Old 10-01-2023, 08:19 PM #1
TexasA&M TexasA&M is offline
TexasA&M is on a distinguished road
1993 V6 occasionally dies at stop signs, has trouble restarting
Just like the title says... I've only had this thing for a week and haven't been out of the neighborhood with it yet because each time I've test driven it it has died at a stop sign and taken a while to get going. I have to give it gas to get it started and it smells like it's flooded. Otherwise, it idles smooth and starts up everytime just fine. Any thoughts on where to start troubleshooting?
- Steve
TexasA&M is offline   Reply With QuoteReply With Quote
Old 11-25-2023, 03:48 AM #2
Tuga2112 Tuga2112 is offline
Tuga2112 is on a distinguished road
i had something somewhat similar. althought mine only happened when stopped when it was warm
my signs was the idle was very slow when it was warm and it would stall on stop signs unless i kept the revs above 1k
the issue was a very dirty butterfly valve. after using brake cleaner in the area and making it a lot less gummy the car never stalled again.
Tuga2112 is offline   Reply With QuoteReply With Quote
Old 02-27-2024, 10:29 PM #3
weberlukas74 weberlukas74 is offline
Real Name: Lukas Weber
weberlukas74 is on a distinguished road
Sorry for the delay. It looks like there might be a hiccup with the fuel delivery, possibly leading to a rich mixture and that strong fuel smell. I suggest taking a look at the fuel pressure at the rail and giving the fuel injectors a once-over for any problems.
Also, don't overlook the chance of a vacuum leak, as that can affect idle and cause stalling. Check vacuum lines for cracks or loose connections. And take a peek at the idle air control valve (IAC) and the throttle position sensor (TPS) to make sure they're doing their job right.
weberlukas74 is offline   Reply With QuoteReply With Quote
Old 03-15-2024, 09:23 PM #4
RightLaneRunner RightLaneRunner is offline
RightLaneRunner is on a distinguished road
Mine is the same.
RightLaneRunner is offline   Reply With QuoteReply With Quote
gas , give , smells , started , stop
Engine bog, then stalling at stop signs, now engine won't start Smiley52 3rd gen T4Rs 32 05-05-2017 05:15 PM
tell tale signs of head gasket failure and stop leak baja1 3rd gen T4Rs 12 02-25-2017 08:47 PM
01 4Runner dies at stop arduckhntr 3rd gen T4Rs 15 10-10-2014 09:56 PM
Trouble restarting when engine is hot giro Classic T4Rs 10 03-09-2014 01:33 AM
4runner dies at stop sign ? ? kennyb3030 3rd gen T4Rs 10 09-14-2009 11:10 PM
