Old 04-22-2018, 01:57 AM #31
GonOvr's Avatar
GonOvr GonOvr is offline
Real Name: Nate
GonOvr is on a distinguished road
GonOvr's Avatar
Real Name: Nate
No worries there. This thing won’t see 1/4 of the load it would see being used in a towing application. These hold more oil too since the bearings get oiled from the diff.
Project 1-Ton Build Thread**SOLD**
Project 1-Ton Build Thread**Current Rig**
GonOvr is offline   Reply With QuoteReply With Quote
Old 04-22-2018, 05:12 PM #32
Cali 4runner Cali 4runner is offline
Cali 4runner is on a distinguished road
Right on, makes sense.
Thanks for the info!
Cali 4runner is offline   Reply With QuoteReply With Quote
Old 06-02-2018, 06:18 PM #33
GonOvr's Avatar
Real Name: Nate
GonOvr's Avatar
Real Name: Nate
Found some motivation to get some stuff done.
IFS pulled out
Got the liquid wrench out and started cutting all the frame mounts off.
Mounted the front hanger and I think I’m going to keep it set to the rear. My springs are already center pin forward.
Old 06-03-2018, 06:50 PM #34
GonOvr's Avatar
Real Name: Nate
GonOvr's Avatar
Real Name: Nate
Finally! Clean frame rails!
Old 06-30-2018, 10:42 PM #35
Number_6's Avatar
Number_6 Number_6 is offline
Number_6 is on a distinguished road
Number_6's Avatar
Originally Posted by 128keaton View Post
They continued this with the 3rd gens--poor choice imho
I think it went company wide. On my 2000 LC when the door opens the map lights stay off. If your door is shut, map lights only- unless you want to reach back and turn the midship on in the headliner.
Number_6 is offline   Reply With QuoteReply With Quote
Old 07-01-2018, 12:47 AM #36
128keaton's Avatar
128keaton 128keaton is offline
Real Name: Keaton
128keaton is on a distinguished road
128keaton's Avatar
Real Name: Keaton
Its actually not as annoying as I thought. I now have a 3rd gen
[DD]2003 Lexus LX470 - Black Onyx - Stock
[SOLD]2000 Toyota 4Runner - SR5 - White - 5-Speed - Toyota E-Locker (4.10s )- 620LB Eibach/OME 890 - 33" Falken Wildpeak ATs - 4x4 - 164k and climbing
[RIP] 1993 Toyota 4Runner - SR5 Sport - Black Onyx - 5 Speed - 31" Bridgestone Dueler ATs - 4x4 - Cracked Block at 254976 RIP
128keaton is offline   Reply With QuoteReply With Quote
Old 12-15-2018, 10:55 PM #37
GonOvr's Avatar
Real Name: Nate
GonOvr's Avatar
Real Name: Nate
Progress and changes..
Well I decided to go with a manual so I swapped the th400 np205 and got a nv4500 5 speed and an atlas 4 speed.
I got the front end setup with a Detroit and Yukon 5.13, Yukon chomo 35 spline inners and outers with Yukon super joints, barnes 4wd high steer arms.
The rear now has a Yukon spool and 5.13s with Chromo axles.
Got some used 63” Chevy springs from a friend and I found some used 5” non-hd trail gear springs local. The front spring hanger is now burned in and shackles are set.
The engine is just about rebuilt, got a Texas speed cam, pushrods, and valve springs for it. All said and done it should be around 450hp.
I bought an industrial sand blast cabinet so small parts cleanup has been a breeze.
I’m hoping the new combination will allow me to not run a body lift. I’ve been doing measurements and it’s going to be tight but possible.
Old 12-20-2018, 02:33 PM #38
warrpath4x4 warrpath4x4 is offline
Real Name: shawn
warrpath4x4 is on a distinguished road
Real Name: shawn
that's one thing i need to get is a blast cabinet.... and a better shop to work in lol.
i will be watching this thread
America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves.
