Old 01-22-2019, 05:49 PM #1
danielevioli danielevioli is offline
danielevioli is on a distinguished road
Removing / replacing front brake rotors questions...
Picked up an 86 22re sr5. It was leaking brake fluid (w/ complete loss of brake power) so checked the rotor. I can't imagine how this kind of damage could have happened. See image
Anyways, onto new rotors and calipers. This is my first time doing this job.
This model has front manual locking hub. I understand I have to remove this. Do I have to disassemble it completely or just unbolt the cover then the assembly and it comes out?
I'll also be replacing the CV half shaft axles since they're shot. Question: should I expect to have to change any seals or oil rings or clips etc?
While I'm there, anything else to look out for?
Removing / replacing front brake rotors questions...-screen-shot-2019-01-22-1-50-30-pm-jpg
danielevioli is offline   Reply With QuoteReply With Quote
Old 01-24-2019, 12:54 AM #2
maco33 maco33 is offline
maco33 is on a distinguished road
Here, the only difference are the manual locking hubs on your truck everything else is the same.
YouTube
1987 4runner SR5, Auto Trans, fully loaded, zuk mod, smittybilt bumpers, 31 inch tires.
maco33 is offline   Reply With QuoteReply With Quote
Old 01-24-2019, 12:59 AM #3
YouTube
Old 01-24-2019, 01:05 AM #4
How to rebuilt your manual locking hubs.
Rebuilding Aisin locking hub Locking hub rebuild | IH8MUD Forum
Toyota Maintenance: Reassembling the Front End - Bearings, Hubs, and Rotors
Old 01-26-2019, 01:59 AM #5
thank you very much for the references. spot on! job looks doable! I'm doing it tomorrow morning, along with bearings and axles since they're visibly shot
as for the hub lock nut, i couldn't get my hands on the 54mm in time so i rented a 2 3/8 inch, do you think this would work or too big? if not... i'll just have to try to screw/unscrew it with a wedge and hammer i guess. should be doable?
since i'm there i plan on changing outer bearing and inner bearing and seal.
as well as the axles. i'm using this vid as reference, seems straight forward...
cv axles removal
as for the brake / rotors do i need any other gaskets or seals? there seems to be some gasket between hub / rotor? how essential is it?
as for the axle, is there any bearing, seal, or gasket that should be changed for the axle?
and lastly... can someone direct me to where i can find the torque specs? i found a "standard" bolt torque chart, but can't find the specific tonques in the manual section i'm seeing.
Old 01-26-2019, 02:28 AM #6
actually now learned more about the hub cap gasket. it doesn't seem to be available at stores
what purpose does it serve?
Old 01-27-2019, 03:44 PM #7
Ahlem Ahlem is offline
Ahlem is on a distinguished road
You can get generic gasket material at most NAPA stores and make your own pretty easily.
Ahlem is offline   Reply With QuoteReply With Quote
Old 01-29-2019, 02:41 PM #8
Done! Update:
So it was relatively painless... I felt the learning curve on the first side and broke a couple bolts (one off the upper control arm joint and one off the locking hub cap). Other than that, everything worked out pretty good! The second side was a lot easier and faster.
Perhaps the hardest part was unbolting the axle from the transfer case. The magic method to prop up a metal bar to keep it from spinning and then to use a breaker bar.
Also to easily remove the cv axle I removed sway bar, suspension damper and upper ball joint. Jacked up the suspension and the axle slipped right out the back.
Also was good to clean up the hubs and see how they work.
Also I changed the inner and outer wheel bearings.
Woohoo! Now onto my broken chain guides!
Removing / replacing front brake rotors questions...-screen-shot-2019-01-29-10-37-35-am-jpg  Removing / replacing front brake rotors questions...-screen-shot-2019-01-29-10-34-27-am-jpg  Removing / replacing front brake rotors questions...-screen-shot-2019-01-29-10-39-22-am-jpg  Removing / replacing front brake rotors questions...-screen-shot-2019-01-29-10-39-32-am-jpg
brake , cover , front , replacing , rotors
Extras for replacing brake pads/rotors/shoes? repo 3rd gen T4Rs 6 01-27-2016 12:06 PM
Help replacing front rotors on 2010 SR5 YukonJack 5th gen T4Rs 8 03-28-2014 08:19 PM
Replacing Rotors, questions about pads... AZ4runner08 4th Gen T4Rs 7 12-04-2013 01:41 AM
Replacing rear brake rotors 2005 4runner Tango22 4th Gen T4Rs 3 11-18-2013 09:12 PM
Need help replacing front rotors bythabay Nor Cal 1 04-29-2010 10:27 PM
