Old 10-10-2015, 04:44 AM #16
Dropzone's Avatar
Dropzone Dropzone is offline
Dropzone is a jewel in the rough Dropzone is a jewel in the rough Dropzone is a jewel in the rough
Dropzone's Avatar
Suspension Price List
here are some of the prices I have come up with for doing my SAS and convert to rear leaf springs
front suspension:
Front Spring Hanger Options-
Traditional/commonly used Trail-gear that seems to had 1.5-2" to a lift
front spring hanger $95 normal t-g
Trail-Gear Front Toyota Leaf Spring Hanger w/Bolts and Bushings (110045-1-KIT)
Low range off road low profile front spring hanger $90 - this is the one I will probably go with
Low Profile Front Toyota Leaf Spring Hanger w/Bolts and Bushings by Low Range Off Road (TSP-FSH-LR)
Details
If you are looking for a front spring hanger for your Toyota, this is the best engineered front spring hanger available today. Why? We have found that with excessive off road use, the front hanger can be bashed in many times. The hanger itself usually holds up, but the factory Toyota frame doesnt. The amount of surface to weld on many hangers allows the frame to tear out and roll under the vehicle, especially on Tacoma's.
This hanger resolves these issues by increasing the amount of surface area to weld.
Its also designed to be "Low Profile," meaning that it does not give as much lift as other hangers on the market, by over an inch. That means that your "3 inch springs" will be closer to the 3" lift you are expecting. Your "4 inch springs" will give you closer to the 4" lift you were expecting......and down the line.
FAQ:
Question: Why won't my factory spring hangers work with new longer springs?
Answer: Many aftermarket springs for the Toyota are increased length over stock. In order to allow for maximum flex, they have to use a longer shackle. When you use a longer shackle, your caster is affected. Caster is the forward and rearward tilt of the steering axis from true vertical. If the caster is not correct, your steering wheel will not return to center and your handling will greatly be affected. This hanger allows for: Longer Springs, a "drop" of the front of the spring so that slightly longer shackles can be used in the rear of the front spring while correcting caster so that your vehicle handles correctly.
Question: What front springs will work with this hanger?
Answer: OEM and Aftermarket front springs ranging from OEM length to 47" Long. You will need to weld this hanger in position so as to have a correct shackle angle in the rear of the front spring. It will also assist when doing the common "Rears Up Front" swap.
front shackle frame jig $27
Toyota Solid Axle Swap (SAS) Frame Tubes & Jigs
front shock hoops $65 - if I can't salvage my current set off the Trekker
Inchworm Gear Automatic Transmission Adapter Kit (TCASE-IW-ATAK)
Front bump stops $45
Toyota Bumpstop and Extensions Package Kit
IFS Steering Box mount $45 (not needed)
Toyota IFS Steering Box Mount
Found some cool front frame plates that I will probably go with from
https://www.facebook.com/Xofab?fref=ts
Extreme Options Offroad & Fabrication 4x4 Enumclaw WA | Fabrication Enumclaw | Welding Services Enumclaw
They have a frame plate with an IFS box mount built in:
priced cheap around $50
and a frame support for where the frame is drilled for the rear spring shackle:
front suspension: ~$225-280
rear suspension:
rear upper shock mount $60
Toyota Rear Upper Shock Mount (TSP-RUSM)
rear spring mount hanger (front ) $40
Welded Toyota Leaf Spring Hangers
rear spring shackle mount $45
Toyota Rear Leaf Spring Shackle Mounts (110027-1-KIT)
rear bump stops $45
rear suspension $190
so for about $500 i will have a pretty decent but partially recycled suspension
1994 4Runner AKA: Project Recycle
@503dropzone on IG
Dropzone is offline   Reply With QuoteReply With Quote
Old 10-12-2015, 10:02 PM #17
Dropzone's Avatar
Dropzone's Avatar
Picked up a set of half doors today:hillbill:
Stripped it pretty quick have a nice Crack free dash and other misc stuff
@503dropzone on IG
Old 10-12-2015, 10:14 PM #18
v_man's Avatar
v_man v_man is offline
v_man is on a distinguished road
v_man's Avatar
I would recommend using those front frame rail enforcement plates, $39.99 is a great deal too, think I paid $80.
By the time you hang a front bumper and wench off the front end, and with turning big tire related stress,
you are really asking your stock frame to do a lot.
Also , gusset and reinforce the heck out of your front shock hangers if you go hoops, ask me how I found out...
before...
after...
v_man is offline   Reply With QuoteReply With Quote
Old 10-15-2015, 07:48 AM #19
Dropzone's Avatar
Dropzone's Avatar
For shock mounts, I may go with Ford Shock towers..
i will definitely be installing the frame reinforcement plates.
I ran into an issue on my 81 where the frame was slightly cracked due to the front spring hanger placing stress on the end of the frame,
I made some brackets like this
ugly welds, but have held well.
I will add something similar to the 4Runner
I think going with the low profile Low Range Off Road front spring hanger will help eliminate some of the stress.
I also really like how the Extreme Off Road Options frame plate has the Steering box mount integrated, that should help reduce stress too.
@503dropzone on IG
Old 10-23-2015, 11:45 PM #20
Dropzone's Avatar
Dropzone's Avatar
started ordering parts yesterday for the SAS.
