Old 05-25-2020, 04:20 PM #436
djelectron's Avatar
djelectron djelectron is offline
Real Name: Duane
djelectron is on a distinguished road
djelectron's Avatar
Real Name: Duane
Originally Posted by Dropzone View Post
Did a little revamp on the roof rack. Using 8020 makes an old fart feel like kid with an erector set again.
Version 1.0 was only about 34" wide and was very low to the roof. That was fine but difficult to get bungee cords/rope around a crossbar. It was also a bit narrow.
Version 2.0 is 38" wide, 72" longand sits about about 1" above the roof line. May not seem like much but will be better in the long run.
Passenger side pic is old narrow rack
Driver side is the wider rack
I have all the 8020 10 series parts and two 1/4" alu plates in my cart for my own new roof rack, but I'm hung up on exactly how to manage the small angle on the side of the roof. There are some 8020 hinge pieces available, but I'm unsure as to their strength. Looks like you have some brackets as risers, but it's unclear what's happening behind the side plate. How are you managing that little bit of angle? Thanks again!
1994 Toyota 4Runner SR5 4WD 3.Slow Auto
All mods *were* listed in my garage but now I'm mid way through a mini-restoration / overland build.
Setting out on a big trip April 1st, 2024! More to follow soon!
PM me for link to 94 Factory Service & Electrical Manual
djelectron is offline   Reply With QuoteReply With Quote
Old 06-03-2020, 09:00 PM #437
Dropzone's Avatar
Dropzone Dropzone is offline
Dropzone is a jewel in the rough Dropzone is a jewel in the rough Dropzone is a jewel in the rough
Dropzone's Avatar
sorry for the slow response, been busy with work and a couple of big back yard projects, i will get a picture of what i did for that tomorrow.
1994 4Runner AKA: Project Recycle
@503dropzone on IG
Dropzone is offline   Reply With QuoteReply With Quote
Old 06-04-2020, 01:10 AM #438
djelectron's Avatar
Real Name: Duane
djelectron's Avatar
Real Name: Duane
No rush and no problem! Always appreciate your help when I've reached out. I've been super busy myself and glad to finally have this new rack underway. I've been wanting to get that basket off the factory rails and crossbars for forever and finally did it last weekend. Had a little cleaning (a lot, actually) to do up there afterwards...
Old 06-04-2020, 10:50 AM #439
VeryWell VeryWell is offline
VeryWell is on a distinguished road
I know it’s been a while since you posted about the spare tire swingout but how is it holding up? My boss and I are going over how we’ll mount it and he’s skeptical about bolting straight to the body with the bracket behind it. I personally don’t have any qualms about it since I believe they were bolted that way with a brace behind them from the factory but I figured I’d ask. Congrats on the shed btw, I’ve been following the progress on the Gram.
Stock 95 with the 3.slo. Fighting the urge to swap the 3.4
VeryWell is offline   Reply With QuoteReply With Quote
Old 06-04-2020, 01:56 PM #440
Dropzone's Avatar
Dropzone's Avatar
I used some 8020 brackets on each end, I elongated the outer hole(hence the bigger washer) slightly to allow for the curve. If you go this route be sure to make left and right side brackets. I ended up with a couple of extras before I realized my mistake.
Hope that makes sense and the pics help
Dropzone's 1994 4Runner Expedition/Overland Build-screenshot_20200604-105141_gallery-jpg  Dropzone's 1994 4Runner Expedition/Overland Build-screenshot_20200604-104157_gallery-jpg
@503dropzone on IG
Old 06-04-2020, 02:05 PM #441
Dropzone's Avatar
Dropzone's Avatar
It seems to be holding up great with the weight of the 35 hanging off there. I didn't get any pictures of it while I was putting it together but I did bend some flat stock to fit both the upper and lower mounts that fit inside the inner body. They aren't tied together like the factor inner bracket .
It's a tight fit getting the nuts on the inside. I still have a 3/4" wrench wedged in there I couldn't get out when I was done.
Thanks on the shed, hope to get most of it wrapped up the next few days. It's gonna help free up some garage space. Once it is done I will concentrate on getting the dual case to auto transmission conversion done
@503dropzone on IG
Old 06-04-2020, 02:17 PM #442
Awesome thanks. Looking forward to seeing it back on the trails
Old 06-05-2020, 07:52 AM #443
djelectron's Avatar
Real Name: Duane
djelectron's Avatar
Real Name: Duane
That makes perfect sense and is exactly what I was hoping to see. Thank you sir!!
Old 10-23-2020, 03:59 PM #444
Dropzone's Avatar
Dropzone's Avatar
Well after sitting for way too long this thing is gonna head down next week to Northwest Toys LLC outside of Salem to have Don finish up my dual case install.
Between work, life and some knee issues blah blah I just can't get to this thing. He is gonna finish up the valve body, install duals behind the a340.
Finally get to use the winch in this thing to pull it up on the trailer!
Also pulled out my left rear cargo storage. We are getting another husky pup so figured with the drawer unit I made I'll have enough storage space and the two dogs will need more room in the back.
