I am looking for a simple/easy/cheap remedy to the nearly totally flat leaf springs on a new to me 1985 4runner. This is not going to be a wheeler, so I don't need a bunch of flex. What I do need is the 33x10.50s that the PO put on at stock height to not rub ASAP.
I was hoping someone more familiar with the factory springs would chime in an let me know before I do something stupid.
In an effort to try to replicate a previous leaf spring revival, I am thinking about pulling the spring packs apart and adding a donor leaf to each. My hope is to achieve something in the neighborhood of 3" of lift. I, and many others, have done this with rear Tacoma leafs with varying degrees of success. Using a single leaf, I was able to achieve about 3" of lift on the rear of my Tacoma recently. Ride quality improved, but I attributed this to the leafs being toast beforehand. I can't compare it to actual lift springs from other manufacturers.
My inspiration for this project comes from here:
https://www.tacomaworld.com/threads/...ishing.194386/
Here are my results:
Tacoma Spring refurbishing
So, my plan was this.
1. Starting with the front - pull the springs, making note not to switch sides.
2. Cut the leaf spring banding (if necessary) and remove the center pin.
3. Cut down my donor leaf as described in the link above.
4. Slide the donor leaf in between overload and bottom spring like I did in the link above.
5. Slap them back in and see what happens.
So anyone see any problems in my thought process here? I figure that if I don't like the results, I can move on to some aftermarket lift springs or take the leaf back out - no harm. Right?
Lastly, will I need to change anything else out? Shocks I assume, but anything other than that? Not familiar with lifting on a solid axle.
Thanks,
Daniel
2005 GX470
3.4l A340 Automatic to R150F Manual Transmission Swap
http://ttora.com/forum/showthread.php?t=159482
