Old 12-23-2019, 03:12 PM #46
warrpath4x4 warrpath4x4 is offline
Real Name: shawn
warrpath4x4 is on a distinguished road
Real Name: shawn
Situation: So i have a ARB in the rear right now, i am picking up an E-locker and will be going solid axle in the front.
Question: ARB rear E-locker front or E-locker rear ARB front?
any reason behind which should go in the front besides clearance for the E-locker?
America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves.
Abraham Lincoln
warrpath4x4 is offline   Reply With QuoteReply With Quote
Old 01-02-2020, 03:51 PM #47
Real Name: shawn
Real Name: shawn
i never get as much time in on projects as i plan for while on vacation.
surprisingly the only rust in the frame is in the front
this was after using the needle scaler
one other small rust hole found using the needle scaler
cutting out the old captured nut
after wire wheeling it
i bought a trail gear winch mount, it uses the 4 bolt holes across the cross member and has 2 extra holes above the cross member but theres nothing to bolt to there on these frames. having to cut out the captured nut i was reinforcing the front, replacing the captured nut, and added 2 more extra holes to the winch mount.
welded the brace plate in on the ends, 3 plug welds in the cross member, and stitch welded on the bottom of the cross member.
bolted up, i painted it black yesterday but didnt get another pic. still need to mount the winch to it.
and just because i have noticed i dont have many "over all" shots, theyre mostly of the areas i am working on.
Abraham Lincoln
Old 01-03-2020, 09:29 AM #48
Hyde802's Avatar
Hyde802 Hyde802 is offline
Real Name: Caleb
Hyde802 has a spectacular aura about Hyde802 has a spectacular aura about
Hyde802's Avatar
Real Name: Caleb
Nice patch job!
92 ExtraCab on 38s: built for go, not for show
88 4runner: Solid axle, doubler, fun stuff
IG: rattlewagon
Its all about the parts you break, and the friends you make.
Hyde802 is offline   Reply With QuoteReply With Quote
Old 01-06-2020, 01:16 PM #49
Real Name: shawn
Real Name: shawn
Kept loosing coolant, and could smell it but couldn't see where it was coming from, wasn't losing a lot but enough to notice. got some leak testing dye from work and an ultraviolet flashlight, the only place i could see it leaking from was the upper radiator hose, I got about an extra turn out of it.
Ive taken it down the freeway a couple times now, at 70 my Speedo is reading 80.
Abraham Lincoln
Old 01-10-2020, 11:51 AM #50
Real Name: shawn
Real Name: shawn
Drove it 45 miles down the freeway to work today, did pretty good now that i have it timed better.
Abraham Lincoln
Old 01-13-2020, 06:54 PM #51
Real Name: shawn
Real Name: shawn
my plan for yesterday was to install the air tank and get my ARB working, with the wind we have been having that sounded like a horrible idea. So i nosed the 4Runner into the shop doors and installed the winch.
extended the cables from the winch to the control box with welding ground cables and put it inside the engine bay. Installed an El Jefe winch hook stopper and have an ebay winch cover for it.
Abraham Lincoln
Old 01-15-2020, 02:37 PM #52
Real Name: shawn
Real Name: shawn
got pulled over last night by a very nice policeman who said the next time he seen me without front turn signals i would be getting a ticket. Stopped by the parts store and picked up some temporary lights and installed them in 11 degree weather. on a side note i have been daily driving it this week 100 miles a day.
I knew i was in violation but was hoping to get the front bumper finished first.
Abraham Lincoln
Old 01-17-2020, 02:55 PM #53
BLANKOHA BLANKOHA is offline
BLANKOHA is on a distinguished road
. We had a 93 XJ and while I could work on it, it needed a lot and just didn't feel right, so i sold it and promptly bought this 4Runner. Lucky Patcher Kodi nox
BLANKOHA is offline   Reply With QuoteReply With Quote
Old 01-21-2020, 12:38 PM #54
Real Name: shawn
Real Name: shawn
sometimes its the small things, like a working windshield washer.
A previous owner put an aftermarket pump on the inner fender but it doesn't pull to well through the old rusted out pump. i blocked off the hole for the rear washer pump, put a new one in the tank for the front and fixed the wiring... ta da a working windshield washer.
Abraham Lincoln
Old 01-23-2020, 04:43 PM #55
Awesome looking project; looking forward to following the progress... snaptube telegram web
Old 01-31-2020, 05:20 PM #56
Real Name: shawn
Real Name: shawn
last week I decided to test the ARB to make sure it was working... it is not. wouldn't lock and I could hear air leaking, guessing an o-ring is leaking.
Today I ordered a set of 4.88 gears and a spartan locker, going to install them in a spare third member and put it in the rear. I will keep the ARB third member for when I do my SAS. Also ordered a couple of triple drilled flanges (ARB third already has one) for when I install the 4.7:1 transfer case gears.
Abraham Lincoln
Old 02-07-2020, 01:57 PM #57
J675465 J675465 is offline
J675465 is on a distinguished road
I would love an older 4runner. I sometimes see them around town and love the look
J675465 is offline   Reply With QuoteReply With Quote
Old 02-25-2020, 06:38 AM #58
NJTMayhem NJTMayhem is offline
NJTMayhem is on a distinguished road
Thumbs up
I know it's only been 2 weeks but I hope this build is still going on, I'm really enjoying the ride
NJTMayhem is offline   Reply With QuoteReply With Quote
Is the 4Runner your toy or daily driver? Bumbo 4th Gen T4Rs 23 12-12-2016 11:18 PM
Just brought home my new project/daily driver jmitchell79 Classic T4Rs 12 12-07-2013 09:12 AM
WTB 1st gen 4runner (daily driver) alexgvojic Classifieds - buy & sell (no commercial ads please) 0 05-06-2009 01:26 PM
Is the 4Runner your daily driver? jwa898 4th Gen T4Rs 92 05-23-2008 07:54 AM
88' SAS 4runner. Built Daily driver AddictedOffroad Classifieds - buy & sell (no commercial ads please) 0 02-21-2008 10:26 PM
