will become famous soon enough
Real Name: Chris
Yep, a 1UZ would be fantastic, but cost to finish the project, including everything you'd need, and have the truck driving on its own power down the road, you're at least 3 grand into it. While a lot will carry over from the donor car, to do it "RIGHT", means to adapt a bunch of stuff in the dash, get exhaust system run properly and still have it efficient so you get full power of out that engine, and have it all tuned and dialed in costs a LOT more than just throwing in a V6. Those can be done dirt cheap, even with a full build on the engine!
I too would love a 1UZ in my truck, but the economical way to make power would be Chevy V6.
And I know you can get a cheap sub-1,000 dollar lexus as a donor car with lots of other issues, but for me, putting an engine that has more than 100,000 miles in my truck without at least going through and doing a mild rebuild to make sure all is well before the swap would be a bad decision. Just that alone will cost you near 4 or 500 bucks more (full gasket kit, water pump, timing belt, whatever else would be done on a 100k service), and that doesn't include any repairs if you find something wrong.
And, if any of you wanna swap a 1UZ into your vehicle and adapt an R-154 trans to it, I've got a friend selling his one-off bellhousing right now!
Ain't she purrdyyyy!?!?!?!?!
2011 4 Runner (my daily driver)
1987 Xtra Cab (35's and locked front/rear, the trail toy!)
1985 Supra (430rwhp track toy!)
2006 Honduh Odyssey (the wife's van)
flyinhawaiian01 is offline   Reply With QuoteReply With Quote
Old 08-14-2015, 01:31 PM #38
Real Name: Chris
Real Name: Chris
Oops! Forgot to show this one in my last post! You can put a 1UZ into almost anything! Like a Merkur!!!!
Old 08-14-2015, 05:40 PM #39
The 3.4 is able to use the 2nd Gen's motor mounts??
Old 08-14-2015, 06:45 PM #40
Real Name: Kevin
Real Name: Kevin
I haven't done it obviously, but that's my understanding. If you wanna know for sure there's a ton of swap threads on Yotatech, or just ask @BigBluePile . He's got a 3.4 in his 3.0 first gen.
Old 08-14-2015, 11:10 PM #41
UnderFire's Avatar
UnderFire's Avatar
How much is he asking for that bellhousing? I need one for my Corona project.
And the 4.3 doesn't fit too well in the bay and the NWOR swap kit is pretty crappy, We've chased endless problems with our neighbors 4.3 swapped 92 pickup.
Old 08-15-2015, 12:56 PM #42
Real Name: Chris
Real Name: Chris
I shot him an email a little while ago, if I don't hear back from him today or tomorrow, I'll call him on Monday for ya.
Old 08-15-2015, 04:42 PM #43
UnderFire's Avatar
UnderFire's Avatar
Awesome man, if you don't know, could you ask him if it uses a hydraulic TOB or a standard slave cylinder setup? Been hoping to find one with a slave clyinder setup.
Old 08-15-2015, 11:15 PM #44
Real Name: Chris
Real Name: Chris
I can probably answer that question, unfortunately:
He might be out of town for the weekend, haven't heard back yet and he usually gets back to me pretty quick...
Old 10-18-2015, 10:29 PM #45
BigBluePile's Avatar
BigBluePile BigBluePile is offline
Real Name: BBP
BigBluePile is on a distinguished road
Real Name: BBP
Tons of info out there. Mine was even MORE complicated as it was a 22R-E vice a 3VZ. Mine was a three day thrash fest to put together. However, I did help get a 2nd gen 4Runner 3.0 swapped over to a 3.4 in an easy day.....
It's OEM brah.
BigBluePile is offline   Reply With QuoteReply With Quote
22re 30-40 Timing issue low mpg and power ricker2278 Classic T4Rs 2 11-19-2014 09:19 PM
Just Rebuilt 22re for 87 4runner 2.4L non turbo....no power need help!! econ1290 Classic T4Rs 5 05-01-2014 09:32 PM
22re down on power illzoni Classic T4Rs 4 11-27-2011 12:16 PM
rebuilding a 22re. more HORSE POWER NEEDED pacman Classic T4Rs 2 03-19-2009 04:52 AM
some 22re power questions goin-pro Classic T4Rs 5 11-20-2008 09:21 PM
