09-17-2015, 11:31 AM
Real Name: Erin
Real Name: Erin
Snow chains??
Hey everybody! Yes tis a newb question, however living in NM I never needed chains. WV is a different story, coming into winter, the dirt road to my place is steep in places and people slide into the trees/ravine all the time.. but they also don't have a 4runner ;)
But for those times of icy, slick, below 10 degree conditions...
Are chains all the same? The price range is freakin ridiculous! I mean $50 for a pair up to over $200??
So my question is... does it matter what brand/type of chains I get? I'm going to get a set of 4, so I want it to be worth it but also not breakin' the budget.
Any other info on chains and how to keep them in good shape would be appreciated, also!
Thanks ^_^
'87 4Runner- Reman 22RE auto, custom exhaust, 4" skyjacker soft springs out back with 3" combined spacer/t-bar lift up front, 5.29s w/ rear Grizzly locker, skinny BFG 33s and Bilsteins all around
'88 Chevy 1 ton dually crewcab- Rebuilt 454, cowl induction hood
09-17-2015, 04:05 PM
Real Name: Bruce
Real Name: Bruce
You might want to check out RUD Grip 4x4 chains. I don't have experience using them myself, but Bill Burke demonstrated them in his Getting Unstuck video and they seem like the business.
You can read more about them here:
http://www.amazon.com/RUD-Chains-Pic.../dp/B00HKV17IG
1985 4Runner, 1984 pickup, 1995 Tacoma, 1997 Land Cruiser
09-17-2015, 04:58 PM
Thanks ^_^
I expect that some cheap cable "chains" would work out nicely. they really should only be used when the conditions are very bad. ICE mostly.
cables wont last as long as chains, but I expect they wont be seeing a ton of use. a good set of cables, with minimal use could last many years.
im not sure how long, or steep the road you are referring to is, but just chaining up the front for THAT trip would likely get you safely down the road, and save a bunch of time/hassle.
1985 pickup : EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5 : 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited : stock. Build Thread YouTube Channel
09-17-2015, 05:27 PM
Thanks ^_^
Here's your average snowfall City of Spencer, WV - Demographics
I've lived here since 2000, and have driven in everything - everywhere. Including Snowshoe WV, and Canaan Valley during the worst conditions to go snow skiing. I have never used chains/cables, but I have run BFG All Terrain tires, and they work GREAT in all weather conditions.
Chains --- Blech!
"People sometimes mistake their own shortcomings for those of society and to want to fix it because they don't know how to fix themselves."
Sir Isaac Asimov
Honey Badger Build Thread
09-17-2015, 05:46 PM
Depending where you're at and how bad chains, cables, or studded tires can be required. I've never used cables. I have had to use chains before. I normally get the cheap Wal-Mart ones and I've had them last a long time. I recommend the rubber chain tighteners as they help a lot. Always felt it's best to have them and not need them then need them and not have them.
Some people have a set of winner tires they put on with studs. Never had that much $. Studs are nice. Had them on a car when I was stationed in AK. Not as good as chains though.
Keep in mind you can only do 25-30 mph with chains on. You can try to go faster but you risk them coming off and destroying stuff. Practice putting them on before it snows. Keep a pair of gloves with the chains. Ice, metal, and skin don’t mix well when it's cold ;)
09-18-2015, 01:08 AM
Originally Posted by nevada
... they really should only be used when the conditions are very bad. ICE mostly.
... but just chaining up the front for THAT trip would likely get you safely down the road, and save a bunch of time/hassle.
...I recommend the rubber chain tighteners as they help a lot. Always felt it's best to have them and not need them then need them and not have them.
Some people have a set of winner tires they put on with studs. ...
...Keep a pair of gloves with the chains. Ice, metal, and skin don’t mix well when it's cold ;)
We don't see much ice here on California mountains but I think that's the only time you'd really need chains/cables IF you have 4WD and All-terrain / MT tires.
Agree with cable/chain on front ONLY when on 4WD. This way you have improved traction on your drive and steering wheels. I suspect there would be too much stress on transmission/wheels if all 4 tires have chains.
Security Chain Company is my favorite manufacturer. Cables are easy to install and already come with tighteners.
Lots of good used ones on craig's list. I always have my cables in the truck during winter months so I won't forget them when I go to the mountains. Sucks to be turned around when not prepared - or be ripped off by rentals.
Make sure you practice installing in the warmth and comfort of your garage; I once watched installation instructions for my friend's un-used chin melt under falling snow in Big Bear. Never got that chain installed - LOL!
86 4Runner, 22R-Eliable, 5-Speed Manual, dlx. WHAT'S YOURS?
If you want us to help from afar please let us see, hear, feel what you're dealing with.
A picture paints a thousand words.
Toyota components are bullet-proof. Issues often arise from poor wiring, assembly and/or maintenance. Suspect those first.
Next only to our senses, the multi-meter is the most important electrical diagnostic tool. Spend $6 at Harbor Freight or $$$ blindly replacing parts.
