Old 11-25-2017, 04:46 PM #46
jsmith7's Avatar
jsmith7 jsmith7 is offline
jsmith7 is on a distinguished road
jsmith7's Avatar
Originally Posted by Dubk_trd View Post
any updates i really like your build . just picked up a 89 in the same color
Thanks man! I haven't done too much. I've put about 5,000 miles on since the rebuild. It's developed an idling issue when the engine is warm. If the engine is cold, or hot, it idles fine, but sometimes has really low idle when it's warm.
Just applied some fluid film to protect the undercarriage from these Ohio winters.
86 4Runner build "El Chapo"-img_0576-jpg
86 4Runner build "El Chapo"-img_0591-jpg
'86 4Runner "El Chapo"
'85 Extra cab
jsmith7 is offline   Reply With QuoteReply With Quote
Old 09-17-2020, 12:29 PM #47
jsmith7's Avatar
jsmith7's Avatar
Wow, I haven't been on here for quite some time.
I moved from Ohio to Michigan and bought a house. All of my free time was spent renovating that... So the 4runner got put behind the garage and hibernated...
86 4Runner build "El Chapo"-img_1706-jpg
'85 Extra cab
Old 09-17-2020, 12:51 PM #48
jsmith7's Avatar
jsmith7's Avatar
Finally pulled the 4Runner out from behind the garage after a little over a year.
Sold the wheels and tires that were on it with a '91 4Runner I had bought for cheap, planned to rebuild the engine and sell... Ended up taking the engine completely apart, realized I didn't have time to rebuild the engine, and sold it.
With no tires and wheels, I needed to get some...
I've always wanted 33's, so I got some. 33x10.5r15 mounted on cheapy 15x8 steel d windows.
It was a dog with the 31's, so a regear was a necessity with the 33's. Went with 4.88s and threw a Yukon Grizzly locker in the rear while I was at it.
Replaced wheel, diff, and pinion bearings, all seals, and brakes while I was in there.
Oh and a fresh paint job too.
86 4Runner build "El Chapo"-img_3760-jpg  86 4Runner build "El Chapo"-img_3784-jpg  86 4Runner build "El Chapo"-img_3785-jpg  86 4Runner build "El Chapo"-img_4078-jpg  86 4Runner build "El Chapo"-img_4080-jpg  86 4Runner build "El Chapo"-img_3798-jpg  86 4Runner build "El Chapo"-img_4147-jpg
'85 Extra cab
Old 09-17-2020, 12:56 PM #49
jsmith7's Avatar
jsmith7's Avatar
Sitting nice and purty.
Rides great! I can actually accelerate up hill going 75mph. With some mixed driving, a tiny bit of trail riding, but mostly highway I averaged 20.3 on my last fill. Not too shabby!
First time setting diff bearings/backlash and pinion bearing preload. Ive put about 1200 miles on since the rebuild and all as been good.
86 4Runner build "El Chapo"-img_4560-jpg  86 4Runner build "El Chapo"-img_5197-jpg  86 4Runner build "El Chapo"-img_5195-jpg
'85 Extra cab
Old 09-17-2020, 01:06 PM #50
jsmith7's Avatar
jsmith7's Avatar
This fall/winter I plan on fixing the rust, dents, and other body imperfections and giving it a fresh paint job.
I plan on doing all the work myself in my garage. I will makeshift a paint booth when it comes time to spray.
I have started on the driver front fender. A few dents/creases as well as about 15 holes on the inner lip from the PO using self tapping screws to screw in rubber molding as fender flares (the cause of rust on my rear fenders)
86 4Runner build "El Chapo"-60972435289__f57f2670-20ed-456e-9ae1-1a1582b3fda1-jpg  86 4Runner build "El Chapo"-img_5205-jpg  86 4Runner build "El Chapo"-img_5206-jpg  86 4Runner build "El Chapo"-img_5227-jpg
'85 Extra cab
Old 09-17-2020, 01:11 PM #51
jsmith7's Avatar
jsmith7's Avatar
Onto the driver door...
There was a cluster of small dents near the handle. First pic below highlights these dents. Pounding these out from inside was quite the pain. Going to try to use as little body filler as possible.
The PO also used self tapping screws to screw in some carpet on the interior of the door... welded in those holes. Still need to grind them smooth
86 4Runner build "El Chapo"-img_5229-jpg  86 4Runner build "El Chapo"-img_5228-jpg  86 4Runner build "El Chapo"-img_5235-jpg
'85 Extra cab
Old 09-17-2020, 01:17 PM #52
jsmith7's Avatar
jsmith7's Avatar
Restored the B pillar badges. They were in pretty rough shape...
Scraped off all the old paint. What a pain...
Used some gel type, t shirt paint for the letters.
black spray paint on the backs.
Not perfect, but much better than before.
86 4Runner build "El Chapo"-img_5245-jpg  86 4Runner build "El Chapo"-img_5257-jpg  86 4Runner build "El Chapo"-img_5259-jpg  86 4Runner build "El Chapo"-img_5261-jpg  86 4Runner build "El Chapo"-img_5264-jpg
'85 Extra cab
Old 09-20-2020, 09:28 AM #53
Melrose 4r's Avatar
Melrose 4r Melrose 4r is offline
Real Name: Thomas
Melrose 4r is on a distinguished road
Melrose 4r's Avatar
Real Name: Thomas
Looks great!
Melrose 4r is offline   Reply With QuoteReply With Quote
Old 09-30-2020, 02:54 AM #54
Cali 4runner Cali 4runner is offline
Cali 4runner is on a distinguished road
Cool to see you still have it and are making it even better!
Cali 4runner is offline   Reply With QuoteReply With Quote
Old 10-02-2020, 04:58 PM #55
thmclaugh thmclaugh is offline
thmclaugh is on a distinguished road
El Chapo is a fantastic name, and you have done some amazing work. Enjoy the fruits of your labor!
thmclaugh is offline   Reply With QuoteReply With Quote
Old 10-05-2020, 10:22 PM #56
Chuckles89's Avatar
Chuckles89 Chuckles89 is offline
Real Name: Charlie
Chuckles89 has a spectacular aura about Chuckles89 has a spectacular aura about Chuckles89 has a spectacular aura about
Chuckles89's Avatar
Real Name: Charlie
Nice work!
Originally Posted by STX4Runner View Post
90% of the build threads in the 5th Gen section consist of Fuel Wheels, Plastidip, Duratracs and window tint.
1998 4Runner "Diamond" - Daily Driver (rolled & rebuilt) - 3.4 5-Speed, Coastal Bumper, Manual Hubs, 255/80r17 AT3Ws (409k+ Miles)
1997 4Runner "Becky" - Camping Rig - 3.4 Auto (for now), Armored, Cable E-Locked, Coastal Bumper, Sleeper Deck, 255/80r17 AT3Ws (185k+ Miles)
1989 4Runner | Tennessee 4Runner Group
Chuckles89 is offline   Reply With QuoteReply With Quote
Just another 4Runner build NcYota99 3rd gen T4Rs 15 03-18-2015 08:49 PM
My 85 4runner build Socal85 Classic T4Rs 3 04-24-2013 12:18 PM
98 4runner build central8-23 3rd gen T4Rs 10 11-25-2010 03:03 PM
4Runner build up CPL T.Norris Australia 0 10-31-2010 08:43 PM
88 4runner build SV_Dude Classic T4Rs 21 03-15-2010 09:40 PM
