Old 02-04-2018, 01:57 AM #16
Cali 4runner Cali 4runner is offline
Cali 4runner is on a distinguished road
Cool project, way to do it right
Cali 4runner is offline   Reply With QuoteReply With Quote
Old 02-04-2018, 02:47 PM #17
Dipper95 Dipper95 is offline
Dipper95 is on a distinguished road
I'm enjoying how well you've put together each post. Good job on the pictures and links!
Sent from my XT1030 using Tapatalk
'95 4Runner
Dipper95 is offline   Reply With QuoteReply With Quote
Old 02-12-2018, 06:04 PM #18
CCDave CCDave is offline
CCDave is on a distinguished road
Replace Sunroof Phase 2
The flex tape (for masking the curves) and Black Jack controlled flow seam sealer (from Crest Industries) finally arrived so ready for phase 2.
I used an extra fuel door to practice taping, laying down the Black Jack sealer, and removing the tape (I needed more practice than this)...
CCDave's 1987 Turbo 4Runner Build
I cut a dozen or so small triangles from painters tape for marking the measured edge that the flex tape would line up with ...
IMG_1498
Placing the marks ...
IMG_1500
Laying down the tape ...
IMG_1503 IMG_1505
Could not take any photos while laying down the Black Jack and pulling up the tape, but this is right after lifting up the tape. The thickness of the sealer is not uniform so I needed more practice working the sealer with the plastic spreader. Also, I did not push out the sealer that was in the mixing tip after my fuel door practice and that small batch hardened within a few minutes. I was able to peel that up, but that cost me valuable time as the sealer starts to set within 10 minutes ...
IMG_1514 IMG_1512
After the sealer dried, the weather strip was run along the edge and then the outer frame was dropped in. The headliner was pulled tight and held in place with clamps. Working from one clamp to the next I slid the inner frame in place. The clamps were a HUGE help in keeping everything tight and in place while I screwed the inner plate in.
IMG_1518
IMG_1519
Attached and clamps removed ...
IMG_1520
Trimmed the extra headliner and the attached the trim strip to cover the screws ...
IMG_1528
5 minute wet test (no leaks!) ...
IMG_1523
Ready to ride ...
IMG_1525
What I would do different next time:
1) More practice working the seam sealer to an even, uniform thickness
2) Clear the mix tube of any sealer
2008 4Runner SR5
1987 4Runner Turbo SR5 http://www.toyota-4runner.org/classi...ner-build.html
CCDave is offline   Reply With QuoteReply With Quote
Old 02-12-2018, 08:41 PM #19
For a non factory sunroof, I think that looks really good!
Old 02-25-2018, 01:07 PM #20
quitcrab quitcrab is offline
quitcrab is on a distinguished road
Really like the way you restored the toyota badges. I am now motivated to do mine. Thanks
quitcrab is offline   Reply With QuoteReply With Quote
Old 02-27-2018, 01:39 AM #21
slow_runner slow_runner is offline
slow_runner is on a distinguished road
Wow this is one clean restoration! Makes me want a 1st gen now..
Did you put on the decal stripes yourself, or did you have them professionally installed? I'm thinking about getting a new set, but I don't want to mess it up.
slow_runner is offline   Reply With QuoteReply With Quote
Old 02-27-2018, 04:06 PM #22
Thanks! They were installed before I took ownership. Probably a good thing because even though they are a bit forgiving to install, I might have messed up one of them. Here's the decal source www.jamesdeancreations.com/1987-88.htm.
2008 4Runner SR5
Old 03-08-2018, 02:59 AM #23
RAMIREZ's Avatar
RAMIREZ RAMIREZ is offline
RAMIREZ is on a distinguished road
RAMIREZ's Avatar
Nice restore
NICE restore Dave.
where did you get the new sunroof at? i got the same model 4runner and my sunroof leak like crazy.
im just starting my build. im going to keep following your thread to keep me motivated on my truck. KEEP IT UP!!
RAMIREZ is offline   Reply With QuoteReply With Quote
Old 03-09-2018, 07:27 PM #24
Originally Posted by RAMIREZ View Post
NICE restore Dave.
Thanks.
My sunroof is an aftermarket, not OEM. I picked up the replacement from TG Automotive. Here is the Autoport 1530 that was an exact match and fit for me - SFC Autoport 1530 Complete Sunroof Kit
Depending on how old your sunroof is, you might be able to get a replacement weather strip. Mine was the older design and I could not find an exact weatherstrip replacement.
Have fun with your build/restoration and post your progress. It's helpful to see what others are doing.
2008 4Runner SR5
Old 03-09-2018, 08:19 PM #25
Hood release and start of the engine bay clean up
The hood release cable broke at the latch a few weeks ago and while waiting for the new cable I decided to start cleaning the engine bay. I cleaned the area between the coolant overflow and power steering reservoir, and that took a good 4+ hours.
Used both a wire brush and a brass wire wheel on a dremel tool to rid the metal parts of rust and oxidation, and soapy water and degreaser to clean the grime and grease ...
IMG_1601
Cleaned and repainted the mass air flow ...
IMG_1604
After brushing and polishing the power steering reservoir (it still needs more work) I created reproduction decals for it using Adobe Illustrator graphics software and a color laser printer. I printed them on waterproof silver polyester label sheets from OnlineLabels.com. This one in the pic below is my first attempt and if you look close at the ends of the top label you can see the old one underneath. The radius needs some tweaking to get it to be an exact OEM match ...
IMG_1612
2008 4Runner SR5
Old 03-22-2018, 08:10 PM #26
Decals
Fixed the radius on the PS Caution Decal. Now it sits right on top of the old one ...
PS Res Top Decal Final on reservoir
Also, made an reproduction Automatic decal for the Tailgate. The OEM is a rectangle decal with lettering, and my version is free floating letters ...
IMG_1692
2008 4Runner SR5
Old 03-22-2018, 08:59 PM #27
Now you can't swap to a 5 speed... :/ haha
Old 03-22-2018, 09:16 PM #28
Melrose 4r's Avatar
Melrose 4r Melrose 4r is offline
Real Name: Thomas
Melrose 4r is on a distinguished road
Melrose 4r's Avatar
Real Name: Thomas
Your truck is looking great!
How do you remove those B-pillar trim pieces from the truck?
Melrose 4r is offline   Reply With QuoteReply With Quote
Old 03-22-2018, 10:05 PM #29
MtBuck's Avatar
MtBuck MtBuck is offline
MtBuck will become famous soon enough
MtBuck's Avatar
i thought the "Automatic" sticker only came on the deluxe / non SR5 models?
Great work your doin, thanks for sharing the pix.
MtBuck is offline   Reply With QuoteReply With Quote
Old 03-24-2018, 11:39 AM #30
RAMIREZ's Avatar
RAMIREZ's Avatar
Nice stickers. I think im gonna have to replace my sunroof also. Ive ordered 2 glass seals and both dont work. I think i have the old style sunroof like yours.
Sent from my SM-N950U using Tapatalk
87 4runner factory every thing. I think.
Not my first toyota but this is my first 1st gen 4runner.
1987 4Runner w/Turbo value? Help? RedRunner87T Classic T4Rs 20 10-28-2013 04:11 PM
1987 Turbo 4Runner benzjed Classic T4Rs 1 01-18-2013 04:54 PM
1987 turbo 4runner blkrob22 Classifieds - buy & sell (no commercial ads please) 0 09-12-2010 07:38 PM
FS: 1987 TURBO 4Runner SR5 kellyk7 Classifieds - buy & sell (no commercial ads please) 3 11-05-2007 07:13 PM
