08-08-2019, 02:19 PM
#47
A lot of this went way over my head but I’ll be following all the same
10-15-2019, 09:02 PM
#48
Real Name: Nate
Real Name: Nate
Well I got the rear suspension cut out and the 14 bolt tacked in. I never knew how soft 63s in a 4runner were! This things gonna ride like a poor mans Cadillac. Need to finish freshing up the transmission, then get those set in to see where its going to live and how much tunnel im going to have to cut.
I also rebuilt the clutch pedal assembly and got that installed.
10-16-2019, 10:19 AM
#49
Looking good. Yea the 63s are really soft back there. Im running the 4leaf pack with a AAL to match the front TG 4" springs. Although I think the front has settled enough I may need to make some changes in the rear now.
Im really interested see more of the motor swap. Ive been tempted to swap to a manual trans behind my 4.3 and ive also been tempted add another number a drop a 5.3 in it lol.
'90 Vortec 4.3Runner
10-21-2019, 10:45 PM
#50
That 450HP V8 would look good in my '92 T4R. Although merging on to the freeway would be much less "sporting".
10-22-2019, 06:44 AM
#51
Cool build Nate. When you say you are trying to keep it low, are you talking 35s? 37s?
‘99 UZJ 100 factory locker with OME and ST Maxxs
‘89 VN60 with OME and BFGs
12-08-2019, 10:27 AM
#52
Real Name: Nate
Real Name: Nate
40s I’ve always ran 40s on my builds. I’m trying to keep it low on 40s, there’s a lot of body carving in the near future.
12-21-2019, 12:03 AM
#53
Real Name: Nate
Real Name: Nate
12-28-2019, 03:00 PM
#54
Fascinating. Thanks for showing us your progress with this build.
92, V-6, AT, 31x10.50, 4.88, Leather interior, purchased:1/24/11 with 192,194 miles. New Toyota dealer installed timing belt, timing belt pulley, water pump, T-stat, acc. belts: 12/6/11, 202,475 miles. 242,xxx miles as of 12/08/14. 252,xxx miles as of 08/22/15. 282,xxx miles as of 2/12/18.
KYB Monomax Performance Gas Shocks 565058-front
KYB Monomax Performance Gas Shocks 565059-rear
Moog CC255 Variable Rate Rear Springs
12-30-2019, 01:13 PM
#55
Real Name: Nate
Real Name: Nate
02-03-2020, 12:31 AM
#56
Real Name: Nate
Real Name: Nate
02-05-2020, 10:34 AM
#58
Cool build! And some really nice work going on here!
I really like the low height of your Chevy 63s. This is my plan for the rear of my upcoming slow build. How much lift did you get from them? Do you have any pics of how you set up the mounts and stuff? Hope you don't mind me picking your brain a little, just over here doing some research...
If ya always do what ya always done, Ya always gonna get what ya always got.
02-05-2020, 02:45 PM
#59
It sure is worth the wait to see photos of your build. Thanks again for sharing them.
05-07-2020, 12:16 AM
#60
Real Name: Nate
Real Name: Nate
The most expensive part is in. It’s all down to making it work now.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
