Old 03-19-2018, 01:34 AM #31
O.B.A.K's Avatar
O.B.A.K O.B.A.K is offline
O.B.A.K is on a distinguished road
O.B.A.K's Avatar
Thanks curserunner!
O.B.A.K is offline   Reply With QuoteReply With Quote
Old 03-20-2018, 01:45 AM #32
128keaton's Avatar
128keaton 128keaton is offline
Real Name: Keaton
128keaton is on a distinguished road
128keaton's Avatar
Real Name: Keaton
How does your rig handle on the highway? Also--HOW are you getting 20-19 MPG. I run 87 sometimes 89 and get, on the highway, 13.45 mpg no matter what. Going up hills with people in the back? 13.45. Heading on I-40 for 200 miles with no climbing or crazy passing? 13.45. Coupled with the shaking and the still loose steering, I just avoid highways.
[DD]2003 Lexus LX470 - Black Onyx - Stock
[SOLD]2000 Toyota 4Runner - SR5 - White - 5-Speed - Toyota E-Locker (4.10s )- 620LB Eibach/OME 890 - 33" Falken Wildpeak ATs - 4x4 - 164k and climbing
[RIP] 1993 Toyota 4Runner - SR5 Sport - Black Onyx - 5 Speed - 31" Bridgestone Dueler ATs - 4x4 - Cracked Block at 254976 RIP
128keaton is offline   Reply With QuoteReply With Quote
Old 03-20-2018, 02:24 AM #33
O.B.A.K's Avatar
O.B.A.K's Avatar
Hey Keaton! My rig loves the highway honestly. It’s not winning any races, but if I can hit hills at 70-73 I can pull a lot of them in fifth, even if I end up doing 60-63. No shakes, no pulls, I am getting comfortable with taking 4th gear up to around 3300-3500 sustained to keep with traffic. That being said I try to stay out of the throttle as much as possible and let the truck set the pace - old 22re habits. I do have the knock sensor bypass (code 52) so I try not to bog it too much and err on the side of downshifting if I feel like it’s getting loaded.
I think there is a bunch of factors that go into the mpg.
Motor: cleaned injectors with fresh seals on them, valves cleaned and clearanced, oem plugs/wires/distributor, EGR/cat delete, fresh rings, synthetic 5/30, oem exhaust
Drivetrain: ADD delete, 5speed manual (this is a big one I think), 4.56 gears, synthetic fluids in all cases
Tires: 33.10.5.15 ko2’s which are lighter than most tires as well as not an overly beefy tread + aluminum SR5 rims
Other: I deleted the AC compressor and belt - I have had mixed reviews from old toyota guys. Some people say it makes no difference because if it’s on the truck but not on it doesn’t tax the system. I was the one that pulled it off and I saw the pressure that AC system had in it, pretty incredible. Kind of like your ADD hubs we talked about, they could be moving even when disengaged - I felt that way about the AC.
Making sure no breaks are dragging all the way around and that the hubs, bearings and joints are well greased and in good working order.
I have noticed a difference with running premium fuel.
Keeping the weight down with just the minimal amount of gear and no giant bumpers - I could probably get more if I pulled the roof racks off, but I really like the look and don’t get any extra sound from it. I will probably pull them next winter.
Sensors are another issue - I replaced the ignition coil module with a used module (was throwing a code), also replacing the fuel filter. The big one here was replacing the o2 sensor with a denso oem one - even though it never threw an o2 code.
Advanced timing to between 11-13 (possibly lessened the mpg, but I felt like i would be better off staying out of the throttle and letting the advance work then fighting the pedal and gears to keep up good speed.
Tires run at a firmer pressure.
And that’s basically it. Honestly I went from 15-16 average in town to 18 in one tank, had been running a few thousand at the lower average. They run the same kind of gas year round up here, so I can’t account it to that. I think the motor is just finally breaking in after the rebuild.
