Old 03-01-2019, 09:57 PM #61
CCDave CCDave is offline
CCDave is on a distinguished road
The frame is in good shape, but could use a clean up and fresh paint. I dropped the spare and removed the spare brackets, bumper and it's brackets, tailpipe hanger, hitch, and mud flaps. Brushed and sanded the parts and the frame from the diff back, then applied POR-15 treatment to everything. After the POR-15 paint dried, I sprayed on a couple of coats of POR-15 Top Coat. I've seen other metal prep and paint products, but I'm happy with the results of the POR-15 product.
Some BEFORE pics ...
Spare-Tire-Mount
Rear-Mud-Flap-Brackets
Rear-Bumper-Brackets
I replaced an adjustable shower curtain rod in my house 3 years ago, but couldn't bring my self to throw it away. I finally found a use for it ...
Parts-Painted-with-POR-15
Drying-after-POR15-application
Installed parts with all new bolts ...
Restored-Rear-Parts-Installed
In the lower right of the last photo you can see what kind of shape the shocks are in - rusty and worn out. I ordered a new set of KYB shocks (OEM ride) from RockAuto and new set of hardware from ToyotaPartsDeal.
2008 4Runner SR5
1987 4Runner Turbo SR5 http://www.toyota-4runner.org/classi...ner-build.html
CCDave is offline   Reply With QuoteReply With Quote
Old 03-02-2019, 12:53 AM #62
Cali 4runner Cali 4runner is offline
Cali 4runner is on a distinguished road
Nice work! I need to do that too..
Cali 4runner is offline   Reply With QuoteReply With Quote
Old 03-03-2019, 10:17 AM #63
Thanks.
I was surprised how accessible the back section of the frame, etc. became after removing the brackets and bumper. It made it much easier to check everything out and do the work.
2008 4Runner SR5
Old 03-16-2019, 04:55 PM #64
Another round of plating and detailing
Another round of electroplating old parts. Finished the Cruise Control Actuator parts, EFI Resistor bracket, Charcoal Cannister bracket, and various bolts, screws, and clamps.
Some Before and After shots. The one clamp had such a buildup of grime that I didn't realize there was a number on until after the degrease bath:
Bolts-Clamp-Nuts-B-and-A
This was the first time using a Blue Chromate finish and am very happy with the way the clamps turned out. The not too clean one in the middle was too far gone with rust and pitting to save.
Blue-Chromate-Plating
Cruise Control Actuator parts reassembled and final assembly of the parts on their bracket:
Cruise-Control-Actuator-Assy---Assembled
Right side of the engine bay after installing the replated parts:
Detailing-Right-Side-of-Engine-Bay-1
2008 4Runner SR5
Old 03-18-2019, 12:55 AM #65
Holy cow, that is awesome
Old 03-19-2019, 09:08 PM #66
Thanks!
I read that the original factory finish on parts in the engine bay will last 3 to 5 years, after which the finish (not the metal) will begin to oxidize or wear down. I'm not sure how accurate this is, so curious if anyone has any experience with this.
The before and after of the Pressure Control Valve Assy:
1987-22RTE-Pressure-Control-Valve-Assy---Restored
2008 4Runner SR5
Old 08-09-2019, 09:56 PM #67
Timing Chain Guide Finally Gave Out
Started hearing an unusual knock and an idling problem about a week ago so I pulled the valve cover to inspect the valve clearances and timing chain. The valves are good, but the plastic timing chain guide finally gave out.
Short video: Broken Timing Chain Guide Aug 8 2019 | djaeger22 | Flickr
If you look closely you can see the chain started cutting grooves on the inside wall of cover.
2008 4Runner SR5
Old 08-24-2019, 10:12 AM #68
Exhaust Manifold Gasket
With the timing chain guide needing replaced I decided to pull the head and get it inspected. I pulled the exhaust manifold yesterday (yes, I'm working slow on this project) and I found the front forward-most bolt was not tight and would not tighten.
Here's a photo of both sides of the exhaust manifold gasket. I count 3 leaks with one near the loose bolt (upper left in the top photo). At least now I know why I was hearing a faint sound of an exhaust leak.
Exhaust-Manifold-Gasket-Inspect
2008 4Runner SR5
Old 08-29-2019, 05:22 PM #69
Ser1clymb's Avatar
Ser1clymb Ser1clymb is offline
Ser1clymb is on a distinguished road
Ser1clymb's Avatar
When you are plating, do you have to protect the non-metal parts? Do you cover those parts or just not "dip" them?
Amazing work by the way. I look forward to seeing where this goes.
"Bettie" - 1998 4runner LTD E-Locker Evergreen Pearl 275K+, Alpine HU, Infinity Reference Speakers, Airraid MIT, B&M Cooler, Light Racing UCA, RCI skids, Bilstein Tundra 5100 and 4runner Eibach Coils in front/ Bilstein FJ 5100 and OME 890 rear, LC80 wheels wrapped with MT Baja ATZ 285/75/16, 99+ overhead console, 99+ center console, sound-deadening, Ditch lights
Ser1clymb is offline   Reply With QuoteReply With Quote
Old 08-30-2019, 10:15 PM #70
Thanks! I don't know if I have to, but I avoid dipping non-metal parts just to be safe. I carefully disassemble parts to separate the metal from non-metal, but if that's not possible I keep the non-metal out of the chemical clean and acid baths.
If you're considering plating your own parts, think safety first. Get the right breather, full coverage goggles, and set up in a ventilated space.
2008 4Runner SR5
1987 4Runner w/Turbo value? Help? RedRunner87T Classic T4Rs 20 10-28-2013 04:11 PM
1987 Turbo 4Runner benzjed Classic T4Rs 1 01-18-2013 04:54 PM
1987 turbo 4runner blkrob22 Classifieds - buy & sell (no commercial ads please) 0 09-12-2010 07:38 PM
FS: 1987 TURBO 4Runner SR5 kellyk7 Classifieds - buy & sell (no commercial ads please) 3 11-05-2007 07:13 PM
