Been awhile since I updated here since image uploading is such a hassle compared to ExPo.
Since I have owned it, I have noticed that there is a weird issue with the brake and battery light illuminating brighter as the RPMs increase. Normally, I would suspect the voltage regulator on the alternator being suspect, but this issue only happens when the head lights are on, and no other lights get brighter.
Last night, after sitting outside in the cold for 3 to 4 hours, those two lights were illuminating brighter than usual at lower RPMs, and when the turn signal would flash, they would also flash. I have't seen that before, but after driving home, the turn signals no longer interfered with it after switching the headlights off and back on several times.
Not really sure what could be causing all of that??? Maybe something in the stalk? Anyone dealt with anything similar?
Anyways, some of the things I have done recently include:
changing exhaust manifold gasket
blocked off air injection tube
powerwashed interior without carpet in place (cargo area)
new ac control panel
custom bike grip shift knob
2016 Ford Police Interceptor sedan seat install
-driver's has an electric 6 way adjustable base, lumbar, tilt
-passenger's is manual, and I have spent about 15 hours so far working
remounting the oem sliding base to this seat. A little bit more work to
get it sliding and tilting with just the side lever will be necessary.
RX300 head rests for rear seats
RX300 heated seat switches (Will install heating elements with new interior)
Overall, it has been a blast and I have barely driving my cruiser since getting this roadworthy. I just put the can back top back on the other day and left the hardtop at my dad's shop. That will be my next order of business. A couple of the sliding windows are scratched badly and all of the rubber seals are dried up and pointless. So I will be rebuilding those with as much new stuff as I can, patching the small amount of rust on the sliding windows, and probably tinting them in addition to painting the top black for now.
For whatever reason, none of my pictures will upload that show any work, but the pictures from a day trip with a friend and his 5th gen upload.
Edit: tried uploading pictures again and they worked. Different computer but exactly the same photos.
