Almost too much has been done to list since I last updated here but here’s the run down
Front ADV fenders on. Probably took 15 hours just fitting them doing a lot of checking, measuring, finessing, and mount building.
Rear hannemann flares are on. I’m probably in another 20 hours alone just sanding and getting these things to fit close to the body.
I’ve built a bolt in IFS rear LCA truss but the picture failed to upload.
Rear wheel wells have been opened up and I’m about done fiberglassing them in.
I’ve skim coated and block sanded most of the truck at this point. A couple spots needing a little more attention, but I should be ready to tear everything down and get going on primer and block sanding.
I’ve built a rear tire mount that attaches to the roll bar
4.88 2nd gen front diff resealed, sand blasted, painted.
Built a high and tight rear bumper
I know I’m forgetting a lot, but that’s the bigger/cool stuff.
Just waiting on my Kings to show up so I can get going on installing the rear axle and fabricating shock mounts.
Also still waiting on my Blazeland LT kit from TNA. I was told worst case shipping by April but have been told 2 weeks out for several weeks now.
Wheels should be shipping out within the next week or two as they’ve been on back order. I also test fit a 35 from my cruiser with a 3” wheel spacer to see how it would look. I also tested a 285/75r16 on a 16x8
1988 4Runner 22RE and W56 - 203k original miles
1992 Land Cruiser 3FE 413k original miles
