Old 03-05-2018, 04:10 PM #31
eli.sanchez.3344 eli.sanchez.3344 is offline
Real Name: Eli
eli.sanchez.3344 is on a distinguished road
Real Name: Eli
Awesome truck and workmanship. I just finished building a 1995 Limited 3.0 4x4. Drove it from California to Michoacan Mexico for some desert running and a bit of crawling. Left it out there and its still running strong with 205 k on her. These are great rigs.
eli.sanchez.3344 is offline   Reply With QuoteReply With Quote
Old 03-05-2018, 06:13 PM #32
1990silverbullet 1990silverbullet is offline
Real Name: Rylee
1990silverbullet is on a distinguished road
Real Name: Rylee
Thank you I try my hardest.
1990 grey runner. 3.0 with a 5 spd (180100 miles)
1991 gold runner 3.0 with auto.(doesn't run but will soon(228,000))
1990silverbullet is offline   Reply With QuoteReply With Quote
Old 03-09-2018, 12:50 PM #33
Real Name: Rylee
Real Name: Rylee
So I noticed my shifting was getting a little crunchy. I could hardly get it into reverse or 5th.I saw a thread on yotatech about replacing the shifter seat and cap. I ordered the shifter seat and cap it was only like 10$ from Toyota. I was surprised on how good it shifted after I saw the bushing that was in there. After I replaced the seat and cap it was amazing. It is nice and tight and shifts really smooth.
the first pic is of the old and new seat. The one in the front was the one that I pulled out. There was none of green rubber left.As for the cap it was pretty worn to.
1990 silver bullet runner-img_20180308_182107-jpg  1990 silver bullet runner-img_20180308_182116-jpg  1990 silver bullet runner-img_20180302_141034-jpg
Old 03-15-2018, 07:35 PM #34
Real Name: Rylee
Real Name: Rylee
So I've developed a high idle. On Cold mornings it idles at 2100 cold then at about 1700 warm. I Cleaned my throttle body and now it idles at 1500 cold and 1200 warm. I also replaced a lot of the vacuum hoses from a kit I got from LCE. Is this normal? what does every one else's truck idle at?
Old 03-15-2018, 08:14 PM #35
128keaton's Avatar
128keaton 128keaton is offline
Real Name: Keaton
128keaton is on a distinguished road
128keaton's Avatar
Real Name: Keaton
Mine idles at 800-1000 warm and 1300 cold.
Not normal. I'd bet you had a vacuum leak that made it idle low, but now that the hoses are new, your idle has been thrown. I'd adjust the idle down and clean your EGR valve.
[DD]2003 Lexus LX470 - Black Onyx - Stock
[SOLD]2000 Toyota 4Runner - SR5 - White - 5-Speed - Toyota E-Locker (4.10s )- 620LB Eibach/OME 890 - 33" Falken Wildpeak ATs - 4x4 - 164k and climbing
[RIP] 1993 Toyota 4Runner - SR5 Sport - Black Onyx - 5 Speed - 31" Bridgestone Dueler ATs - 4x4 - Cracked Block at 254976 RIP
128keaton is offline   Reply With QuoteReply With Quote
Old 03-16-2018, 10:45 AM #36
Real Name: Rylee
Real Name: Rylee
So this weekend if I have time im going to take the whole throttle body off and deep clean it really good. After I put it back on and ill mess with the idle down and clean the EGR. Thanks for the ideas ill let you know if it fixed anything.
Old 01-16-2019, 02:45 PM #37
Real Name: Rylee
Real Name: Rylee
Im back and need a little help
Hey there everyone. I have not drove my runner in a little a couple months and she needs some love again. I haven't had time to drive her because of my work hours and I live in a bigger city so I drive my car for better gas mileage. I finally have time to take my favorite whip out and when I started it the other day it was making some funky noises from the timing cover.I'm guessing that it's from the tensioner and idler bearing that we took from my spare runner like half a year ago. I have all of the parts now. I was just wondering if anyone had some good tips and tricks for replacing it. If not does anyone have a good thread I could look at?
Old 01-16-2019, 03:26 PM #38
mholme's Avatar
mholme mholme is offline
mholme is on a distinguished road
mholme's Avatar
90-95 Toyota 4Runner Factory Service Repair Manual
That’s an online manual you can follow. I didn’t read your entire thread, but there are probably some “while you’re in there” items that should be replaced.
mholme is offline   Reply With QuoteReply With Quote
Old 01-18-2019, 05:32 PM #39
Ahlem Ahlem is offline
Ahlem is on a distinguished road
I'd suggest taking a good look at the timing belt to be sure it's running true.
If something is out of alignment on the idlers it will push the belt forward or back and it will start eating itself up. BTDT.
Ahlem is offline   Reply With QuoteReply With Quote
Old 02-16-2020, 02:22 PM #40
Real Name: Rylee
Real Name: Rylee
So I haven't posted her for awhile. My 4runner was resting while I got some time to work on her. I started my timing belt and it seems the one of the bolt holes for the water pump is stripped out. What could I do to fix it do I have to re tapp it or is there a little sleeve I could get? Any help is appreciated
1990 silver bullet runner-20200216_105634-jpg  1990 silver bullet runner-20200216_111435-jpg
Old 01-14-2021, 03:27 PM #41
Real Name: Rylee
Real Name: Rylee
Hey, afternoon. I'm in need of some help. I replace my timing belt and water pump and it went well but after about a month it started spraying anti freeze on the bottom of the hood and it started peeling paint. it was also overheating after a couple mins of driving. Would this be a symptom of a bad water pump? or maybe something different... If anyone has any ideas please let me know.
1990 silver bullet runner-4runner-jpg
Old 01-14-2021, 04:42 PM #42
Nobody Special's Avatar
Nobody Special Nobody Special is offline
Real Name: Special Ed
Nobody Special is a jewel in the rough Nobody Special is a jewel in the rough Nobody Special is a jewel in the rough
Take a few pics of the engine from different angles. Front, sides...
Did you get all the air out?
Air in there can allow steam to build.
N̷̢̗̪̗̞̯͈̥̐̉͌͜͝O̴̢̨͚̭͕̾B̶̪̩̙̰̩̟̪͓̠̫̉̏̀͗̀̾͒̏̐̽O̵̾̏̈ ̨̡̖̬̀͂̒͂͂̃D̷̯̪͙͍͖͙̰͒̈Y̸͎̗̝͍͌̑̆͂̈́͘̕
Nobody Special is offline   Reply With QuoteReply With Quote
Old 08-17-2021, 11:12 AM #43
Dannyw Dannyw is offline
Dannyw is on a distinguished road
Really enjoy your thread
Dannyw is offline   Reply With QuoteReply With Quote
Old 12-07-2021, 03:34 PM #44
smelliott's Avatar
smelliott smelliott is offline
smelliott is on a distinguished road
smelliott's Avatar
Subscribed. I have the same silver 90 model. Going to be coming back here for a little inspiration.
smelliott is offline   Reply With QuoteReply With Quote
My 1990 4 Runner Gatti Classic T4Rs 31 02-21-2016 10:51 PM
1990 Runner 01yz426 Classic T4Rs 0 08-12-2014 12:09 AM
AFE Silver bullet installed. Aquabear 4th Gen T4Rs 11 07-04-2011 05:06 PM
FS: 1990 4 Runner SR5 V6 formulaz Classifieds - buy & sell (no commercial ads please) 0 06-09-2006 06:49 PM
1990 4 Runner ChicagoD Classifieds - buy & sell (no commercial ads please) 1 07-19-2005 08:13 PM