Old 03-20-2018, 09:12 AM #34
128keaton's Avatar
Real Name: Keaton
128keaton's Avatar
Real Name: Keaton
My truck sounds extremely similar to yours regarding what I've done. I still have smog/emissions and A/C (essential down here in Redneck swamp kuntry). 5speed, 4.56s, still have my OEM cat though, advanced to 12*, new O2, but I run smaller tires. Thinking about deleting ADD but that was one of the neatest features of the truck new. With the big 'ol roof basket off I wonder now if I get any better MPGs. That and keeping to 70 MPH. Too bad it shakes the sh*t out of you at that speed. Thanks for the info.
Old 03-20-2018, 01:54 PM #35
Dropzone's Avatar
Dropzone Dropzone is offline
Dropzone is a jewel in the rough Dropzone is a jewel in the rough Dropzone is a jewel in the rough
Dropzone's Avatar
The first long trip this last weekend went well (Palmer south to Seward, Alaska). Playing around with gas mileage numbers/fuel types and I am finding that I am getting better gas mileage with premium fuel. Average speed was 70 mph over 200 miles, and I averaged 20 miles a gallon even with some steep climbs in 4th. Tires were at 37 PSI. I still need to address the rear shock mounts, but only managed to bottom out once on the drive through the mountains. Interestingly enough running low-grade fuel and reducing the average speed to 60 I lost a 1 mpg, even the route was more downhill than going in. I figure I am splitting hairs with the cost-benefit of premium vs. not, but I kind of like the experimentation. It does run better on premium. Some pictures from the trip are attached.
Looking towards this summer as far as mods go I am planning on making some changes:
CVT RTT on rear 3 roof bars
ARB 2500 Awning
Yukon grizzly rear locker w/master rebuild kit for the diff
Rear seat delete-build boxes in the area
OME rear HD 1.5" lift springs
Relocate rear lower shock mounts
Move fog lights and light bar inside bumper
CB radio
4-crawler track bar bracket
Mudflaps
Secondary to all of that I would like to get all the chrome plasti-dipped to match the body color, and get the rims powdercoated gun-metal grey.
Attachment 289941
Attachment 289942
Attachment 289943
Attachment 289944
Attachment 289945
Attachment 289946
crap I miss living in alaska!
Adding that air brake CVT tent will cut your mileage a bit but it will be worth it. Nice being off the ground when camping
1994 4Runner AKA: Project Recycle
@503dropzone on IG
Dropzone is offline   Reply With QuoteReply With Quote
Old 04-16-2018, 06:51 PM #36
O.B.A.K's Avatar
O.B.A.K's Avatar
Got the RTT and awning mounted up and few test sleeps the last couple weekends. I sleep great on the memory foam, and it is super handy not to have to pull everything out of the back to go to bed. I am getting around 17.5 mpg city these days, driving conservatively. It is definitely a kite up there on the roof, but not as bad as it looks. It took some finesse to get the yakima bars and track mounts on the tent where I wanted it, but it ended up good. I am still in the process of trusting the tent up there at highway speeds, but getting more comfortable by the day.
Speaking of comfort, I ended up measuring my shock mounts and getting a rear shock that was about 3" shorter than what I had on there. Just some oreilly cheap thing, not even sure about the application. I had to drill out the stud holes on one end to work but got them on there. It solved my bottoming out issue I was having, which is great not to have to worry about.
I saved my old shocks because eventually I will go with cruiser coils in the rear and those shocks will work with that application.
Got all the gear sorted out and looking forward to hitting the road this summer!
1995 4runner DD/adventure rig "Killbox"-fullsizeoutput_1276-jpg
1995 4runner DD/adventure rig "Killbox"-img_4902-jpg
1995 4runner DD/adventure rig "Killbox"-img_4908-jpg
1995 4runner DD/adventure rig "Killbox"-img_4942-jpg
Old 04-17-2018, 12:21 AM #37
128keaton's Avatar
Real Name: Keaton
128keaton's Avatar
Real Name: Keaton
Attachment 293477
Attachment 293478
Attachment 293479
Attachment 293480
Man I'm always worried about the shear factor on the bolts. A rooftop tent looks amazing though.
