Real Name: Chris
Real Name: Chris
Check the fuse box with either a test light or multimeter for a wire with power when the ignition switch is on, and goes out when the switch is off. Tap that wire to trigger the relay on your fan.
You'll have to do this yourself, as there's too many combinations of vehicle wiring scenarios (options, manual or auto, a/c, power stuff, etc.). Its easy enough though, should take you a whole 2 minutes to figure out which wire is switched in the fuse block...
2011 4 Runner (my daily driver)
1987 Xtra Cab (35's and locked front/rear, the trail toy!)
1985 Supra (430rwhp track toy!)
2006 Honduh Odyssey (the wife's van)
