Old 10-29-2018, 12:19 PM #1
warrpath4x4 warrpath4x4 is offline
Real Name: shawn
warrpath4x4 is on a distinguished road
Real Name: shawn
Project daily driver 1991 4Runner
This weekend the wife and i went and picked up this 91 4Runner. Currently I drive a 06 Jetta TDI but it has had electrical issues and cost us way to much in repairs, I wanted to get something I could work on myself and was 4wd. We had a 93 XJ and while I could work on it, it needed a lot and just didn't feel right, so i sold it and promptly bought this 4Runner.
specs:
1991 4Runner
22RE
5-speed
3" (or 4) lift
33" tires
4.88 gears
ARB locker in rear but needs a compressor (have not verified locker yet)
sun roof
I had planned on putting a header in it and a new radiator but it already has a Doug Thorley header and a new radiator in it. So i will catch it up on maintenance with a full tune up, replace all the hoses, change all fluids, verify the locker and if so add a compressor, add dual batteries (more than likely in a custom box where the spare is currently located), tire carrier rear bumper, winch/bumper front, big 3 upgrade, higher output alternator.
planning on repairing this and getting some seat covers
back seats in good shape
onto the rust spots, while its not horrible, they do need addressed
somebody has already been into the AFM, and there are 3 different types of fasteners loosely holding it together and the piping is cobbled together, i am going to get a cold air intake and build a heat shield for it.
new radiator
i am not surprised it has a power steering leak, even though it is not directly coming from right here
and i thought this was mud caked on until i took my knife to it and yup, more rust. so far it looks like the frame rust is isolated to the front, i need to look at the frame again but the rest looked ok. so i am going to hit it with a wire wheel, cut as needed and weld in some new steel.
America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves.
Abraham Lincoln
warrpath4x4 is offline   Reply With QuoteReply With Quote
Old 10-30-2018, 10:12 AM #2
Pick_T4R's Avatar
Pick_T4R Pick_T4R is offline
Pick_T4R is on a distinguished road
Pick_T4R's Avatar
Awesome looking project; looking forward to following the progress...
I'm in 'paralysis by analysis' on my '94. Can't decide whether to pull the engine and do a full rebuild or just patch things up to get it going... so I've just been driving it as-is for now.
Pick_T4R is offline   Reply With QuoteReply With Quote
Old 10-30-2018, 01:46 PM #3
Arild Arild is offline
Arild is on a distinguished road
I like the brown interiour
Looking forward to your tire carrier bumper mount. I want to do the same
Arild is offline   Reply With QuoteReply With Quote
Old 10-30-2018, 06:16 PM #4
Real Name: shawn
Real Name: shawn
my UPS and Fedex drivers are not going to like me next week, they will be at my house every day according to tracking numbers.
tune up stuff
140 amp alternator
cold air intake
winch
new dipstick from LCE
wiring harness for the alternator
latch from McMaster-Carr for the swing out
still need to order a power steering cooler but i need to look at available space with the auxiliary fan in front of the A/C condenser first
Abraham Lincoln
Old 10-30-2018, 06:18 PM #5
Real Name: shawn
Real Name: shawn
thats kind of how the Xj was, not enough to fix it how i wanted it so i just kept driving it.
Abraham Lincoln
Old 10-30-2018, 06:20 PM #6
Real Name: shawn
Real Name: shawn
thanks,
if it wasn't for the tear in the driver side it would be in really good shape, i have been looking for seat covers but they're either generic ones that dont fit well, or $200 a seat.
Abraham Lincoln
Old 10-31-2018, 10:58 PM #7
Real Name: shawn
Real Name: shawn
took it in today to get the one busted wheel stud replaced and a front end alignment (pulled hard to the left), they said they helped the alignment but he couldnt complete it due to the idler needing replaced. so i brought it home (now it veers to the right pretty good) and ordered more parts for it today, idler, pitman, tie rods, and found my steering leak, its the box itself so i ordered a reman box for it.
verified it does have an ARB in it, the bulk head is still in the housing but someone must have cut the hose when they pulled the compressor, now i need to look into how to clean the locker or what needs done since who knows if there is mud or dirt in there. i ordered a Viair compressor and an air tank for it, along with some other little things like USB ports and flush mount LED's for the rear bumper.