Dropzone's 1994 4Runner Expedition/Overland Build-screenshot_20201023-125417_gallery-jpg  Dropzone's 1994 4Runner Expedition/Overland Build-20201023_125434-jpg  Dropzone's 1994 4Runner Expedition/Overland Build-20201023_125456-jpg  Dropzone's 1994 4Runner Expedition/Overland Build-screenshot_20201023-125810_gallery-jpg
@503dropzone on IG
Old 10-27-2020, 04:33 AM #445
4RunnerSafari's Avatar
4RunnerSafari 4RunnerSafari is offline
4RunnerSafari will become famous soon enough 4RunnerSafari will become famous soon enough
Looking good Dropzone's 1994 4Runner Expedition/Overland Build
Sent fra min WAS-LX1 via Tapatalk
4RunnerSafari is offline   Reply With QuoteReply With Quote
Old 10-28-2020, 02:16 PM #446
Hyde802's Avatar
Hyde802 Hyde802 is offline
Real Name: Caleb
Hyde802 has a spectacular aura about Hyde802 has a spectacular aura about
Hyde802's Avatar
Real Name: Caleb
Excellent!!
92 ExtraCab on 38s: built for go, not for show
88 4runner: Solid axle, doubler, fun stuff
IG: rattlewagon
Its all about the parts you break, and the friends you make.
Hyde802 is offline   Reply With QuoteReply With Quote
Old 11-07-2020, 03:20 PM #447
Dropzone's Avatar
Dropzone's Avatar
Finally got to use the winch on the 4runner.
I caved and called my friend Don at Northwest Toys in Monmouth. He is tackling my halfway done dual case behind the a340 swap. Truck has been sitting for almost 2 years..it was time to see professional help.
also ordered a 3" hole saw
so I can see if a snorkel for a hilux will fit a 4runner
it will probably be 2-3 weeks before i get the 4runner back but it will be worth the wait..
will have to install the seats and figure the center console around the triple sticks.
also gonna have to get it through emissions and get tags.
I was really burned out on this thing but am getting motivated to drive it again and hit some winter trail runs..been way to long
Dropzone's 1994 4Runner Expedition/Overland Build-img_20201106_193734_939-jpg  Dropzone's 1994 4Runner Expedition/Overland Build-img_20201106_091425_568-jpg  Dropzone's 1994 4Runner Expedition/Overland Build-img_20201107_071626_320-jpg  Dropzone's 1994 4Runner Expedition/Overland Build-img_20201107_071626_318-jpg
@503dropzone on IG
Old 11-29-2020, 07:58 PM #448
Dropzone's Avatar
Dropzone's Avatar
dug through my driveshaft collection so i can drop them off next week @1UZrunner 's shop.
Fingers are crossed that the two rear d/s I had made for my old 81 Trekker might work. one has a CV built in and it it would be nice to have a spare for trail runs.
Time will tell
Dropzone's 1994 4Runner Expedition/Overland Build-img_20201125_144424_830-jpg
@503dropzone on IG
Old 12-12-2020, 11:51 PM #449
Dropzone's Avatar
Dropzone's Avatar
Well as many of you know I have a fascination with lights. I was looking for a set of small quality lights for to use for auxiliary back up lights.
That search let me to Rigid Ignites. A lot of light in a small package.
Got them in not knowing they used a go pro style mount. So that led to ordering a set of magnetic mounts.
Voila- magnetic camp lights
Dropzone's 1994 4Runner Expedition/Overland Build-img_20201212_180428_158-jpg  Dropzone's 1994 4Runner Expedition/Overland Build-img_20201212_180428_157-jpg  Dropzone's 1994 4Runner Expedition/Overland Build-img_20201212_180428_155-jpg
@503dropzone on IG
Old 12-13-2020, 07:30 AM #450
hmartin99's Avatar
hmartin99 hmartin99 is offline
hmartin99 is on a distinguished road
hmartin99's Avatar
I read your whole thread here tonight, looks good. You definitely have a fascination with lights and gear that I admire as someone who collects a bunch of random stuff I may never need but is nice to have. I'm finally getting back around to 4Runners after a few years bouncing from Jeep to Jeep and you've definitely given me some ideas on what to do with mine eventually lol
'92 Toyota 4Runner SR5 4x4
3.0l V6 5-Speed Manual trans.
Currently Non-operational
hmartin99 is offline   Reply With QuoteReply With Quote
Expedition Overland feat. 5th gen 4Runners - Central American Expedition - Episodes jicko 5th gen T4Rs 219 01-26-2018 03:42 AM
Detailed list of items/mods on Expedition Overland's 4Runner jicko 5th gen T4Rs 42 01-01-2018 08:35 PM
Expedition Overland's brand new 4Runner's Toymaker General Discussions 1 07-27-2015 02:31 AM
Brian's Build Journal - All Purpose, Overland/Expedition 4Runner TheFriZ 3rd gen T4Rs 58 10-10-2014 08:59 AM
