Originally Posted by KidVermicious
The outer is more of a dust cover than a seal. If you've got gear oil it's the inner that's leaking, and five bucks says it's leaking because the wheel bearing is shot. If you don't have ABS it's an easy fix.
Toyota Maintenance: Replacing Rear Wheel Bearings and Seals
Make sure it's gear oil and not brake fluid though.
Thanks for the link.
I kind of thought the same thing, gear oil needs to get past the inner seal
to reach the brakes, I assumed that the outer protects the bearing from dirt.
Why do you think the bearing is gone? you think the failing seal has contaminated the bearing or the bearing has damaged the seal?
It is ABS, fairly stock and stays on the road, sometimes goes to the beach.
Bearings really have only 10K, had them done when I had the carrier rebuilt
about 4 yrs ago.
Gear oil
