Originally Posted by RonJR
Sounds like your key is worn and your switch is also worn, and the combination doesn't work together anymore. You might try having a locksmith (not KMart or Walmart) cut you a new key - the proper height bumps on the key might be enough to get it to work again.
If you have a relatively unused key lying around you might try that as well.
Very good point. Maybe I'll pop it out and take it to a locksmith and have them cut a key off the code. I tried removing it a week ago, but couldn't get the clip off...so I started tinkering elsewhere. About freaked out when I realized I couldn't get the window back down. Had to cut some excess wire to reverse polarity at the motor.
I got 4 keys from the PO, all were ILCO cuts, and all were pretty worn, and all turn the switch LEFT, but not RIGHT.
