Old 10-06-2017, 12:08 AM #1
4Reak Show's Avatar
4Reak Show's Avatar
Power antenna override switch
Working on this. Issue is, aftermarket stereo energizes relay and raises antenna no matter which source I'm at. I'm rarely on AM/FM so I wanted control. Wheeling with a power antenna dancing around while on iPhone music uselessly is pointless and can cause damage and more work at some point.
So far I plucked some wires at the relay module at found the right one that comes from the stereo to energize. Next is to wire in a toggle switch so I have ultimate control.
Fun fact: Chuck Norris's computer doesn't have a CONTROL button... He is ALWAYS in control.
Update by the end of the weekend of anyone cares.
Old 10-06-2017, 11:26 AM #2
djelectron's Avatar
djelectron djelectron is offline
Real Name: Duane
djelectron is on a distinguished road
djelectron's Avatar
Real Name: Duane
I've been thinking about this exact same thing. In my 94, a solid connection through the radio's relay between the Black-Red wire and the Pink-Blue wire in the radio harness activates the Auto Antenna Control Relay. The radio harness wires are probably the easiest to get to. Throw a switch in-line on one of those, and you're good to go.
1994 Toyota 4Runner SR5 4WD 3.Slow Auto
Youtube: OceansOverlandUSA Instagram: @OceansOverland
toyota-4runner.org: Official Build Thread
Setting out on a big trip Spring 2024! More to follow soon!
PM me for link to 94 Factory Service & Electrical Manual
djelectron is offline   Reply With QuoteReply With Quote
Old 10-06-2017, 11:39 AM #3
4Reak Show's Avatar
4Reak Show's Avatar
Thanks. The pink/blue I plucked out of the relay connector for testing seemed to shut down the antenna so that's the first one I'm going to try. Shitty part about going after the radio is that I've had this dash apart so much over the years none of the screws are holding in very well anymore haha. I'm probably just going to run a couple wires from the relay itself and try not to disturb the dash. This was supposed to be a quick deal and id like to keep it that way.
Should be able to confirm today or tonight depending on time.
Old 10-06-2017, 04:38 PM #4
4Reak Show's Avatar
4Reak Show's Avatar
Done! Used pink/Blue at relay, cut it and ran switch in line. Switch also has LED so ran a ground for it to energize when antenna is up. Works like a charm. I have a video but no YouTube account so if anyone wants to see it I'll gladly email the video.
Old 10-06-2017, 09:04 PM #5
djelectron's Avatar
Real Name: Duane
djelectron's Avatar
Real Name: Duane
That's awesome 4Reak! I'll have to try that next.
My dash is the same as yours... We need to get some larger thread screws with a head that fits the holes.
I'll post your vid if you want. I'll pm you my email.
Old 10-06-2017, 10:10 PM #6
4Reak Show's Avatar
4Reak Show's Avatar
Yeah that sounds good man shoot me your email. Appreciate it
Old 05-05-2024, 06:29 PM #7
djelectron's Avatar
Real Name: Duane
djelectron's Avatar
Real Name: Duane
I am guessing you must have wired yours properly. I am also thinking I misread the schematic...
I think we need power on both the Pink / Lt. Blue as well as the Black / Red or at minimum just the Black / Red. Looking at the schematic, the logic gates (from L to R) call for power from:
  1. Radio Fuse AND Instrument Cluster
  2. Gate 1 OR the Player (Din-size OEM CD I'm guessing?) without Gate 3 to Lower the Antenna
  3. Gates 1 & 2 AND Power from the Radio output to Raise the Antenna
I only connected the Pink / Lt. Blue to my Remote Out on my stereo. Looks like I should have wired it together with the Black / Red instead or with both together. Duh. I also think my switch should have gone in-line on the Black / Red or both that and the Pink / Lt. Blue combined. Wordy, I know. Does that make sense?
Having just put everything back together... I think I'll wait to mess with that again. I listen to downloaded or streaming 99% of the time anyway, but I do want the radio to work properly.
Can anyone confirm both wires or just the Black / Red need to be connected to the Remote Out for the antenna to function properly?
Power Antenna Toggle Switch jaredking733 3rd gen T4Rs 15 11-02-2018 10:54 AM
Power antenna switch Fit4Action 3rd gen T4Rs 19 05-03-2018 11:44 AM
power antenna switch or Tacoma whip antenna? hrt4me 3rd gen T4Rs 18 07-08-2013 10:09 PM
Power antenna toggle switch zgensler31 3rd gen T4Rs 6 05-19-2013 11:46 PM
Power Antenna Switch 004Gunner 3rd gen T4Rs 13 06-30-2008 10:21 AM
