I took care of a variety of repairs and clean up over the past months, here's the summary:
Hood latch cable busted one Saturday afternoon. I ordered a new cable and cleaned and painted the old latch.
The brake master cylinder started leaking. Picked up a new 13/16" MC from RockAuto. I considered the 1" upgrade, but decided against it since I've had no braking issues with the stock MC. When bench bleeding the MC I could only get fluid to move through the rear port, but when I plugged the rear port the fluid flowed through the front port and was able to bleed it.
New Brake MC installed. I repainted the Booster, shield, and three way while the MC was off. I'm learning how to plate small parts, but my results haven't been good enough for finish work so I settled for using Eastwood paint (Silver Cad, Underhood Black, and Aluminum).
Fuel injector #1 started leaking so took off the plenum and other parts to get to the rail. Labeled vacuum lines to avoid future issues.
Injectors were a little dirty.
The leaky injector was the cleanest.
A little clean up while waiting for injectors to be serviced by WitchHunter.
WitchHunter did a good job servicing the injectors. I chose them from recommendations given on this and other forums.
Here's the before and after test results from WitchHunter Performance.
Injectors installed.
Everything back together.
Upper radiator hose sprang a leak at the thermostat housing. I couldn't put a new hose on a dirty thermostat housing so it was cleaned and painted, then I replaced the thermostat and painted the top tank of the radiator before installing the new upper hose.
2008 4Runner SR5
1987 4Runner Turbo SR5
http://www.toyota-4runner.org/classi...ner-build.html
