Old 01-03-2017, 10:25 AM #1
SquirtleSoup SquirtleSoup is offline
Real Name: Andrew V.
SquirtleSoup is on a distinguished road
Exclamation HELP!!! DD Stuck in Neutral Drives in Hi4
I am gonna get straight to the problem this past weekend my DD and only vehicle got stuck in neutral I found it would drive only in Hi4 In doing research before this post I found only that hopefully my problems lie in the t-case and not the transmission itself that is my understanding I aint no master mechanic so I can be completely wrong does anyone have any ideas what may be the cause of my problems?? Thank You in advance for any replies
In some of my reading I am lead to believe that the transfer case motor may be the culprit but I can not find the part number if this vehicle even has one
Vehicle is '94 Toyota 4runner 3.slow V6 4WD
'94 4runner Automatic 4x4 V6 3.Slow
SquirtleSoup is offline   Reply With QuoteReply With Quote
Old 01-03-2017, 12:48 PM #2
nevada's Avatar
nevada nevada is offline
nevada has a spectacular aura about nevada has a spectacular aura about nevada has a spectacular aura about
nevada's Avatar
try again.
explain exactly what its doing.
it cant be in neutral if its driving. what you said doesn't make sense.
1985 pickup: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited: stock. Build Thread YouTube Channel
nevada is offline   Reply With QuoteReply With Quote
Old 01-03-2017, 01:24 PM #3
If I put the truck in Drive or Reverse it will not move the engine just revs as if it were in neutral it does this in all modes unless I put the truck into Hi4 then it drives
Old 01-03-2017, 01:55 PM #4
RonJR RonJR is offline
Real Name: Ron
RonJR has a spectacular aura about RonJR has a spectacular aura about RonJR has a spectacular aura about
Real Name: Ron
It's almost certainly a tcase problem. Sounds like the output to the rear drive shaft is disconnected or sheared off. So, when you put it in 4hi, the front wheels are providing drive power, but the rear wheels are just along for the ride.
Get it to a mechanic that you trust.
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
RonJR is offline   Reply With QuoteReply With Quote
Old 01-03-2017, 01:59 PM #5
bearcat90's Avatar
bearcat90 bearcat90 is offline
bearcat90 is on a distinguished road
bearcat90's Avatar
When you shift into first or reverse, does it feel like the gears are engaging? In an attempt to help without belittling anyone, is your clutch pressed all the way to the floor when you're shifting? Transmission issues are not my forte so I would start with the KISS method: keep it simple, stupid. These details could help someone who actually knows what they're talking about narrow down your issue..
1990 4Runner 3VZE 170k rebuilt
bearcat90 is offline   Reply With QuoteReply With Quote
Old 01-03-2017, 02:38 PM #6
mholme's Avatar
mholme mholme is offline
mholme is on a distinguished road
mholme's Avatar
He has an automatic.
mholme is offline   Reply With QuoteReply With Quote
Old 01-03-2017, 02:43 PM #7
Thumbs down
It's an automatic transmission, when I put it in drive or reverse in 2WD I can feel it barely shifting into gear if I step on the gas it moves about an inch and then the engine just revs as if it were in neutral in Hi4 it drives very roughly
Old 01-03-2017, 02:57 PM #8
ts01-4Runner ts01-4Runner is offline
ts01-4Runner is on a distinguished road
... got stuck in neutral ... I aint no master mechanic ...
As another non-mechanic with the same setup, my question is, how did it "get stuck in neutral"? What were you doing when the problem arose?
ts01-4Runner is offline   Reply With QuoteReply With Quote
Old 01-03-2017, 02:59 PM #9
And, for the master mechanics - what are the things a driver could do that might cause - or avoid - this type of problem?
Old 01-03-2017, 03:47 PM #10
I was simply at a stop light on Nye when the light turned green my engine just revved as if it were in neutral I shifted through every gear until I found that Hi4 would allow me to drive
Old 01-04-2017, 12:14 PM #11
Well there's your problem - don't stop at stop lights!
Old 01-04-2017, 12:39 PM #12
goatfarmer's Avatar
goatfarmer goatfarmer is offline
goatfarmer is on a distinguished road
goatfarmer's Avatar
Not sure about the 94 Auto, certain other member's more familiar can advise. Had same/similar problem, transmission was okay but the problem was in the T-Case and according to the Transmission shop they are non-separable. Did not have a clue so I had the shop make the repair, ouch, the cost of labor was absurd, majority of the cost was in removing/installing the transmission. Unfortunately, less that 100 miles vehicle now collecting dust in need of a head gasket.
Dave
'The problem with engaging in useless activity is never knowing when you are done'
1990 T4r, SR5, Auto, 4X4
goatfarmer is offline   Reply With QuoteReply With Quote
Old 01-04-2017, 01:29 PM #13
Real Name: Ron
Real Name: Ron
It's true that the auto transmission and the tcase on the '94 are an integrated unit. As such, there is some communication between the two which I have not studied in any detail, since my vehicle is a manual. It may be that something in the tcase is sending a wrong signal to the transmission, holding it in neutral unless the tcase is in 4hi.
The best would be to pull any transmission diag codes. I've attached the section of the FSM concerning troubleshooting the A340 transmission. Page AT-18 has the procedure for pulling the codes. I'd suggest starting there.
File Type: pdf A340h Automatic Transmission_ Troubleshooting.pdf (603.8 KB, 310 views)
Cone washers stuck stuck stuck 4eigner 3rd gen T4Rs 14 04-03-2015 03:49 AM
Calipers stuck in mornings then drives fine. kmiller93 3rd gen T4Rs 6 02-11-2014 12:53 AM
4runner stuck in neutral Denet 3rd gen T4Rs 7 10-08-2012 05:55 AM
99 - 4Runner Drives Forward in Neutral ?!?! Post strawberry milkshake issues... SJChiz Problems & Warranty Issues 1 09-03-2012 12:14 AM
Dangerous Drives on TV ryangab General Discussions 2 06-25-2010 03:09 PM
