05-02-2012, 06:36 PM
Failed Smog in CA... Help :(
Hey Guys,
Out here in California, and the vehicles are tested at 15 & 25mph for HC(PPM), CO(%), and NO(PPM). The vehicle passed all except for the Nitrous Oxide (NO) at 15mph. The max reading is allowed at 356, & the average reading is supposed to be 39, however my truck showed 709! It was a test only station, and the guy was helpful and said that it's running "lean", and the cause could be one of the following:
1) EGR valve not working properly
2) Ignition timing not set properly
3) Catalytic converter not working properly
I bought the truck recently and it had 287k miles on it, and the heads have been rebuilt recently. I have not changed anything on it yet. Just driven it about 500 miles. It runs fine (no misses or stalling), and gets anywhere from 15-18mpg. Timing can't be set properly at the moment as the bottom timing belt cover is not there (as that's what has the BTDC marks on it). I'm tearing it down to install a new bottom timing belt cover this evening. Once the timing is set properly (I was told it's 10* BTDC) should I retest again, or is there any way of figuring out if there's something wrong with the catalytic converter or the EGR valve (which I hope is not the case)? Thanks in advance!
1999 Toyota 4Runner. 4x4, V6, Auto, Factory Rear E-Locker
05-02-2012, 06:54 PM
Real Name: Willy
Real Name: Willy
same issue - solved by a new cat
A muffler shop should run you $120 to weld one in. You can use a universal cat prior to 1995 instead of a vehicle specific unit. While you are at the muffler shop - A cat back replacement puts a pleasant rumble in the exhaust note.
05-02-2012, 11:45 PM
That is a lot of miles and the cat could be bad, but I think it could also be the O2 sensor, which is much cheaper to replace. If it were me, I'd confirm the timing is right and then consider replacing the O2, a Denso is like $50. I have heard that if you hit the cat with a rubber mallet and it rattles, it should be replaced. Also, check for any stored codes, especially the code 71 for the EGR. If there are none, just to double check, I'd run through the FSM procedure for checking the EGR components. Its pretty quick.
05-03-2012, 12:16 AM
If it does need a catalytic converter, are you sure a universal one would fit, and be okay for the long run? A guy at one of the shops said it could cost me anywhere upwards of $500!!
Can someone enlighten me on how to check and diagnose codes? How do you access/look for a code, and how do you know what it means... do you need some kind of scanner?? Assuming the FSM will have the meaning of each code once you find it right?
05-03-2012, 01:41 AM
Toyota Tech - Diagnostic Trouble Codes
Here ya go. No scanner needed, just follow the instructions and get a little piece of wire (or paperclip) to jump the connections. This one is for 22re engines, but I'm pretty sure the codes are the same for V6.
05-03-2012, 02:06 AM
Thanks... that really helps! Can anyone verify if the codes for the 22re & the 3-liter engine are the same?
05-03-2012, 01:29 PM
[QUOTE=Lankan;1057872]If it does need a catalytic converter, are you sure a universal one would fit, and be okay for the long run? A guy at one of the shops said it could cost me anywhere upwards of $500!!
$500?!?! Thats insane. I bought a magnaflow hi flow cat for around $100 and had it welded in for $40.. And yes, a universal one will work. I had one on for a few months when my old one got stolen.
2006 Sport V8
05-03-2012, 05:44 PM
The OP lives in CA and I was under the impression most magnaflow cats can no longer be sold there since they are not the greatest cats and don't actually do much.
Cheap cats are cheap because they don't do all that much and have very little of the precious metals (not "precious means hard to get and expensive) that are the actual catalyst to convert the exhaust.
In CA you can get an aftermarket, but it will need to meet CA standards and will probably be more expensive than 100 bucks.
05-03-2012, 09:14 PM
I live in Cali and passed smog with my magnaflow.
2006 Sport V8
05-04-2012, 12:30 AM
As some of you say, the mechanic said that cheap cats can only work for a few months. I'm really dreading the second test. My plan is to get the timing done properly by the shop. They also said they got the tools to check if there is an issue with the EGR valve... I'm hoping all this doesn't cost a whole lot!
05-07-2012, 01:38 PM
Guys, while installing new upper and lower timing covers, I also checked all the vacuum tubes that are near the EGR system. I realized that a one way valve that operates with a VSV and the PAIR Reed Valve was installed the wrong way. Could this have anything thing to do with the EGR not working properly and the "NO" levels reading high at lower RPM's (the reason why I failed the smog)?
05-07-2012, 02:09 PM
Real Name: Brett
Real Name: Brett
Only way to know for is unplug battery so check engine light goes away and drive for 50-100 miles and see if it comes back on and check codes.
05-07-2012, 05:16 PM
was the smog check place actually nice enough to only charge you half the cost when you failed, and charge you the remainder when you go back to retest?
'95 3.0 - OME shocks and springs - trail damage - Lots of stuff coming in the near future.
05-07-2012, 06:47 PM
I see... guess it's worth the chance to get the smog checked again, as that costs only $20, as opposed to the minimum $90/hr labor charge that a local shop wants to diagnose the problem.
The smog fee here in Cali for an OBD1 can vary. At the place I got it, the test is $51.95 + $8 for the certificate (the first time around). Re-testing is $20. So IF I pass the 2nd time around, it will be $51.95 (which I had to already pay the first time) + $20 + $8. If it doesn't pass and I have to go a third time... add another $20.
By the way, in case I need one, I checked a few places for pricing of a universal catalytic converter. Pep Boys has it for $180 with a one year warranty, and a local muffler shop has it for $220 installed with a 7-year warranty! So thank goodness, it's not as expensive as what I had heard from a mechanic when first checking out the problem.
05-09-2012, 12:33 AM
Do the $220. It may seem like a lot now, but when you think of it, $40 for an extra 6 years is awesome!!