09-18-2015, 01:56 AM
Well up north here I swear by studded winter/snow tires. Have Nokian Hakka 7 SUV's on my 4Runner and the newer and better Hakka 8's on my Yaris. From snow, to 25 below polished hard pack, to freezing rain; never been let down.
This is my last season for the older 7's and in fall 2016 on to these which I would recommend (or maybe they release 9's):
Nokian Hakkapeliitta 8 SUV
There are almost no conceivable conditions where you would need to chain these up on a 4WD vehicle. Perhaps a mountain pass with a foot of heavy wet snow or if you decide to put a plow blade on the front of your rig.
BTW looked it up and in WV you can have studded tires on between November 1st and April 15th.
Last note is that A/T or M/T tires are *not* remotely close to winter tires for grip (studded or not) under most conditions other than deep snow. You see 4WD trucks, with fancy, "aggressive" off road style A/T-M/T tires in the ditch all the time in winter up here. Black ice or freezing cold demands a real winter tire, not rock hard lugs the size of your fist.
09-18-2015, 02:07 AM
If you are going to chain or cable 4WD do them all. That way you don't have the rear catching up with the front (front only) or have to sacrifice braking and steering (rear only). If you only have one set I would do the rear for stability. Same reason you always put newer tires on the rear if you only replace two for some reason.
If you have chains on you are in such low traction conditions and going at such low speeds you should not be stressing anything too much.
09-18-2015, 11:05 AM
I disagree. also, I always put the newer tires on the front. being able to stop and steer are pretty important.
09-18-2015, 12:41 PM
Real Name: Bruce
Real Name: Bruce
I certainly don't disagree with that, but nevertheless, if you can only replace two tires, the recommendation is to put the new ones at the rear. Keeping the rear end of the vehicle, at the rear, is really important too. Best just to replace all four tires if they're worn out.
When Buying Two Tires Instead of Four, Place the Two New Tires on the Rear - Tire Safety Group
09-18-2015, 01:51 PM
I've only heard great things about these. The videos on the site prove it. Credit to the 4x4Podcast for getting the news out about these:
http://www.flextrax.com
'86 SR5 T4R 1st Gen
31'' BFG A/T KO's, 17'' '07 Taco wheels, "Zuk" Mod, 2 inch front ball joint spacers, Trail Gear front tube bumper with stinger (no winch...yet ), custom fabbed rear bumper, aspiring SASer
09-18-2015, 05:41 PM
... You see 4WD trucks, with fancy, "aggressive" off road style A/T-M/T tires in the ditch all the time in winter up here. Black ice or freezing cold demands a real winter tire, not rock hard lugs the size of your fist.
That's what I said.
To re-phrase:
When there is no ice on the road, Highway patrol allow 4WD with A/T or M/T.
When there is ice (underlined in original post), chains are required because rubber, no matter the lugs does not bite into ice.
We don't see much ice here on California mountains but I think that's the only time (when you have ice on road) you'd really need chains/cables IF you have 4WD and All-terrain / MT tires.
09-18-2015, 05:45 PM
Real Name: Kyle
Real Name: Kyle
Well, I don't know how good they'd work (I never got to try mine out) but I'd also think about looking into studded snow tires. Depending on how you use them they could be easier then chains and you don't have to worry about them falling off when you reverse. Just another option. Hope it helps!
1990 Toyota 4Runner SR5 V6 5 Speed Manual 4x4 263k miles
1995 Toyota 4Runner SR5 V6 5 Speed Manual 4x4 (Sold @ 225k)
1996 Toyota 4Runner SR5 V6 (Totaled @ 317k miles)
1991 Toyota Pickup DLX 22re 5 Speed Manual 4x4 206k miles
09-18-2015, 06:09 PM
I run all 4 studded tires..... with them, its rare to ever need chains... But then I have driven in snow/ice all my life.
like mentioned.... usualy just when highway patrol has "chains required"
most times its just "traction devices required" & studs work awesome.
just cant be an idiot like 50+% of the people who think 4 wheel drive & the ability to "go" means they can drive like the road is dry.... I see them people off the road, slamed into things, upside down, etc... & I just laugh!
example: I was in my 89 4x4 extended cab (4 sand bags in the rear) 4 studded tires & driving from seattle to boise durring 1 of the biggest snow storm's to hit in years. I never went over 45 mph the whole way... I passed over 2 mountain ranges.... & saw over 25 4x4 trucks & Suv's off the road or on there roofs, etc... I never chained up or even slid....
@ 1 point they closed the blues pass, but I made it by just before they closed it. (when I stopped to get gas, they asked where I came from. LOL & state patrole was blocking the on ramp.... when they got a call, I just went on my way.)
It took nearly 20 hrs to make the trip! (normaly around an 8hr trip)
09-18-2015, 06:15 PM
Originally Posted by 85_4Runner
how many years before they change their minds again? it used to be recommended they go on the front.
either way, I stand by what I said, with the limited information given. chains on the front only, will likely be just fine, and save a bunch of time. if its just a small section of road that they are needed, its likely also to be slow going.
as it is, 35mph would be FAST while running chains. if you are going fast enough while running chains, that you risk swinging the rear end around due to not having chains on the back, YOU ARE GOING TOO FAST.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