Abraham Lincoln
warrpath4x4 is offline   Reply With QuoteReply With Quote
Old 06-03-2019, 11:40 PM #39
GonOvr's Avatar
Real Name: Nate
GonOvr's Avatar
Real Name: Nate
Little progress. Got the rear end pulled, and started courting out the frame brackets.
Old 06-05-2019, 05:38 PM #40
bump530's Avatar
bump530 bump530 is offline
bump530 is on a distinguished road
bump530's Avatar
nice build. There are plenty of times I wish I would have went with one tons and a 5.3. I just did toy axles and a 4.3 lol.
'90 Vortec 4.3Runner
bump530 is offline   Reply With QuoteReply With Quote
Old 06-09-2019, 12:13 AM #41
GonOvr's Avatar
Real Name: Nate
GonOvr's Avatar
Real Name: Nate
Did some upgrades on the engine.
Texas speed cam, valve springs, pushrods and new valve seals. Need to get some parts painted and round up some parts. Engine is just about done.
Old 06-09-2019, 01:37 PM #42
Jimmy Two Dogs's Avatar
Jimmy Two Dogs Jimmy Two Dogs is offline
Jimmy Two Dogs is on a distinguished road
Originally Posted by GonOvr View Post
The rear door glass only went down with the key. Found the front console switch all gunked up. Took it apart and cleaned the contacts. Fixed.
On my '90 4Runner, the rear window console switch works fine. But the key switch on the tailgate will only lower the window...it won't raise it. Toyota dealer is clueless as to how to fix it.
Do you have any suggestions? I'd love to hear them.
Jimmy Two Dogs is offline   Reply With QuoteReply With Quote
Old 06-09-2019, 09:52 PM #43
GonOvr's Avatar
Real Name: Nate
GonOvr's Avatar
Real Name: Nate
You need to check the green wire with red stripe inside the rear door. That’s your up wire from the key. When you hold the key in the up position that wire should be grounded. If it doesn’t, the wire or switch might be bad.
Old 07-20-2019, 11:02 PM #44
GonOvr's Avatar
Real Name: Nate
GonOvr's Avatar
Real Name: Nate
A little progress. I try to do at least one thing a day.
Got the engine 90% done. Built the new harness and got most of the components on. Still need headers and accessory brackets. Gonna wait until I get the engine in to order some things. Need to measure for room.
I currently have the transmission torn apart to freshen it up and paint it.
I also got a new boat, so a lot of weekend time has been on the water. It’s got a bmw in-line 6 and a rarer than hens teeth bmw z-drive.
Old 07-25-2019, 07:20 PM #45
astynx's Avatar
astynx astynx is offline
astynx is on a distinguished road
astynx's Avatar
Engine looks good. This is going to be a very nice 2nd gen. Mine is gone. Wish I could have had this work done to it. Have fun with the boat.
92, V-6, AT, 31x10.50, 4.88, Leather interior, purchased:1/24/11 with 192,194 miles. New Toyota dealer installed timing belt, timing belt pulley, water pump, T-stat, acc. belts: 12/6/11, 202,475 miles. 242,xxx miles as of 12/08/14. 252,xxx miles as of 08/22/15. 282,xxx miles as of 2/12/18.
KYB Monomax Performance Gas Shocks 565058-front
KYB Monomax Performance Gas Shocks 565059-rear
Moog CC255 Variable Rate Rear Springs
astynx is offline   Reply With QuoteReply With Quote
1996 4runner back wiper and back window switch not working ertmann 3rd gen T4Rs 5 02-02-2018 02:00 AM
need help hooking up aux back up light relay, which wire powers the back up lights? keakar 4th Gen T4Rs 24 01-29-2018 05:08 PM
T4R 1996 back window and back wiper help Paramedic 3rd gen T4Rs 4 04-10-2016 01:48 PM
Back to back Toytech vs xreas drive 03_4x4Runner 5th gen T4Rs 21 04-21-2015 11:08 AM
Back light on top of back window shield billsauce 3rd gen T4Rs 10 12-17-2012 11:06 PM
