Old 08-04-2015, 11:50 AM #1
cferry7's Avatar
cferry7 cferry7 is offline
cferry7 is on a distinguished road
cferry7's Avatar
Rear Brake Backing Plate Sheild Rebuild
1989 Toyota Pickup DLX 22RE , 2.4 L , 4WD
Rear Brake Backing Plate Outer Diameter Dust Sheild Rebuild ------- Pictorial's
To be continued .....
Rear Brake Backing Plate Sheild Rebuild-img_20150715_120350672-jpg  Rear Brake Backing Plate Sheild Rebuild-img_20150719_100050981-jpg
cferry7 is offline   Reply With QuoteReply With Quote
Old 08-04-2015, 04:33 PM #2
cferry7's Avatar
cferry7's Avatar
Fabricate Dust Shield
1) Fabricate Brake Backing Plate Outer Dust Shield ----
a. 1/32 inch thickness Steel Sheet
b. Cut 2 1/4 inch strip of this Stainless Steel
Sheet
c. Shaped this Strip into Circular shape
d. Cut trapezoidal shape slits lengthwise
into Steel Strip up to the 1/2
inch depth.
e. Bend trapezoidal and trianglular shape
cuts of Stainless Steel to form circular
Shield consisting of the 1/2 inch outer
edge for shield.
To be continued . . .
Rear Brake Backing Plate Sheild Rebuild-img_20150804_093752163-jpg  Rear Brake Backing Plate Sheild Rebuild-img_20150804_093815840-jpg
Old 08-04-2015, 04:43 PM #3
cferry7's Avatar
cferry7's Avatar
Backing Plate -
Backing Plate - with Rusted Outer diameter Dust Shield Removed ---
Rear Brake Backing Plate Sheild Rebuild-img_20150804_120955602-jpg  Rear Brake Backing Plate Sheild Rebuild-img_20150804_121012126-jpg
Old 08-04-2015, 07:10 PM #4
cferry7's Avatar
cferry7's Avatar
Cut of Stainless Steel Strip
Cutting of Stainless Steel Strip
Black & Decker Jig Saw - All Metal Blade
Painting "new" Dust Shield
Rustoleum Flat Black spray paint
Rear Brake Backing Plate Sheild Rebuild-img_20150802_154730575-jpg  Rear Brake Backing Plate Sheild Rebuild-img_20150804_120031368-jpg
Old 08-05-2015, 11:06 AM #5
cferry7's Avatar
cferry7's Avatar
Paint, Begin Attaching
Paint and Beginning to Attach Shield to Backing Plate.
1) JB Weld, Dewalt Clamps
2) Glue in individual stages. Two days in advance I Form Fitted the Shield - Small Shaping adjustments with Ball Peen hammer.
3) Individual JB Weld Stages counterclockwise to continue to shape the Steel Strip.
4) Allow each stage to dry at least 4 - 5 hours
before next Glue attachment spot. At least 24 hour dry time before functional test.
Rear Brake Backing Plate Sheild Rebuild-img_20150804_120107581-jpg  Rear Brake Backing Plate Sheild Rebuild-img_20150804_173910660-jpg  Rear Brake Backing Plate Sheild Rebuild-img_20150804_180233552-jpg
Old 11-26-2015, 05:49 PM #6
cferry7's Avatar
cferry7's Avatar
Completed
Completed Final JB Weld Touch Up on Left Rear Brake Drum Dust Shield Fabrication.
Pictures added to a new Picture Album within T4R Forum Photo Gallery.
brake noise when backing jhlscut 4th Gen T4Rs 8 01-27-2015 04:08 PM
Rust rot on rear drum backing plate. Suggestions? hamiltonshmamilton 3rd gen T4Rs 2 09-14-2014 11:39 PM
Rear axle/Drum backing plate replacement jsmith7 3rd gen T4Rs 4 04-15-2014 02:42 PM
Sound from brakes when backing up after parking brake release? DennisW 5th gen T4Rs 0 09-16-2010 02:05 PM
Loud brake noise when backing up? mybenje 4th Gen T4Rs 2 05-29-2009 10:28 AM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