Ordered this from Extreme Options Fab Thursday morning, had it Friday afternoon. I will be ordering stuff from them again
the integrated steering box mount is a nice touch
rest of the stuff should be here monday from LROR
@503dropzone on IG
Old 11-08-2015, 07:48 PM #21
Dropzone's Avatar
Dropzone's Avatar
Decided to take the easy route to clean up a set of free headlight housings
@503dropzone on IG
Old 11-09-2015, 02:13 PM #22
Scalded_Dawg's Avatar
Scalded_Dawg Scalded_Dawg is offline
Real Name: Brent
Scalded_Dawg is on a distinguished road
Real Name: Brent
Another red 2nd gen... WOOT!
One day we will rule the classics section!
Great info on your SAS... I'm in the researching parts phase as well.
That Trekker "was" SICK!!! Would love to find one of those to restore and just use as a daily.
>>> The Expo Dawg Build <<< (SOLD)
New hotness: '04 V8 Ltd (No Build Page)
Scalded_Dawg is offline   Reply With QuoteReply With Quote
Old 11-09-2015, 08:37 PM #23
Dropzone's Avatar
Dropzone's Avatar
Thank you Sir
Hopefully you are correct, but for some reason I am still getting use to the idea of a 94 being a classic
Found some high power emergency vehicle LED's I was gonna use on the Trekker..
Thinking about mounting them on the mirrors
Going to also try a $15 ebay experiment and hopefully add heated mirrors to this hunk
@503dropzone on IG
Old 11-17-2015, 12:46 AM #24
Dropzone's Avatar
Dropzone's Avatar
2nd Gen 4Runner Heated Mirrors
Started on my heated mirror experiment :
$15 heated inserts from eBay
First step was to get the mirror apart, there is a screw on the bottom of the mirror that will allow you to get the motor assembly and mirror out from the housing
Assemble your chosen weapons:
Is this case a wide putty knife and plastic pry bars worked for separate the mirror from the mount
I trimmed the heated insert slightly
No pics but I drilled a couple of holes in the mount to allow the power wires for the heated insert power and remountEd the mirror with some 3M tape
There is a small screw you can remove disassemble the the pivot point on the mount
Remove that screw in addition to the 3 bigger screws on the bottom of the housing, this will allow access to feed your wires through.
I went ahead and added a high power LED for a signal
Should be pretty bright
So I threw the mirror in the freezer with some water on it for a couple of hours and went to grab some dinner with friends.
Hooked up the battery charger set to two amps
After about 3-4 minutes
I have an extra defroster switch that I might use or just wire them into the rear defrost circuit.
Am happy for an experiment they seem to work OK
@503dropzone on IG
Old 12-04-2015, 07:44 PM #25
Notoyz Notoyz is offline
Notoyz is on a distinguished road
Nice build but I'm really digging the Trekker
Notoyz is offline   Reply With QuoteReply With Quote
Old 12-10-2015, 07:43 PM #26
_ExpeditionMan _ExpeditionMan is offline
_ExpeditionMan is on a distinguished road
This is going to look great once completed.
_ExpeditionMan is offline   Reply With QuoteReply With Quote
Old 01-27-2016, 09:22 PM #27
Dropzone's Avatar
Dropzone's Avatar
Thanks. The Trekker has been a fun project, almost part of the family.
Thanks, I wish it was going a little faster..
Haven't really had much time to work on this project lately.
Recently switched shifts to day shift, after almost 15 years on nights my body is having a heck of a time adjusting.
Lame update but made a little headway. I had taken the running boards off and screwed up thinking I had gotten everything removed from the mounts and accidently ripped off the d/s rear quarter guard.
Ordered a pack of the moulding clips off ebay.
4runner moulding clips
Cleaned up the wheel arch so some 3M tape would stick for the next few years
Between the 3m tape and the replacement moulding clips it fit like a charm
@503dropzone on IG
Old 01-28-2016, 10:47 AM #28
BigRyan1986's Avatar
BigRyan1986 BigRyan1986 is offline
Real Name: Ryan O'Dell
BigRyan1986 is an unknown quantity at this point
My neighbors boggers removed those for me about 5 mins after hitting the trails lol
4" pro comp lift, pro comp ES9000 shocks, homemade sliders, tinted rear windows, more mods to come
http://www.toyota-4runner.org/classi...d-big-red.html my build
BigRyan1986 is offline   Reply With QuoteReply With Quote
Old 02-11-2016, 09:51 PM #29
Dropzone's Avatar
Dropzone's Avatar
I got this idea from @the great him when I was snagging some parts from him.
Quick 15 minute project to get a Noco Genius charger install. Trickle charger will help keep the battery maintained since the 4runner sits so long.
Added the connector through the grill (grill will be replaced down the road)
Easy connection
The charger has settings for different batteries, gives you battery status.
@503dropzone on IG
Old 02-17-2016, 02:23 AM #30
Dropzone's Avatar
Dropzone's Avatar
So today was sort of like Christmas for me when I got home from work. I scored a Ram Tablet Mount on eBay for 20% of what they go for new. This one is used but functions awesome. It is missing the right side retainer but the spring loaded tongs hold the tablet well.
The dual suction mounts are extremely secure even with a 10" Tablet.
Even my blind old Vision balls can see the map.
Nice thing is it is easily moved from vehicle to vehicle
@503dropzone on IG
Expedition Overland feat. 5th gen 4Runners - Central American Expedition - Episodes jicko 5th gen T4Rs 219 01-26-2018 03:42 AM
Detailed list of items/mods on Expedition Overland's 4Runner jicko 5th gen T4Rs 42 01-01-2018 08:35 PM
Expedition Overland's brand new 4Runner's Toymaker General Discussions 1 07-27-2015 02:31 AM
Brian's Build Journal - All Purpose, Overland/Expedition 4Runner TheFriZ 3rd gen T4Rs 58 10-10-2014 08:59 AM
