Old 08-03-2019, 09:14 PM #46
Hyde802's Avatar
Hyde802 Hyde802 is offline
Real Name: Caleb
Hyde802 has a spectacular aura about Hyde802 has a spectacular aura about
Hyde802's Avatar
Real Name: Caleb
Awesome work! Sweet boat too!
92 ExtraCab on 38s: built for go, not for show
88 4runner: Solid axle, doubler, fun stuff
IG: rattlewagon
Its all about the parts you break, and the friends you make.
Hyde802 is offline   Reply With QuoteReply With Quote
Old 08-08-2019, 02:19 PM #47
VeryWell VeryWell is offline
VeryWell is on a distinguished road
A lot of this went way over my head but I’ll be following all the same
VeryWell is offline   Reply With QuoteReply With Quote
Old 10-15-2019, 09:02 PM #48
GonOvr's Avatar
GonOvr GonOvr is offline
Real Name: Nate
GonOvr is on a distinguished road
GonOvr's Avatar
Real Name: Nate
Well I got the rear suspension cut out and the 14 bolt tacked in. I never knew how soft 63s in a 4runner were! This things gonna ride like a poor mans Cadillac. Need to finish freshing up the transmission, then get those set in to see where its going to live and how much tunnel im going to have to cut.
I also rebuilt the clutch pedal assembly and got that installed.
Project 1-Ton Build Thread**SOLD**
Project 1-Ton Build Thread**Current Rig**
GonOvr is offline   Reply With QuoteReply With Quote
Old 10-16-2019, 10:19 AM #49
bump530's Avatar
bump530 bump530 is offline
bump530 is on a distinguished road
bump530's Avatar
Looking good. Yea the 63s are really soft back there. Im running the 4leaf pack with a AAL to match the front TG 4" springs. Although I think the front has settled enough I may need to make some changes in the rear now.
Im really interested see more of the motor swap. Ive been tempted to swap to a manual trans behind my 4.3 and ive also been tempted add another number a drop a 5.3 in it lol.
'90 Vortec 4.3Runner
bump530 is offline   Reply With QuoteReply With Quote
Old 10-21-2019, 10:45 PM #50
grande grande is offline
grande is on a distinguished road
That 450HP V8 would look good in my '92 T4R. Although merging on to the freeway would be much less "sporting".
grande is offline   Reply With QuoteReply With Quote
Old 10-22-2019, 06:44 AM #51
Redthies's Avatar
Redthies Redthies is offline
Redthies is on a distinguished road
Redthies's Avatar
Cool build Nate. When you say you are trying to keep it low, are you talking 35s? 37s?
‘99 UZJ 100 factory locker with OME and ST Maxxs
‘89 VN60 with OME and BFGs
Redthies is offline   Reply With QuoteReply With Quote
Old 12-08-2019, 10:27 AM #52
GonOvr's Avatar
Real Name: Nate
GonOvr's Avatar
Real Name: Nate
40s I’ve always ran 40s on my builds. I’m trying to keep it low on 40s, there’s a lot of body carving in the near future.
Old 12-21-2019, 12:03 AM #53
GonOvr's Avatar
Real Name: Nate
GonOvr's Avatar
Real Name: Nate
Some more progress!
Rebuilt the wheel ends with new bearings and seals
built my steering using a sky off-road billet pitman arm and 1-ton tie rod ends on the drag link and tie rod. Built the tubes out of 1.5” OD .250” wall dom with ballistic fab tube adapters.
Got the disc brake conversion going using sky off-roads caliper brackets and 3/4ton Chevy rotors and calipers. Now if I want I can run 15s on a Dana 60.
The picture where it’s raked to the rear is gonna be about ride height on 40s. I currently have trail gear 5” up front and a 3 pack of 63s in the rear. I’m gonna wait until I have the drivetrain in place and tires to see how I’m gonna change the height. I’m about 3” off front to rear. I’m thinking about 4” trail gears up front and a flat 1” block in the rear. 🤷🏻*♂️
Tires should be here next week, rear axle is coming out over break to shave the diff, things are coming together ever so slowly...
Old 12-28-2019, 03:00 PM #54
astynx's Avatar
astynx astynx is offline
astynx is on a distinguished road
astynx's Avatar
Fascinating. Thanks for showing us your progress with this build.
92, V-6, AT, 31x10.50, 4.88, Leather interior, purchased:1/24/11 with 192,194 miles. New Toyota dealer installed timing belt, timing belt pulley, water pump, T-stat, acc. belts: 12/6/11, 202,475 miles. 242,xxx miles as of 12/08/14. 252,xxx miles as of 08/22/15. 282,xxx miles as of 2/12/18.
KYB Monomax Performance Gas Shocks 565058-front
KYB Monomax Performance Gas Shocks 565059-rear
Moog CC255 Variable Rate Rear Springs
astynx is offline   Reply With QuoteReply With Quote
Old 12-30-2019, 01:13 PM #55
GonOvr's Avatar
Real Name: Nate
GonOvr's Avatar
Real Name: Nate
So I got the transmission to the shop to be freshened up.
Got the shave kit for the rear axle installed and front diff cover painted and installed.
Front hubs, rear pinion guard, and some clutch parts show up today.
Old 02-03-2020, 12:31 AM #56
GonOvr's Avatar
Real Name: Nate
GonOvr's Avatar
Real Name: Nate
Photo dump.. edit later.
Old 02-04-2020, 02:50 PM #57
Hyde802's Avatar
Real Name: Caleb
Hyde802's Avatar
Real Name: Caleb
That 14b looks awesome. Awesome work as usual!
IG: rattlewagon
Old 02-05-2020, 10:34 AM #58
Red October Red October is offline
Red October will become famous soon enough
Cool build! And some really nice work going on here!
I really like the low height of your Chevy 63s. This is my plan for the rear of my upcoming slow build. How much lift did you get from them? Do you have any pics of how you set up the mounts and stuff? Hope you don't mind me picking your brain a little, just over here doing some research...
If ya always do what ya always done, Ya always gonna get what ya always got.
Red October is offline   Reply With QuoteReply With Quote
Old 02-05-2020, 02:45 PM #59
astynx's Avatar
astynx's Avatar
It sure is worth the wait to see photos of your build. Thanks again for sharing them.
Old 05-07-2020, 12:16 AM #60
GonOvr's Avatar
Real Name: Nate
GonOvr's Avatar
Real Name: Nate
The most expensive part is in. It’s all down to making it work now.
1996 4runner back wiper and back window switch not working ertmann 3rd gen T4Rs 5 02-02-2018 02:00 AM
need help hooking up aux back up light relay, which wire powers the back up lights? keakar 4th Gen T4Rs 24 01-29-2018 05:08 PM
T4R 1996 back window and back wiper help Paramedic 3rd gen T4Rs 4 04-10-2016 01:48 PM
Back to back Toytech vs xreas drive 03_4x4Runner 5th gen T4Rs 21 04-21-2015 11:08 AM
Back light on top of back window shield billsauce 3rd gen T4Rs 10 12-17-2012 11:06 PM
