Originally Posted by 1990silverbullet
Thank you!! Does any of you know if a ps pump from a 1991 3.0 will fit in my 1990 3.0. I have a 1991 as a donor car. would it be a direct fit?
If they're the same engine then yes. FYI, be careful when removing the return hose, they like to disintegrate.
There should be a two wire switch on the front differential, it's right next to the actuator. I would start there. Another possibility is that the actuator for the front diff is stuck on. let me know what you find, I have both volumes of the factory service from toyota, complete with all wiring diagrams.
