Originally Posted by Bad_Vision
So turbos, I said when I go bigger that I will make a custom intake. What's the size I can do without having low rpm lag? Or can I do like a t3 feeding a big t60?
I have done feeder turbo set up before but never on diesel.
I highly recommend staying VNT first of all. You could certainly do compound or sequential. However, it's worth pointing out that the VNT15 that comes stock on the ALH is 1st gen VNT technology. And the tech has really changed a lot since it was released. In fact, 4th gen VNTs are smaller than ever, while pumping out more power with less lag.
So, if you don't want to get crazy complicated by going twins, I recommend 3rd or 4th gen VNT. The turbo I plan on running is the GTC1549VZ. It comes stock on the 177 hp Cuda, and will easily support 240 hp. Which is very difficult to obtain with the ALH. Users running this turbo report almost zero lag, and full boost at just off idle. Pretty obscene compared to the VNT15. You'll want to be careful, as the ALH doesn't like to be lugged with gobs of power below 1,600 or so rpms.
