Old 12-30-2018, 06:04 PM #1
lonewolf98765 lonewolf98765 is offline
lonewolf98765 is on a distinguished road
Front end lift advice
Alright,
When I first started on here I felt like a noob because I was fourteen. Now 6 years and many extensive repairs later I ant to finally get the front end up. I went full balls when I did the zuk mod so I have about 3-4 inches of lift in the back. Maybe along the lines the torsions were cranked by a p.o. Not sure but what do people tend to incorporate into adding ball joint spacers-beyond a diff drop. I found 3" spacers and a either1.5"-2" diff drop. Not sure where to go from there. Adding pictures of it tonight.
lonewolf98765 is offline   Reply With QuoteReply With Quote
Old 12-30-2018, 06:51 PM #2
Dropzone's Avatar
Dropzone Dropzone is offline
Dropzone is a jewel in the rough Dropzone is a jewel in the rough Dropzone is a jewel in the rough
Dropzone's Avatar
you could always cut a coil out of the zuk mod, crank the torsions back to stock (probably rides like crap with cranked torsions anyway)
personally I feel that is a band aid fix and would just replace the springs correctly
1994 4Runner AKA: Project Recycle
@503dropzone on IG
Dropzone is offline   Reply With QuoteReply With Quote
Old 12-30-2018, 09:45 PM #3
I mean yeah I could do that but I could also just lift my chevy... but what would be the fun in that? I got the tires spaced out 2.5" per side, running 16" rims from a 2000 sr5 on 31"s When these tires are dead I'm putting on 33"s and the 31s still rub so she has to go up
Old 12-31-2018, 01:32 PM #4
superex87 superex87 is offline
superex87 is on a distinguished road
For the front there are a few options.
1- Bracket lift. I want to say rough country makes one.
2- Mid or long travel. Blazeland makes a nice mid travel DIY kit. Total chaos makes a long travel. Both will lift and significantly improve ride.
3- Solid axle swap.
superex87 is offline   Reply With QuoteReply With Quote
Old 01-01-2019, 02:47 PM #5
Johnny0's Avatar
Johnny0 Johnny0 is offline
Johnny0 is on a distinguished road
Johnny0's Avatar
We had a Rancho suspension IFS lift on our 1st gen. The kit consisted of all new Upper A arms with mounting brackets. Had a new frame member (bolt in) in front to lower front differential. Had two brackets to carry the front differential lower. and a stiffening bracket (in black) below the front diff in back and it bolted to the inside of the frame carriers of the LCA's. Will try and post some pics.
Most of the parts are Red. UCA
Lower bracket
Can see red diff carrier brackets and gusset bracket
You can see how the UCA carring bracket wraps over the top of frame rail and extended down on inside of frame rail in this pic
Last edited by Johnny0; 01-01-2019 at 02:58 PM. Reason: pics didn't show. (broken link)
Johnny0 is offline   Reply With QuoteReply With Quote
Old 09-02-2020, 11:09 PM #6
JustinSmileySteele's Avatar
JustinSmileySteele JustinSmileySteele is offline
JustinSmileySteele is on a distinguished road
3- Solid axle swap.
How much lift does the blazeland front end kit provide?
JustinSmileySteele is offline   Reply With QuoteReply With Quote
ball joint spacer , diff drop
Urgent 96 Front lift upgrade advice?? tenguns 3rd gen T4Rs 4 05-04-2014 08:37 PM
front suspension upgrade/lift question/advice bhsewu90 3rd gen T4Rs 5 01-28-2014 02:51 AM
New 3rd Gen owner looking for some tips(Lift Advice, front end parts advice) Strain 3rd gen T4Rs 2 09-20-2013 10:49 AM
Help/advice on front lift + rear leveling + tire size CaptainCrump 4th Gen T4Rs 2 02-05-2013 04:53 PM
OW 2.0 Lift v. OME 885 front, 895 rear: advice please cmoney 4th Gen T4Rs 16 01-29-2012 07:32 PM
