Old 01-28-2017, 11:06 PM #151
Dropzone's Avatar
Dropzone Dropzone is offline
Dropzone is a jewel in the rough Dropzone is a jewel in the rough Dropzone is a jewel in the rough
Dropzone's Avatar
I have been having intermittent issues with the left rear window so I ordered a replacement regulator a few months ago. Tear the door apart to find out they send a passenger side regulator..
And too late to send it back..
So with that being a bust I started to tackle the tailgate. I could roll down the window but not open the tailgate.
This of course is a major PITA.
Started taking it apart, I was able to get it unlocked and the tailgate down.
Digging around I found a small broken spring that goes being the lock release pivot.
Ran out of daylight so threw it back together. Plan is to replace the broken spring with a coil spring.
Upside I can get the tailgate open now
1994 4Runner AKA: Project Recycle
@503dropzone on IG
Dropzone is offline   Reply With QuoteReply With Quote
Old 01-29-2017, 05:34 PM #152
HanginInUtah's Avatar
HanginInUtah HanginInUtah is offline
Real Name: Ben
HanginInUtah will become famous soon enough HanginInUtah will become famous soon enough
Real Name: Ben
I would assume you've checked the wires for that one? Reason I say, is that I actually had a front right window issue that I figured was the regulator. I actually found two of them (separate trips) at the wrecking yard, and after all of that it was the wires where they go through the jamb. Wires were old, cracked, and open.
Best tool I ever bought for electrical is a Power Probe. They're a bit expensive, but that way you can put 12 volts to the motor to be sure it's good or bad. And my experience with intermittent windows is usually not the motor.
1992 3.0 Auto - First Project -Sold-
1995 3.0 Manual - Second Project - Sold-
2018 TRD ORP Barcelona Red
HanginInUtah is offline   Reply With QuoteReply With Quote
Old 01-30-2017, 10:29 AM #153
Dropzone's Avatar
Dropzone's Avatar
I like that Power Probe...B-day is coming up I may ask the missus for one.
I have power to both switches. Continuity seems good. I will pull the wiring loom cover and inspect the wires. I may break out my extra door from storage and see if it works and swap the regulator from that one.
I didn't wanna go that route so I would still have a complete door
@503dropzone on IG
Old 01-31-2017, 12:24 PM #154
Real Name: Ben
Real Name: Ben
Check the operation as you yank on the harness. That's about all it should take. And, it may very well be the regulator. I'm just a lot more suspicious of the wiring on these older rides!
Old 02-01-2017, 04:32 PM #155
Dropzone's Avatar
Dropzone's Avatar
I agree it could be wiring. That is one reason I retired my Trekker, the wiring had been hacked by so many previous owner. That and a cracked frame that I had patched a couple of times let to this 'new' project. I only paid $400 for it so a few issues were to be expected.
@503dropzone on IG
Old 02-04-2017, 09:14 PM #156
Dropzone's Avatar
Dropzone's Avatar
After 23 years the factory stripes were faded and chips, especially the passenger side.
I had tried heat gun and goof off when I saw a thread some where about a drill powered adhesive remover. Watch some video on YouTube and decided to order one for $10 off amazon
After a couple of hours it looked like this
Driver side before
Passenger side before
Testing it, makes a poop ton of dust
About 2 or 3 hours I was done
Pretty happy with the outcome for $10 and an afternoon
@503dropzone on IG
Old 02-23-2017, 07:45 PM #157
Dropzone's Avatar
Dropzone's Avatar
Well looks like Project Recycle is gonna take a major step forward in the next few weeks
Just got off the phone with @1UZrunner and talked with him about doing the SAS on this POS, the truck will be heading down his way to have him work his magic and fix it so some 35's can get stuffed into the fenderwells...pretty stoked.
This thing will actually be able to hit some trails in the near future.
@503dropzone on IG
Old 02-26-2017, 10:48 PM #158
Dropzone's Avatar
Dropzone's Avatar
forgot that I am gonna need to swap oil pans.
this is the only list I can find so far (from a 15 year old post on pirate, with 15 year old prices)
Oil Pan $125 --auto zone $120 Best Oil Pan Parts for Cars, Trucks & SUVs
12101-65030
other stuff looks I will order from
Plate (windage tray/baffle) $30
12122-62040
Strainer (pickup tube) $30
15104-62060
Gasket (for pickup tube) $2-3
15147-62020
Dipstick $15
15301-62060
Guide Tube $20
11452-62060
Guide Tube Union $5
9040510033
looking at prices from a few places online it looks like i can get the parts for about $250...hopefully order them in the next couple of days
@503dropzone on IG
Old 03-02-2017, 07:02 PM #159
Dropzone's Avatar
Dropzone's Avatar
This should give the front end a little better protection and give me a place to stuff the winch i got for Christmas 3 years ago
@503dropzone on IG
Old 03-03-2017, 08:34 PM #160
Dropzone's Avatar
Dropzone's Avatar
Swapped bumpers
Stock
Trail Gear Bumper
Need to figure out some different turn signals
@503dropzone on IG
Old 03-08-2017, 06:25 PM #161
Dropzone's Avatar
Dropzone's Avatar
got the 3.0 2WD oil pan parts needed for the SAS, one step closer
I looked at a few discount toyota sites and they were all priced very close to each other.
ended up getting them from https://www.toyotapartsdeal.com/
ordered on March 1st, had them by 3/6..
@503dropzone on IG
Old 03-10-2017, 09:32 PM #162
Dropzone's Avatar
Dropzone's Avatar
After 35 years under the 81 it was time to get rid of some rust and road grime.
About to start round 2 under the 4runner
@503dropzone on IG
Old 03-15-2017, 09:25 PM #163
Dropzone's Avatar
Dropzone's Avatar
Dropped off a pile of front end parts with 1UZrunner this afternoon. He is gonna get the axle.back together and do the SAS
@503dropzone on IG
Old 03-16-2017, 03:43 PM #164
Dropzone's Avatar
Dropzone's Avatar
The sun showed up today so decided to try to clean up the 4" Trail Gear springs from the Trekker that are being recycled and thrown in the 4runner. Wasn't really happy with how high it sat so gonna give pulling the two smaller springs a shot to see if it ends up lowering the 4runner a little
@503dropzone on IG
Old 03-17-2017, 09:27 PM #165
Dropzone's Avatar
Dropzone's Avatar
It was sort of hard to find a frame brace for a 2nd Gen but Northwest Trail Innovations had a nice one 1/8" thicker than the other one I found, 3/8" thick should give a bit of beef
This will help the frame survive winch duties
@503dropzone on IG
Expedition Overland feat. 5th gen 4Runners - Central American Expedition - Episodes jicko 5th gen T4Rs 219 01-26-2018 03:42 AM
Detailed list of items/mods on Expedition Overland's 4Runner jicko 5th gen T4Rs 42 01-01-2018 08:35 PM
Expedition Overland's brand new 4Runner's Toymaker General Discussions 1 07-27-2015 02:31 AM
Brian's Build Journal - All Purpose, Overland/Expedition 4Runner TheFriZ 3rd gen T4Rs 58 10-10-2014 08:59 AM
