Old 04-19-2008, 02:31 PM #16
Alabama4Runner's Avatar
Alabama4Runner Alabama4Runner is offline
Alabama4Runner is an unknown quantity at this point
Guys,
There's a replaceable drive gear on the end of the speedometer cable where it goes into the transmission. I haven't done it myself but my mechanic has. Go to the dealer and see if there isn't a replacable part...easier than the entire speedometer cable.
1985 4Runner
1997 FZJ80
2007 HDJ100 - DD
Alabama4Runner is offline   Reply With QuoteReply With Quote
Old 04-22-2008, 06:35 PM #17
toplessrunner's Avatar
toplessrunner toplessrunner is offline
toplessrunner is on a distinguished road
I was able to fix my speedometer last weekend, it does not jump or rattle anymore, I used Prolong lubricant on the cable and a small amount on the odometer where the cable connects, FYI if anyone uses my method please do it in a empty parking lot.
2015 TRD Pro
toplessrunner is offline   Reply With QuoteReply With Quote
Old 04-26-2008, 09:52 PM #18
rob dives rob dives is offline
rob dives is an unknown quantity at this point
try this
jc whitney sells a speedo cable lubricator it attaches to a gease gun. also if you can disconnect from tranny side a slowly pull on inner cable you can inspect it for kinks/grease and put it back .
rob dives is offline   Reply With QuoteReply With Quote
Old 04-26-2008, 10:50 PM #19
try this
jc whitney sells a speedo cable grease tool and grease.detach cable both ends and lube cable...also some cars cable pull out easy inspect for kinks/grease and replace.. check speedo cable gear at tranny end for damage...good luck
Old 11-13-2019, 11:56 PM #20
Lewichris Lewichris is offline
Lewichris is on a distinguished road
I have just taken my dash apart due to this same problem. What I found was old ass grease causing the cable to work too hard to turn the gear. I put PB blaster in there to loosen it up. Then cleaned it out with parts cleaner. Then put in some new light grease. Put back together and absolutely no bounce or squealing. No need to lube the cable for me. The problem was old ass grease in a 25 year old vehicle. Hope this helps someone out.
Lewichris is offline   Reply With QuoteReply With Quote
Old 11-18-2019, 08:21 AM #21
wallytoo's Avatar
wallytoo wallytoo is offline
wallytoo has a spectacular aura about wallytoo has a spectacular aura about
wallytoo's Avatar
a useful bump of an 11 year inactive thread, unlike most bumps of ancient threads. good job! you provided good information about dealing with the symptoms, rather than asking for answers from one of the old posters or giving advice specifically to one of the old posters.
refreshing.
member, new hampshire timberland owners association (NHTOA)
1987 4runner sr5, 22re, 5-speed
1988 4runner sr5, 3.0, auto (parts rig)
1987 4runner, sr5, 22re, 5-speed (#2)
wallytoo is offline   Reply With QuoteReply With Quote
Speedometer and Odometer SCRunner12 Classic T4Rs 8 09-07-2010 12:46 AM
Erratic Speedometer wkriner Problems & Warranty Issues 6 10-23-2009 10:13 AM
Rattling noise from front wheel Big E 4th Gen T4Rs 6 05-11-2006 07:02 PM
Speedometer problems - mystery James Moore Problems & Warranty Issues 3 11-13-2005 11:32 PM
Rattling noises return Avian Problems & Warranty Issues 2 05-18-2004 06:38 AM
