Old 07-27-2015, 10:31 PM #1
f0rest f0rest is offline
f0rest is on a distinguished road
A/C problems, please help! Thank you in advance!
Hello readers,
I should be under the right discussion but feel free to move my topic if not.
What I have:
Toyota 4runner 1991 SR5 V6 3.0L Engine it's has a manual transmission.
I am having the following problem, my A/C does not blow cold. So I went and bought a bottle of Refrigerant because I thought I was just low on it. I loaded it up and within 5 minutes it was blowing cold air, I put everything away try it again still cold air. Two days later I try it and no cold air comes out, so I am guessing a leak? I leave it where it is because at the time I could not deal with it, and I move to a different state, here I am now with as much time as I need, I buy another bottle and try the same exact thing, this time no cold air comes out, I try to fill it but it won't let me. So I go on the internet and it looks like there is a AC Compressor Clutch which needs to engage so when I add the refrigerant it can go in. I go to check out YouTube videos and everyone shows and explains how to do it on their car, and how to manually engage the ac compressor clutch by removing the fuse and giving it power with a wire, problem is I open my fuse box (under my hood) and I don't see anything that says A/C on it, all I have is (ALT 80A, 15A EFI, 7.5A Charge, 15A Dome, 15A HAZ - Horn, 10A Head(LH), 10A Head(RH), AM2 30A, AM1 40A) Aside from that box I have a second smaller box which has the following on it (FAN NO1, FAN NO2, FAN 30A) so my question is where is my A/C fuse? As well as how do I know if my clutch has engaged? The examples they have shown on YouTube are on small cars which you can see everything around the engine, but mine are right up front and all are ROLLING when car is running and the AC is on, blowing on max on cold as well as open doors, there is one at the bottom in which it's head isn't moving but it looks like that one isn't it because the examples I've seen on other cars it's always a black plastic looking circle but the one I have is straight metal coming out the actual "wheel" so please if you understand let me know, if you need any pictures, just let me know I will take them and upload by tomorrow. Thank you in advance, I really appreciate it!
f0rest is offline   Reply With QuoteReply With Quote
Old 07-27-2015, 10:56 PM #2
santanvalleydirt's Avatar
santanvalleydirt santanvalleydirt is offline
santanvalleydirt is on a distinguished road
Originally Posted by f0rest View Post
Hello readers,
What I have:
I literally just got this problem fixed on my 2nd Gen 95 3.0. It ended up being a bad A/C belt. The belt was old, slick, and didn't have enough traction to start the A/C. Sometimes it would catch and the it would blow cold, sometimes it wouldn't and it'd be hot. Have any horrible noise come out?
santanvalleydirt is offline   Reply With QuoteReply With Quote
Old 07-27-2015, 11:06 PM #3
Peevedkitten's Avatar
Peevedkitten Peevedkitten is offline
Peevedkitten is on a distinguished road
Is the AC belt the lower accessory belt? I was to tired when I was under the runner last.
Peevedkitten is offline   Reply With QuoteReply With Quote
Old 07-27-2015, 11:27 PM #4
No clue, lol. Went to a shop, didn't have time to do it myself. They did have to put it on the lift though, so I think it is.
Old 07-28-2015, 12:30 AM #5
Hey santanvalleydirt thank you for replying to my post. Yes back when I filled it the first time and it blew cold it took a good 3-5 minutes and it was more than a horrible noise but it eventually stopped, and it was still blowing cold, until two days after when I tried again, and it was not blowing cold at all. But now when I tried to fill it up it does not want to even blow cold so that's why I researched and people said to look into the compression clutch but like I mentioned before all the examples I saw were on Hondas or some low cars which had a lot of space between the engines and you can clearly see if it runs or not but my Toyota doesn't, I can see all of the BELTS for sure, and they are all spinning, but isn't the AC compression clutch engaged when a plastic thing is spinning as well? I don't have it on that circle that's why I am asking which belt is it and how do I know it's running? Because even with the AC switch off the all belts are still spinning.
