Old 02-23-2016, 01:47 PM #31
Ahlem Ahlem is offline
Ahlem is on a distinguished road
Can you post some pictures of the frame parts on the newer one that caused it to be fatal? Would be beneficial to the future searchers to see where to look when doing a PPI. Thanks.
Ahlem is offline   Reply With QuoteReply With Quote
Old 02-23-2016, 02:08 PM #32
Bad_Vision's Avatar
Bad_Vision Bad_Vision is offline
Bad_Vision is on a distinguished road
Bad_Vision's Avatar
Sure Im pulling the body off now so I will take pictures of it when the body's off.
Classic's Section Moderator
http://www.4crawler.com/4x4/CheapTricks/index.shtml
My 1985 TDI swapped 4Runner http://www.toyota-4runner.org/classi...-tdi-swap.html
Bad_Vision is offline   Reply With QuoteReply With Quote
Old 02-23-2016, 02:10 PM #33
Bad_Vision's Avatar
Bad_Vision's Avatar
Factory sunroof for sale PM for details.
Old 02-23-2016, 07:04 PM #34
Bad_Vision's Avatar
Bad_Vision's Avatar
Separated body and frame from the 1984
The frame is in good shape minus some scaling that will come off when it's sand blasted.
Old 02-23-2016, 07:07 PM #35
Bad_Vision's Avatar
Bad_Vision's Avatar
Just to show what to look for when assessing your frame.
If you have scaling tap it with a hammer hard. If you punch through you have problems but if it's still tough and hurting your hand your good.
Old 02-23-2016, 08:26 PM #36
flyinhawaiian01's Avatar
flyinhawaiian01 flyinhawaiian01 is offline
Real Name: Chris
flyinhawaiian01 will become famous soon enough
Real Name: Chris
You ever get your axles figured out? Since you have a ton of 1st gen stuff, why not just build them up? Straight axles from '84 would be best, as they have the support brackets welded in from the factory, and I would not worry about snapping axles at all if you run Longfield's Superaxles. You will not break them, and if you somehow did, Bobby has a lifetime warranty on them, free replacement if you do! Chances are, you'll break the diff or transfer case before you ever hurt those axles.
And that's some nasty scaling on that frame! I gotta see how it looks once you sandblast it. Hopefully it doesn't blow through when you clean it up.
2011 4 Runner (my daily driver)
1987 Xtra Cab (35's and locked front/rear, the trail toy!)
1985 Supra (430rwhp track toy!)
2006 Honduh Odyssey (the wife's van)
flyinhawaiian01 is offline   Reply With QuoteReply With Quote
Old 02-24-2016, 12:02 AM #37
Bad_Vision's Avatar
Bad_Vision's Avatar
Yup I'm running the Toyota mini truck axles I'm using the Marlin crawler conversion plate to put a top shift gear drive t case mounting to the A340 that is on the 3.4l set up so it will make it drivers drop and gear driven.
Old 02-24-2016, 08:19 PM #38
ajohnson's Avatar
ajohnson ajohnson is offline
ajohnson will become famous soon enough
ajohnson's Avatar
Unfortunately Bobby Long is not around anymore and Trail Gear bought the Longfield brand. Longfield axles are now basically "rebranded" dirty 30's. Go with RCV, they are the same as the original Longfield birfs.
2007 Tacoma with cool things and stuff
1987 4runner with cool things and stuff and such
ajohnson is offline   Reply With QuoteReply With Quote
Old 02-25-2016, 11:07 AM #39
Real Name: Chris
Real Name: Chris
Really? WTF!?!?!?!
So, I guess the lifetime warranty meant lifetime of Bobby's company?
I guess I shouldn't worry too much, even with a stock 1UZ, I doubt there will be enough torque to snap it.
Old 02-25-2016, 11:32 AM #40
Bad_Vision's Avatar
Bad_Vision's Avatar
Hell guys with Cummings swaps will run the dirty thirtys until they switch to tons or unimog axles. Of course most intelligent off-roading guys know you don't need 44" tires to do anything anymore. 36" and 37" are more common now.
Old 02-25-2016, 11:47 AM #41
ajohnson's Avatar
ajohnson's Avatar
Bad_Vision's TDI 1984 build with 1996 SAS build.
Originally Posted by flyinhawaiian01 View Post
Really? WTF!?!?!?!
Yes. I believe TG upholds the original warranty, but your replacement would basically be a Dirty 30.
New RCV shafts are marked in memory of Bobby. RCV originally worked with Bobby to produce the super axles.
Old 03-04-2016, 06:44 PM #42
Bad_Vision's Avatar
Bad_Vision's Avatar
Update. Waiting on Marlin crawler to produce some tcase adapter plates for the a340 to accept a top shift gear drive tcase. I can't machine one for the cost of what they sell them for.
the second frame just was sent out and as soon as that's back its time to make the custom mounts to bolt a 3rd gen body to it and modified steering system.
Old 06-06-2016, 03:45 PM #43
Any updates on your project?
Old 06-06-2016, 03:47 PM #44
Bad_Vision's Avatar
Bad_Vision's Avatar
Not yet, I got really busy with work building a brand-new house top to bottom so absolutely no time for fun. It will be July before I get some time to actually work on the trucks
Old 01-10-2017, 01:14 PM #45
JBurt's Avatar
JBurt JBurt is offline
Real Name: Jeff
JBurt has a spectacular aura about JBurt has a spectacular aura about
JBurt's Avatar
Real Name: Jeff
Hopefully the house is done and you're comfortably enjoying some completed projects. Why'd you decide to scrap the 96?
97 SR5 4runner: 2" OME Lift, rear E-Locker, 231mm Tundra Brakes, 203K, B&M 70264 Tranny Cooler, Duratracs
Build
JBurt is offline   Reply With QuoteReply With Quote
Any meets? Aelfwine Toronto / Ottawa / Ontario 4 10-27-2014 11:51 AM
85 4runner meets 96 sr5? Bad_Vision Classic T4Rs 6 11-27-2013 11:48 AM
Texas meets? Craig8d8 General Discussions 1 04-18-2012 01:25 AM
meets in So Cal?? 501runner T4R Meet Announcements & Info 12 12-14-2011 10:22 AM
