i'm not positive, but i believe the '88 used a one-year only injector with different specifications than either the pre-'88 and post-'88. therefore, if you are using an '88 engine with '88 injectors, you'll need an '88 ECU to make it work, or do some other changes.
if you are already using the '89 injectors, then something else is going on.
the starter issue may well be related to the wiring flaw made by toyota in the starting circuit, similar to the headlight wiring flaw.
wally
member, new hampshire timberland owners association (NHTOA)
1987 4runner sr5, 22re, 5-speed
1988 4runner sr5, 3.0, auto (parts rig)
1987 4runner, sr5, 22re, 5-speed (#2)