Old 07-28-2015, 12:34 AM #6
And also which one is the Fuse for the A/C? What is the name? I don't have one under my hood nor inside? Is there a specific name? Would you like pictures of both fuse boxes? Please I need to fix this because I moved from Washington to Florida, and I am using the Toyota for my daily and it is pretty hot here hahaha! I have some money, but would not like to spend it on something I could probably fix with some guide.
Old 07-28-2015, 12:45 AM #7
I don't know anything about fuses unfortunately...maybe a Google search to find it. And I'm not sure which belt, I didn't even look, everything seemed to be in running condition, but the shop found that the belt was too loose and stripped, and would just free-spin, with out ever activating the A/C system. It looked like it did, but it wasn't catching. It did cause that horrible squealing noise, and a new one fixed my whole problem.
Old 07-28-2015, 12:47 AM #8
Okay thank you! And may I ask how much did it cost you for the belt and for it to be replaced? Thank you in advance.
Old 07-28-2015, 12:49 AM #9
It was $136, but the belt itself wasn't too expensive. Mostly the labor. If you know a good place or have connections probably could be way less.
Old 07-28-2015, 12:52 AM #10
Oh okay, I could probably take it apart and replace it myself hahaha, thank you for your reply and I will first take it to a shop for a free estimate and for them to tell me if that's what is wrong with it!
Old 07-28-2015, 12:55 AM #11
Awesome. They couldn't even do a normal A/C check BECAUSE of the belt, and that's all the actual problem was.
Old 07-28-2015, 01:32 AM #12
Take a look in my build thread. I am in the process of swapping my fan pulley bracket and removing the accessory belts was one of the things I had to do. I did a write up and took pictures! If it's the belt I think it is then I didn't get a picture but I promise you can figure it out as soon as you look up under the front of the truck. It's just an adjuster and pivot bolt, I even circled the correct bolts in the pictures I did take. Let me know if you have any questions or concerns and I'll grab some more pictures for you.
Old 07-28-2015, 02:22 AM #13
grumpin's Avatar
grumpin grumpin is offline
grumpin is on a distinguished road
grumpin's Avatar
On my 87 runner, I jumpered the low pressure switch to get the compressor to engage. Just long enough to confirm the clutch worked. On mine the switch is under the dash. Then found my leak (the condenser by visually inspecting everything), replaced it and the receiver/dryer, all the o-rings and added oil and refrigerant after evacuating the system with a pump and gauges. Just adding refrigerant most likely isn't going to solve the problem. Might have to find a good A/C shop.
1987 4Runner 22RE, 5 Spd
grumpin is offline   Reply With QuoteReply With Quote
Old 07-30-2015, 09:34 PM #14
Hello, a quick update here. I went and bough all three new belts I'm in a position which I do not understand, I have a picture (see below) I have removed all bolts how do I pull this out? I need to remove the Fan thing in front of it, because I was stupid enough to get my wrench stuck in there.... Now there is no way I can get it out without me taking that thing out which I have no idea how to do? Is it stuck or is there anything else holding it except the four bolts I have taken off?
HERE IS THE IMAGE! Current problem!
Old 07-31-2015, 12:42 PM #15
Please someone help me out? I took out the four bolts which I didn't have to but my instrument got stuck on there so now I can't remove it without removing the following up there? How do I pull this out? Is it stuck or something? I don't see anything else holding it? Maybe a center bolt but it does not seem to have one! Please help me out here!
Traded the T4R for a MDX Advance rotorhead6 5th gen T4Rs 57 02-03-2022 12:13 PM
Never Ever Ever Buy A CoilPack from Advance BamaDrewski 3rd gen T4Rs 2 05-23-2015 04:10 PM
Lifting soon. Thanks in advance. kenlainpro_ 4th Gen T4Rs 2 07-08-2014 03:32 PM
Help on my rig set up. Thanks in advance. Bloody14KDSS 5th gen T4Rs 9 01-05-2014 05:14 PM
government advance already spent? Ron Helmuth 3rd gen T4Rs 47 01-29-2008 05:58 PM
