Real Name: Ron
Real Name: Ron
It's possible you may have an air bubble in the cooling system. That will throw the temperature sensors off and make for poor engine operation.
Google "burping the cooling system" and see what you come up with. There are writeups on how to do it. Generally involves pointing the vehicle as nose-high as you can get it and running it for a while with the radiator cap off, adding water as space becomes available.
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
