Old 06-24-2020, 01:49 PM #1
WPG93's Avatar
WPG93 WPG93 is offline
Real Name: Paul
WPG93 is on a distinguished road
WPG93's Avatar
Real Name: Paul
Gas smell on my 3VZE
Hey guys,
I couldn't explicitly find what I was looking for in my searches and figured it's probably not a sin to make a new thread given the decline in activity here. I have an 88 manual with the 3VZE and want to deal with a gas smell in my engine bay. It was pointed out to me by a ferry worker while my truck was turned off. I can't smell it very strongly myself so it's hard to detect. Seems like the strongest I can smell is the drivers side of the engine in the area in the photo. I don't see any gas on the injectors that I can see. I've checked my charcoal canister lines and both can be blown into without blockage. Tried to reach behind the engine to touch what others say leaks back there and while I found some gunk, it didn't smell of gas. Any tricks to checking the rails for leaks or even the injectors? This is my daily driver and I'd rather it not burn down! Help me fix my truck please!
Gas smell on my 3VZE-20200624_104753-jpg
WPG93 is offline   Reply With QuoteReply With Quote
Old 06-24-2020, 04:55 PM #2
Voltan73's Avatar
Voltan73 Voltan73 is offline
Real Name: Jason
Voltan73 has a spectacular aura about Voltan73 has a spectacular aura about
Voltan73's Avatar
Real Name: Jason
Check the Fuel Pressure Pulsation Damper...known failure on these...
23207-65010
Voltan73 is offline   Reply With QuoteReply With Quote
Old 06-24-2020, 09:25 PM #3
wallytoo's Avatar
wallytoo wallytoo is offline
wallytoo has a spectacular aura about wallytoo has a spectacular aura about
wallytoo's Avatar
check the fuel lines (the hard lines) running along the passenger side of the chassis back to the tank. mine split, but didn't stop it from running (probably the low-pressure return line, but haven't checked). gas smell, but no visible gas up front at the engine. might be what's happening for you?
member, new hampshire timberland owners association (NHTOA)
1987 4runner sr5, 22re, 5-speed
1988 4runner sr5, 3.0, auto (parts rig)
1987 4runner, sr5, 22re, 5-speed (#2)
wallytoo is offline   Reply With QuoteReply With Quote
Old 06-26-2020, 02:12 PM #4
WPG93's Avatar
Real Name: Paul
WPG93's Avatar
Real Name: Paul
Thanks guys, very good leads. I have now noticed it more towards the back of the engine where the pulsation dampener lives. I've also been noticing it taking an extra crank or two to start, and I think that could be a cause as well. I'll try to find all the fuel lines though.
If I end up going after the dampener, is there a point before I have a replacement? Is there a seal on it that is the culprit or do you scrap the whole unit? Any other preventative maintenance I should do at the same time or any gaskets I'll need to replace during reassembly?
Will keep updating this thread as I go to help others.
Old 06-26-2020, 04:26 PM #5
WPG93's Avatar
Real Name: Paul
WPG93's Avatar
Real Name: Paul
For instance, it seems that I will need some crush washers: 90430-12005. This is because of the lines that need to be removed to wrench off the damper. Reading some horror stories about the fpd6 by standard motor products, I wonder if it's worth shelling out extra for the OEM? It's not on rockauto, where is a good source for OEM parts?
Also looks like I will need gaskets for the plenum/manifold.
Old 06-26-2020, 06:09 PM #6
WPG93's Avatar
Real Name: Paul
WPG93's Avatar
Real Name: Paul
Update on the diagnosis: I have determined it is in fact the fuel injection pulsation damper.
To help others like me who at first couldn't detect for sure a leak there, what I had to do was remove a coolant line (got coolant on my exhaust manifold which was a little stinky) so I could get to it better with a shop towel and clean it off from 30 years of gunk on it. This also makes you more familiar as to where it is. See attached image for the hose I removed. Once it is cleaned off I put the hose back on and tightened it. With the engine running for a couple minutes it wasn't too warm to sneak my fingers back there and touch it while running, at which time my fingers immediately got wet with drips coming on the bottom lip of the mushroom top of it. Mine had the plastic cover on it, so don't expect to feel the middle screw, that round dome thing you feel is in fact the damper.
Looking for any feedback and advice on sourcing the parts needed while doing this procedure.
Gas smell on my 3VZE-20200626_150810-jpg
Old 06-26-2020, 06:12 PM #7
WPG93's Avatar
Real Name: Paul
WPG93's Avatar
Real Name: Paul
Here's what it looked like sneaking my camera in there.
Gas smell on my 3VZE-20200626_151115-jpg
Old 06-27-2020, 06:49 PM #8
WPG93's Avatar
Real Name: Paul
WPG93's Avatar
Real Name: Paul
So I found a really good post by a guy on Yotatech that I thought I'd paste over to here.
Originally Posted by MudHippy on Yotatech
1. The EGR valve and the intake plenum chamber stay/bracket will need disconnected/removed. Disconnect the 2 coolant hoses running to and from the bottom of the throttle body and the 2 heater hoses at the front and rear of the intake plenum chamber. Unplug the TPS and the rear engine ground strap from the intake plenum chamber. A couple vacuum hoses(1 on top of the throttle body mark "P", 1 on top of fuel pressure regulator)and atleast one fuel line(fuel pressure regulator)will need disconnected. Disconnect the accelerator cable from the throttle body and remove it from the intake plenum chamber clips. Disconnect the hoses for the intake silencer and air filter box resonator from the intake plenum chamber. Disconnect the air intake hose from the throttle body. Then unbolt the intake plenum chamber. Lift the intake plenum chamber off the intake manifold and set it aside leaving the throttle body and as many hoses and wires still connected to it(passenger's side)as possible, while leaving enough space to access the fuel pressure pulsation damper.
