Old 03-23-2017, 04:39 PM #16
russman russman is offline
russman is on a distinguished road
Can you post photos of your Blazeland setup once it's all installed? And what have you decided to do about your steering system? I'm getting darn close to pulling the trigger on LT setup.
Can you let us know how the truck handles on-road as well as off? I'm curious about how these long arm kits influence high speed freeway manners.
It looks like you have a super clean 1st gen! Nice build man!
russman is offline   Reply With QuoteReply With Quote
Old 03-24-2017, 07:58 AM #17
PlanetExpress's Avatar
PlanetExpress PlanetExpress is offline
Real Name: Drake
PlanetExpress is on a distinguished road
Real Name: Drake
The steering system will remain mostly factory, the Blazeland kit comes with extended adjustment sleeves to accommodate the added length. I have an old Downey Idler arm brace which i will be putting on as well. I just installed new inner and outer tie rod ends a few months ago.
I plan on taking tons of pictures during the install and will be sure to post them here.
Thanks for the compliment! I love this truck. I only wish it had more power for highway driving.
1987 4Runner 22re, 5-speed Daily driver/Wheeler
2003 4runner SR5 V8
Instagram: @plan_ex
PlanetExpress is offline   Reply With QuoteReply With Quote
Old 03-24-2017, 08:03 AM #18
Real Name: Drake
Real Name: Drake
The Blazeland kit came in the mail yesterday. I had planned on doing the install this weekend, but found something that may cause delays unless i can get it sorted out today. I have two alignment cams that are completely seized. There is a guy local to me who says he may have a couple that he can spare, don't know what he wants for them but i hope i can get them today.
Looks like I can buy them from Summit and Jegs for about $35 per cam bolt. That's a bit more than i want to pay for what is essentially a bolt with a flat section machined into it.
2003 4runner SR5 V8
Instagram: @plan_ex
Old 03-25-2017, 08:51 AM #19
Real Name: Drake
Real Name: Drake
Found out two of my alignment cams were seized a couple of days ago. Managed to get ahold of a local guy who had some parts trucks he let me raid for a price. Thank god for parts trucks. Anywho, moving forward with the install this weekend. Just a shot of everything together
Blazeland Long Travel - 1987 5-Speed 22re-20170324_211019-jpg
2003 4runner SR5 V8
Instagram: @plan_ex
Old 03-25-2017, 09:49 PM #20
sam24th's Avatar
sam24th sam24th is offline
Real Name: Sam
sam24th is on a distinguished road
sam24th's Avatar
Real Name: Sam
Looks good. Looking forward to seeing the install.
Need Custom Decals? PM me.
1984 Toyota Pickup SR5: 22r dual fuel propane/gas, 5-speed, 35s, RUF lift, TG high steer, Chevy 63 rear swapped, 5.29 gears, longs, chromo shafts, aisin hubs, 4.8 T-case, twin sticks, addicted offroad bumper, homemade sliders, arb front locker, aussie rear locker.
1989 Toyota 4runner SR5 Daily Driver: 3.0 5-Speed, 35s 4inches of lift (still chicken winged) sliders, arb front locker, 5.29 gears, chromo rear shafts
sam24th is offline   Reply With QuoteReply With Quote
Old 03-27-2017, 06:09 PM #21
Real Name: Drake
Real Name: Drake
Began the install Saturday morning around 9:30 am. Managed to get everything disassembled with the exception of the seized alignment cam bolts. Turns out sawzall blades rated for metal aren't rated for anything like the bolts i was dealing with. Spend a solid 6 hours cutting away at these things. Used up about 15 blades. Sunday morning i picked up a set of Diablo Carbide tip blades... they did the job in 15-20 minutes.... the 1000th lesson i've had on using the right tool for the job.
anywho! ran into some issues when swapping the current setup to the Blazeland setup.
1. The blazeland setup used the factory torsion bar to UCA bolts, i had Ranch mid-travel control arms which (unbeknownst to me) used different bolts. needed some grade 8 hardware quick. 1/2-13 3.5 inch bolts will fit (rather snuggly... Lowes didnt carry metric grade 8 hardware)
2. The mid-travel shock tower and Blazeland LCA shock tabs position a shock to interfere with the UCA in almost every position of travel. I will need to weld in new shock tabs in a different location on the LCA
3. The beefed up center-link on my truck positioned the inner tie rods roughly 3 inches inboard of the factory position. When i was trying to get the truck aligned i had toe in really bad and couldn't figure out why. Had to swap to a factory center-link
All of these issues had to do with owning a truck that was modified by the PO and not having a complete idea of how the parts would work with the Blazeland kit. The Blazeland kit itself was great!
Blazeland Long Travel - 1987 5-Speed 22re-img_20170327_103921_514-jpg  Blazeland Long Travel - 1987 5-Speed 22re-img_20170327_153032_177-jpg  Blazeland Long Travel - 1987 5-Speed 22re-img_20170327_153349_109-jpg  Blazeland Long Travel - 1987 5-Speed 22re-img_20170327_153417_114-jpg  Blazeland Long Travel - 1987 5-Speed 22re-img_20170327_153436_915-jpg
2003 4runner SR5 V8
Instagram: @plan_ex
Old 03-27-2017, 06:17 PM #22
2ndGenFlip's Avatar
2ndGenFlip 2ndGenFlip is offline
2ndGenFlip is on a distinguished road
2ndGenFlip's Avatar
looks good man.
2ndGenFlip is offline   Reply With QuoteReply With Quote
Old 06-16-2017, 08:49 AM #23
Real Name: Drake
Real Name: Drake
Tops off and cleaned up.
Blazeland Long Travel - 1987 5-Speed 22re-19143370_10154811959366872_1869013068862868455_o-jpg
2003 4runner SR5 V8
Instagram: @plan_ex
Old 03-09-2019, 08:30 PM #24
Diablo169's Avatar
Diablo169 Diablo169 is offline
Diablo169 is on a distinguished road
Diablo169's Avatar
BUMP! Please!
I almost got the rebuilt trans back in the new to me 88' runner, and I've been eyeballing the blazeland for awhile now.
88' T4R Super Clean - Build in Progress
16' MGM SR5 T4R
16' Bro-Coma on Dirty 5's (Sold)
Diablo169 is offline   Reply With QuoteReply With Quote
Old 09-02-2020, 11:07 PM #25
JustinSmileySteele's Avatar
JustinSmileySteele JustinSmileySteele is offline
JustinSmileySteele is on a distinguished road
How much lift would this front end set up give you?
JustinSmileySteele is offline   Reply With QuoteReply With Quote
Cheapest Long IFS long travel Kits? Cap. Morgan General Discussions 19 05-05-2020 02:28 AM
Dirt King Long Travel System, 14" Travel - +3.5" Wider - Under 2700 Delivered!! TotalAutomotiveLV Total Automotive Performance 13 07-04-2017 02:32 PM
1987 1st gen 22re engine/harness questions for later 22re swap Ace-the-Dragon Classic T4Rs 5 04-24-2015 12:39 PM
FS 1987 22re 5 speed 1st gen. $2400, Central VT Hyde802 For Sale: Vehicles 3 06-25-2013 10:36 PM
1987 t4r 22re problems matt_6412 Problems & Warranty Issues 1 10-09-2007 07:45 AM
