After replacing the timing belt and the water pump and the crank and camshaft seals I have figured out that the valve covers and pan are leaking. Yipee. Only leaks about half the oil it used to so the new seals in the front helped out. The PS pump isn't leaking for me so that is good.
Gawd those valve covers look like a pain to remove...sort of like everything else on this v-6