2. Unscrew the fuel pressure pulsation damper from the end of passenger's side fuel rail. Replace with a new one using new copper gaskets. If the unit itself isn't the cause of the leak, then you may be able to just replace the copper gaskets.
3. Place a new intake plenum chamber gasket on top of the intake manifold. Set the intake plenum chamber on top of that and bolt it securely to the intake manifold. Reconnect the EGR valve, intake plenum chamber stay/bracket, and all hoses and wires.
4. Run the engine with the heater on and the radiator cap off untill the upper radiator hose is warm, to circulate coolant through the system and remove any trapped air(necessary because you'll have disconnected/reconnected atleast 4 coolant lines for the throttle body and heater core in the process). Check the coolant level and refill if needed. Put the radiator cap back on.
5. Your done.
More info/details can be found in the link below.
404 Not Found
There's your write-up. Shouldn't take more than 4-5 hours even if you take your time. It would take me less than 2, because I'm very familiar with how to remove/replace the intake plenum chamber efficiently.
Here's the stuff I forgot, diagrams and part #'s.
17176 GASKET, AIR SURGE TANK TO INTAKE MANIFOLD
17176-65020 3VZE
23270 DAMPER ASSY, FUEL PRESSURE PULSATION
23207-65010 3VZE
23270B GASKET (FOR PULSATION DAMPER HOSE)
90430-18028 3VZE
23807J GASKET, PIPE FUEL DELIVARY INLET
90430-18028 3VZE
Still trying to figure out where to best source OEM parts.
Gas smell on my 3VZE-a1_maa563c-jpg  Gas smell on my 3VZE-a1_178705-jpg
Old 06-29-2020, 05:05 PM #9
WPG93's Avatar
Real Name: Paul
WPG93's Avatar
Real Name: Paul
Found out that my crush washer will be different part number to the one above because my truck is older. Also having to pay absurd prices on the damper from the local dealer because I can't stomach Amazon's shipping time... If anyone has a source for OEM would be appreciated for future endeavors. Too many nightmare reviews on the knock off damper for me to handle going rockauto on this one.
Old 06-30-2020, 11:25 AM #10
Voltan73's Avatar
Real Name: Jason
Voltan73's Avatar
Real Name: Jason
Sometimes you just have to forget about the coin, and do what's best for your rig. I'm a 19 year veteran parts counterman for a Toyota dealer. I cannot stress enough the quality of genuine Toyota parts over aftermarket garbage. This is NOT because I work for a dealer...this is from 19 years of gained knowledge and experience.
Glad to hear you figured it out.
Old 06-30-2020, 09:37 PM #11
WPG93's Avatar
Real Name: Paul
WPG93's Avatar
Real Name: Paul
Thanks @Voltan73 , it just hurts paying twice the price of the same part I can get on Amazon that's a Denso, from a dealership. I definitely decided OEM was the way to go, had to pay double since it's my daily driver and I couldn't wait as long.
My parts store is confident they can provide the crush washers that the dealership couldn't get for me. Wondering if anyone has any issues with stuff like that?
Old 06-30-2020, 11:22 PM #12
Voltan73's Avatar
Real Name: Jason
Voltan73's Avatar
Real Name: Jason
Let me check on the washers at work tomorrow...I may have them in stock. 90430-18028, correct? How many do you want if so? Could mail perhaps...
Out of curiosity, does Amazon offer a warranty for the parts? Toyota's is 12 months, unlimited mileage. Lifetime for certain exhaust and suspension parts.
Old 07-01-2020, 11:25 AM #13
Voltan73's Avatar
Real Name: Jason
Voltan73's Avatar
Real Name: Jason
I have 4 of the 90430-18028 washers in stock. $4.97 each plus tax, and maybe an extra buck to mail them? Let me know if you want them...
Edit---Just noticed you're in Canada...would make the postage higher I would suspect...
Old 07-02-2020, 02:02 AM #14
WPG93's Avatar
Real Name: Paul
WPG93's Avatar
Real Name: Paul
@Voltan73 , actually the crush washers I need are the ones for the fuel delivery pipe that sits right above the damper not the ones for the damper itself. Yeah in the Yukon no less.
Old 07-03-2020, 06:14 PM #15
WPG93's Avatar
Real Name: Paul
WPG93's Avatar
Real Name: Paul
Ok so I've got it open and removed the damper, what should I do while I'm in here? I couldn't remove the last hose under the back passenger side of the plenum, any advice to get that off?
I had to turn a fitting that was in the path of the damper twisting out. Should I not have? What is it and any risk to damaging it by giving it a quarter to a half turn? It has two little blue nipples on the top of it, picture provided.
I got the damper off and it rattled. Brought it in and the little screw had come loose and was caught in the shroud, is this why it was leaking? Is my damper possibly fine and I can just screw the screw back in? Any advice on this screw would be good. Do I adjust the screw on the new damper before putting it in?
Gas smell on my 3VZE-20200703_151245-jpg  Gas smell on my 3VZE-20200703_151303-jpg  Gas smell on my 3VZE-20200703_151319-jpg
engine , gas , injectors , smell , truck
Fuel Smell/ oil smell wingzerom31996 4th Gen T4Rs 3 12-31-2016 03:40 AM
Burning rubber smell after 'hot brake' smell westwind77 5th gen T4Rs 7 02-11-2013 01:26 PM
91 3VZE into 93 Auto 3VZE Swap 4beginner Classic T4Rs 1 04-13-2011 08:54 AM
Differences in 91 3vze and 95 3vze Deranged Classic T4Rs 2 03-14-2011 04:37 PM
