Old 08-12-2016, 10:55 PM #1
Ruger2011 Ruger2011 is offline
Ruger2011 is on a distinguished road
Front Shock Suggestions after 1.5 inch Front Ball Joint Specer Kit
I got my Toytec 1.5 inch Front Ball Joint Spacer Kit installed today on my 1986 4Runner and my current shocks are almost maxed out. I need some new shocks with more travel to improve the ride quality and performance. I was curious if the Old Man Emu 60072 front shocks would allow enough travel or if anybody had any other suggestions.
60072 - Front OME Nitrocharger Sport Shock
Ruger2011 is offline   Reply With QuoteReply With Quote
Old 08-12-2016, 11:03 PM #2
joeynational's Avatar
joeynational joeynational is offline
joeynational will become famous soon enough
Im using Bilstien HDs
Sent from my LG-D801 using Tapatalk
My build thread;
https://www.toyota-4runner.org/class...achillies.html
joeynational is offline   Reply With QuoteReply With Quote
Old 08-12-2016, 11:19 PM #3
KidVermicious's Avatar
KidVermicious KidVermicious is offline
Real Name: Kevin
KidVermicious has a spectacular aura about KidVermicious has a spectacular aura about
Real Name: Kevin
OME shocks would be perfect for that lift.
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
The Grey Bastard, 1985 4Runner, driveway ornament.
Utah DesertRunners T4R, for all things wheeling and 4Runner in Utah.
KidVermicious is offline   Reply With QuoteReply With Quote
Old 08-12-2016, 11:32 PM #4
Awesome! I will order the OME 60072 Nitrocharger shocks this weekend.
Old 08-13-2016, 11:33 AM #5
89FourRunner's Avatar
89FourRunner 89FourRunner is offline
89FourRunner is on a distinguished road
Are they too short? Lift the truck by the cross member and pop the lower bolt off the shock? If the shock is aligned with the mounting holes on the control arm, and just make it, you can save money by simply spacing the current shocks down nice and neat.
You can do it with a nut like so:
Of course if the shock is way too short you have to order some new ones.
1989 Toyota 4Runner SR5, 3.0L V6, 4x4, 5-Speed Manual, 2" add-a-leaf kit in rear, Bone Stock with 31x10.5" tires.
89FourRunner is offline   Reply With QuoteReply With Quote
Old 08-14-2016, 12:22 AM #6
Thanks for the information and the picture. I will take a look tomorrow.
Old 08-14-2016, 02:22 PM #7
No problem. I am not promoting the cheap skate route, but I know what these bjs kits cost and then shocks sometimes double the cost, even tripple.
Just jack the truck off the ground at the front crossmember and look and see if the upper control arm droop stops are what is stopping the travel. If the droop stops dont make contact then the shock is too short. This will wear out the lower ball joints fast. If the droop stop on the upper UCA is contacting then the shocks you have are long enough. If you want to investigate further: disconnect the lower bolt of the shocks, then wiggle it free of the mounting tabs and see if it wants to continue its travel farther down.if it doesnt, and you still feel uncomfortable about them you can space them down as noted.
Old 08-14-2016, 05:50 PM #8
iferro iferro is offline
Real Name: Ian
iferro is on a distinguished road
Real Name: Ian
i would highly recommend billys over ome. thats just my .02 though. i opt for koni or bilstein whenever available.
also would you post pictures of your rig with the spacers? i was thinking of getting them. did you also get the diff drop?
iferro is offline   Reply With QuoteReply With Quote
Old 08-21-2016, 07:06 PM #9
dsalazar88 dsalazar88 is offline
dsalazar88 is on a distinguished road
Diff drop
Yes you absolutely need to get spacers to drop the front diff.
They are 30 bucks from 4crawler and 30 minute install. I didn't have these on mine and just threw down almost 1k to get my CV assembly replaced when my boots split from the increased angle.
Not sure if the spacers help with the ride quality at all but it will save your CV boots and give you more downward travel.
dsalazar88 is offline   Reply With QuoteReply With Quote
Old 08-21-2016, 09:53 PM #10
The after pictures are at the bottom of this post! I didn't get a Diff Drop! I have Bilstein 5100s on my Tundra and they are great but I decided to try OME on the 4Runner! I am pleased with both so far!
Ruger2011's 1986 4Runner Build Thread
Front Upper Ball Joint - replace arm or joint? dleeallen 4th Gen T4Rs 7 02-05-2016 12:14 AM
2003 4runner v8 lower ball joint does not want to move an inch!!! saint123 4th Gen T4Rs 12 12-28-2015 07:08 AM
ball joint suggestions? bubba 10 Engines / Suspension / Wheels / Tires / Audio / Accessories 0 07-07-2014 03:17 PM
New front shock suggestions? Ride_Red 3rd gen T4Rs 4 08-07-2012 02:09 PM
front passenger lower ball joint keeps breaking/coming apart jsbrewton 3rd gen T4Rs 9 02-13-2011 06:22 PM
