Old 01-25-2018, 10:44 PM #1
Racerzl1 Racerzl1 is offline
Racerzl1 is on a distinguished road
1994 T4R not getting fuel.....
Got a good deal on a 94 T4R and its not getting fuel to the engine. Is there a fuse just for this? How can I check for power going to the fuel pump without dropping the tank? Also noticed fuel gauge is not working.
Any ideas?
Fuel pump doesn't make any noise when key is turned on....
2004 4Runner 4WD, V-6 , Limited, 186000 miles, ToyTec Lift, Nitto Terra Grapplers -265-70-R17 , Interior LED lighting upgrade, Scion Stereo, K&N a/f, HCF Delete, Bull Bar, 12VDC+ mod.
Racerzl1 is offline   Reply With QuoteReply With Quote
Old 01-25-2018, 10:48 PM #2
also...
Also, I have checked the 15amp Efi fuse under the hood in the fusebox and it is good.
Previous owner stated that vehicle was running fine , then sat up for 3 months, then wouldn't start, only turn over.....
Old 01-26-2018, 12:01 AM #3
White94runner's Avatar
White94runner White94runner is offline
White94runner is on a distinguished road
My nephews truck (89 Toyota pickup) just recently had a similar issue and it ended up being a ground wire from the sending unit in the tank had come loose. I would get a volt meter/ test light and check all the wires to and from sending unit to see if pump is working. If all is good check fuel filter and test fuel pressure if the pump is working
White94runner is offline   Reply With QuoteReply With Quote
Old 09-02-2019, 02:57 PM #4
rsquaredatx rsquaredatx is offline
rsquaredatx is on a distinguished road
I have almost this same exact issue.
1994 V6 3.0
Previous owner said he came out one day and it didn't start. It sat 8 months before I got it.
When I jump FB and V+, the fuel pump runs.
When I open the door inside the air filter, the fuel pump runs.
There are no engine codes at all.
The filter "looks new", as it is black and shiny on a very dirty 4R.
Fuel gauge is not reading, so I'm assuming it just has a bad sending unit.
When it turns over, it will sort of "fire" for about 3-4 seconds...and then die.
If I spray carb cleaner or starting ether in the intake it will run 5-8 seconds and then die.
I've read about COR and MAF and AFM. Any advice on what to check next?
Thanks from a Noobie!
1994 4Runner
v6
rsquaredatx is offline   Reply With QuoteReply With Quote
Part number fuel return line at Fuel press. Regulator nissanh 3rd gen T4Rs 3 12-18-2017 12:18 PM
Fuel leak stops. Now have a blue liquid on outside of fuel filter. Hard start getting 3rdgen_4runner 3rd gen T4Rs 2 09-05-2017 10:23 AM
1994 4 runner v6 fuel leak pharaohjoe Problems & Warranty Issues 0 08-26-2014 06:38 PM
Fuel Starvation / 1994 4R 3.0L FI / Need help rockinhorse77 Classic T4Rs 3 08-01-2013 08:26 PM
PG011R-05 06/09/2006 Fuel System - Fuel Injector Cleaning Procedure CBR_GUY_IA TSB 0 07-12-2009 09:44 PM