digging around in the cubby's in the back i found this
Abraham Lincoln
Old 11-02-2018, 10:54 AM #8
Real Name: shawn
Real Name: shawn
parts are starting to roll in, not really much of an update but the old dipstick wasn't sealing and was just flopping around, while it may have been fine it was only about $20 for a new Toyota OEM dipstick from LCE.
my cold air intake also showed up and i got it mocked up but the elbow coming off the intake is not long enough so the cross pipe hits the sling hook. i am either going to look for a longer elbow or just get a piece of pipe to extend it out towards the core support. by the time i got that far into it, it was dark.
Abraham Lincoln
Old 11-07-2018, 12:22 AM #9
ddonovan48 ddonovan48 is offline
ddonovan48 is on a distinguished road
im currently on the same journey, trying to get my 84 road worthy. good luck to you!
ddonovan48 is offline   Reply With QuoteReply With Quote
Old 11-07-2018, 02:09 AM #10
Real Name: shawn
Real Name: shawn
by tomorrow all the big items should be here (the 4runner is full of boxes), i will still need to get the small stuff (belts, wire, fluids). As luck would have it though i fly out sunday for a week in Dallas for work, i wonder if my parts will be thinking of me while im thinking of them lol.
Abraham Lincoln
Old 11-18-2018, 11:13 PM #11
Real Name: shawn
Real Name: shawn
I am back from Dallas and got a total of about 10 minutes to work on the 4runner this weekend.
here is the routing of the CAI hitting the engine hook
putting it in a bind against the overflow tank
i ordered up an extension and a new elbow and adapter
but i think it may be a little too long, i may need to shorten it up a little to align things better
and i still need to build a heat shield.
Abraham Lincoln
Old 12-04-2018, 07:26 PM #12
Real Name: shawn
Real Name: shawn
last weekend i got the fan, alt, water pump, and associated bracketry removed, tried to test fit the new CS144 alternator but it doesn't look like it will work (without more mods than i want to do right now) so i found a stock size 130 amp unit to put back in that is supposed to be here Monday. I will put the CS144 in my 72 K5 next spring when i revamp the electrical system in it. I have yet to put anything back together between the cold weather and the cold my son gave me i have not done much of anything.
Abraham Lincoln
Old 12-05-2018, 11:29 AM #13
Ahlem Ahlem is offline
Ahlem is on a distinguished road
Try a Harbor Freight Needle Scaler on that rusty frame stuff. I was amazed at how much work it did before hitting it with a wire brush or sandblaster.
My son and daughter-in-law are in Moses Lake and have a TDI as well.
Ahlem is offline   Reply With QuoteReply With Quote
Old 12-05-2018, 01:06 PM #14
Real Name: shawn
Real Name: shawn
any excuse for more tools right? i will have to pick one up and try it.
Abraham Lincoln
Old 01-07-2019, 12:37 PM #15
Real Name: shawn
Real Name: shawn
Finally got some time to work on the 4Runner yesterday with our weird weather were having.
i was wrong when saying the power steering cooler needed replaced, it was the A/C condenser, and since the A/C doesn't work i don't see the point in keeping extra parts on the rig.
much more space now
and without the condenser and everything else in the way, the radiator will get more air flow
i had planned on keeping the A/C fan but its a little rusty
this is what its suppose to look like
with the rust in the front of the frame i was fearing what i was going to find when i pulled their little skid off that was bolted under the radiator... but i was pleasantly surprised.
Abraham Lincoln
Is the 4Runner your toy or daily driver? Bumbo 4th Gen T4Rs 23 12-12-2016 11:18 PM
Just brought home my new project/daily driver jmitchell79 Classic T4Rs 12 12-07-2013 09:12 AM
WTB 1st gen 4runner (daily driver) alexgvojic Classifieds - buy & sell (no commercial ads please) 0 05-06-2009 01:26 PM
Is the 4Runner your daily driver? jwa898 4th Gen T4Rs 92 05-23-2008 07:54 AM
88' SAS 4runner. Built Daily driver AddictedOffroad Classifieds - buy & sell (no commercial ads please) 0 02-21-2008 10:26 PM