Old 04-17-2018, 01:13 AM #38
CurseRunner CurseRunner is offline
CurseRunner is on a distinguished road
Attachment 293477
Attachment 293478
Attachment 293479
Attachment 293480
Wish my runner came with roofrails. I wonder how hard it would be to install factory rails if you're runner never came with them...
'92 4runner 4x4
CurseRunner is offline   Reply With QuoteReply With Quote
Old 04-17-2018, 09:52 AM #39
Dropzone's Avatar
Dropzone's Avatar
O.B.A.K: the mileage is awesome with the tent up there!
actually not too bad. i extended my factory rails about 20". I used a 1/4-20 nutsert kit off amazon
20180322_124327 by ocdropzone, on Flickr
i drilled the holes, just barely punching through the sheet metalI just sealed the holes with a liberal dose of silicone. 2 years later no leaks.
sorry for the thread jack
@503dropzone on IG
Old 04-17-2018, 11:54 AM #40
O.B.A.K's Avatar
O.B.A.K's Avatar
Your welcome to pop in any time dropzone!
Old 04-17-2018, 07:39 PM #41
DannyBFresco's Avatar
DannyBFresco DannyBFresco is offline
DannyBFresco is on a distinguished road
Sweet build! Definitely how I see mine turning out until I can afford to dive down the SAS rabbit hole. It's also awesome to see you're getting some solid gas mileage out of your 3.0
2006 SWB Tacoma TRD Sport 4x4
1995 T4R 3.0 4x4 (SOLD)
1996 FZJ80 Land Cruiser
DannyBFresco is offline   Reply With QuoteReply With Quote
Old 04-18-2018, 12:44 AM #42
O.B.A.K's Avatar
O.B.A.K's Avatar
Thanks Danny. Yeah the whole gas mileage thing has been the biggest surprise of this whole build. If I dropped down to 31’s I could probably break 20! I am pretty happy with the way the build turned out. Some days I look at it and want more stance-12.5” wide tires and offset rims or wheel spacers.
I think second phase of this build will be land cruiser coils in the rear, and it’s a toss up with what happens up front. I’ve read a lot about the blazeland long travel kits, and since it’s such a daily I am leaning towards that option more than an SAS at this point.
Old 04-18-2018, 10:33 AM #43
Chazzmatazz's Avatar
Chazzmatazz Chazzmatazz is offline
Chazzmatazz is on a distinguished road
I’m very interested in the awning you are running. What brand is it? Thanks and keep up the work!
1995 SR5 4Runner | 3.4L 5VZ-FE | 5 Speed | Daily Driver
Chazzmatazz is offline   Reply With QuoteReply With Quote
Old 04-18-2018, 12:20 PM #44
Right on, yeah long travel is fun. I'm building my 06 Tacoma with LT currently, so that's why I'm leaning SAS. LT is a lot of maintenance though, and I think if you did the SAS right you could be pretty comfy riding around daily. However, LT is really cush and fun off road lol.
Old 04-18-2018, 11:58 PM #45
O.B.A.K's Avatar
O.B.A.K's Avatar
Hey Chazz thanks! The awning is a Tepui. 6x6 deployed, bought it through REi and had it delivered to my local store. ARB also makes a nice one that I was leaning towards, but this one had the right price with a discount.
Rock Rat's Imperial Jade Mica "Next Adventure" Build Rock_Rat 3rd gen T4Rs 404 08-06-2020 09:04 PM
"The Stormtrooper" 4thGen 4Runner build/adventure/shenanigans thread Roody 4th Gen T4Rs 21 12-07-2018 09:08 AM
"Crazy Cows" - Our 2017 Overland Adventure SS_Syndicate Off Topic 7 08-09-2017 03:38 PM
NateMob's "Bump-It!" Adventure/Build Thread NateMob 4th Gen T4Rs 61 06-16-2016 05:17 PM
